[petsc-users] Compiling PETSC with Intel OneAPI compilers and OpenMPI
Mon May 15 11:53:33 CDT 2023
Send us
  $PETSC_ARCH/include/petscconf.h
     Matt
On Mon, May 15, 2023 at 12:49 PM Vanella, Marcos (Fed) <
marcos.vanella at nist.gov> wrote:
> Hi Matt, I configured the lib like this:
> $ ./configure --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1
> --with-debugging=0 --with-shared-libraries=0 --download-make
> and compiled. I still get some check segfault error. See below:
> $ make PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1
> PETSC_ARCH=arch-darwin-c-opt check
> Running check examples to verify correct installation
> Using PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 and
> *******************Error detected during compile or
> link!*******************
> See https://petsc.org/release/faq/
> /Users/mnv/Documents/Software/petsc-3.19.1/src/snes/tutorials ex19
> mpicc -Wl,-bind_at_load -Wl,-multiply_defined,suppress
> -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs
> -Wl,-search_paths_first -Wl,-no_compact_unwind  -fPIC -wd1572
> -Wno-unknown-pragmas -g -O3
>  -I/Users/mnv/Documents/Software/petsc-3.19.1/include
> -I/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/include
> -I/opt/X11/include  -std=c99    ex19.c
>  -L/Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/lib
> -Wl,-rpath,/opt/intel/oneapi/mkl/2022.2.1/lib
> -L/opt/intel/oneapi/mkl/2022.2.1/lib -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib
> -L/opt/openmpi414_oneapi22u3/lib
> -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib
> -L/opt/intel/oneapi/tbb/2021.7.1/lib -L/opt/intel/oneapi/ippcp/2021.6.2/lib
> -L/opt/intel/oneapi/ipp/2021.6.2/lib
> -L/opt/intel/oneapi/dnnl/2022.2.1/cpu_iomp/lib
> -L/opt/intel/oneapi/dal/2021.7.1/lib
> -L/opt/intel/oneapi/compiler/2022.2.1/mac/compiler/lib
> -L/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk/usr/lib
> -Wl,-rpath,/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib
> -L/opt/intel/oneapi/compiler/2022.2.1/mac/bin/intel64/../../compiler/lib
> -Wl,-rpath,/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin
> -L/Library/Developer/CommandLineTools/usr/lib/clang/14.0.3/lib/darwin
> -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lX11
> -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lopen-rte
> -lopen-pal -limf -lm -lz -lifport -lifcoremt -lsvml -lipgo -lirc -lpthread
> -lclang_rt.osx -lmpi -lopen-rte -lopen-pal -limf -lm -lz -lsvml -lirng
> -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -lmpi -lopen-rte -lopen-pal
> -limf -lm -lz -lsvml -lirng -lc++ -lipgo -ldecimal -lirc -lclang_rt.osx -o
> ex19
> icc: remark #10441: The Intel(R) C++ Compiler Classic (ICC) is deprecated
> and will be removed from product release in the second half of 2023. The
> Intel(R) oneAPI DPC++/C++ Compiler (ICX) is the recommended compiler moving
> forward. Please transition to use this compiler. Use '-diag-disable=10441'
> to disable this message.
> In file included from
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsys.h(44),
>                  from
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscvec.h(9),
>                  from
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscmat.h(7),
>                  from
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscpc.h(7),
>                  from
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscksp.h(7),
>                  from
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsnes.h(7),
>                  from ex19.c(68):
> /Users/mnv/Documents/Software/petsc-3.19.1/include/petscsystypes.h(68):
> warning #2621: attribute "warn_unused_result" does not apply here
>   PETSC_ERROR_CODE_TYPEDEF enum PETSC_ERROR_CODE_NODISCARD {
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> [excess:37807] *** Process received signal ***
> [excess:37807] Signal: Segmentation fault: 11 (11)
> [excess:37807] Signal code: Address not mapped (1)
> [excess:37807] Failing at address: 0x7f
> [excess:37807] *** End of error message ***
> Primary job  terminated normally, but 1 process returned
> a non-zero exit code. Per user-direction, the job has been aborted.
> mpiexec noticed that process rank 0 with PID 0 on node excess exited on
> signal 11 (Segmentation fault: 11).
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> [excess:37831] *** Process received signal ***
> [excess:37831] Signal: Segmentation fault: 11 (11)
> [excess:37831] Signal code: Address not mapped (1)
> [excess:37831] Failing at address: 0x7f
> [excess:37831] *** End of error message ***
> [excess:37832] *** Process received signal ***
> [excess:37832] Signal: Segmentation fault: 11 (11)
> [excess:37832] Signal code: Address not mapped (1)
> [excess:37832] Failing at address: 0x7f
> [excess:37832] *** End of error message ***
> mpiexec noticed that process rank 1 with PID 0 on node excess exited on
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
> process
> forrtl: severe (174): SIGSEGV, segmentation fault occurred
> Image              PC                Routine            Line        Source
> libifcoremt.dylib  000000010B7F7FE4  for__signal_handl     Unknown  Unknown
> libsystem_platfor  00007FF8024C25ED  _sigtramp             Unknown  Unknown
> ex5f               00000001087AFA38  PetscGetArchType      Unknown  Unknown
> ex5f               000000010887913B  PetscErrorPrintfI     Unknown  Unknown
> ex5f               000000010878D227  PetscInitialize_C     Unknown  Unknown
> ex5f               000000010879D289  petscinitializef_     Unknown  Unknown
> ex5f               0000000108713C09  petscsys_mp_petsc     Unknown  Unknown
> ex5f               0000000108710B5D  MAIN__                Unknown  Unknown
> ex5f               0000000108710AEE  main                  Unknown  Unknown
> dyld               00007FF80213B41F  start                 Unknown  Unknown
> mpiexec detected that one or more processes exited with non-zero status,
> thus causing
> the job to be terminated. The first process to do so was:
>   Process name: [[48108,1],0]
>   Exit code:    174
> Completed test examples
> Error while running make check
> make[1]: *** [check] Error 1
> make: *** [check] Error 2
> *From:* Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
> *Sent:* Monday, May 15, 2023 12:20 PM
> *To:* Matthew Knepley <knepley at gmail.com>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Compiling PETSC with Intel OneAPI compilers
> and OpenMPI
> Thank you Matt I'll try this and let you know.
> Marcos
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Monday, May 15, 2023 12:08 PM
> *To:* Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
> and OpenMPI
> On Mon, May 15, 2023 at 11:19 AM Vanella, Marcos (Fed) via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hello, I'm trying to compile the PETSc library version 3.19.1 with OpenMPI
> 4.1.4 and the OneAPI 2022 Update 2 Intel Compiler suite on a Mac with OSX
> Ventura 13.3.1.
> I can compile PETSc in debug mode with this configure and make lines. I
> can run the PETSC tests, which seem fine.
> When I compile the library in optimized mode, either using -O3 or O1, for
> example configuring with:
> I hate to yell "compiler bug" when this happens, but it sure seems like
> one. Can you just use
>   --with-debugging=0
> without the custom COPTFLAGS, CXXOPTFLAGS, FOPTFLAGS? If that works, it is
> almost
> certainly a compiler bug. If not, then we can go in the debugger and see
> what is failing.
>   Thanks,
>     Matt
> $ ./configure --prefix=/opt/petsc-oneapi22u3
> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2022.2.1 COPTFLAGS='-m64 -O1 -g
> -diag-disable=10441' CXXOPTFLAGS='-m64 -O1 -g -diag-disable=10441'
> FOPTFLAGS='-m64 -O1 -g' LDFLAGS='-m64' --with-debugging=0
> and using mpicc (icc), mpif90 (ifort) from  Open MPI, the static lib
> compiles. Yet, I see right off the bat this segfault error in the first
> PETSc example:
> PETSC_ARCH=arch-darwin-c-opt test
> /Users/mnv/Documents/Software/petsc-3.19.1/arch-darwin-c-opt/bin/make
> --no-print-directory -f
> /Users/mnv/Documents/Software/petsc-3.19.1/gmakefile.test
> PETSC_DIR=/Users/mnv/Documents/Software/petsc-3.19.1 test
> /opt/intel/oneapi/intelpython/latest/bin/python3
> /Users/mnv/Documents/Software/petsc-3.19.1/config/gmakegentest.py
> --petsc-dir=/Users/mnv/Documents/Software/petsc-3.19.1
> --petsc-arch=arch-darwin-c-opt --testdir=./arch-darwin-c-opt/tests
> Using MAKEFLAGS: --no-print-directory -- PETSC_ARCH=arch-darwin-c-opt
>          CC arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1.o
>                  from
> /Users/mnv/Documents/Software/petsc-3.19.1/src/sys/classes/draw/tests/ex1.c(4):
>     CLINKER arch-darwin-c-opt/tests/sys/classes/draw/tests/ex1
>        TEST
> arch-darwin-c-opt/tests/counts/sys_classes_draw_tests-ex1_1.counts
> not ok sys_classes_draw_tests-ex1_1 *# Error code: 139*
> *# [excess:98681] *** Process received signal ****
> *# [excess:98681] Signal: Segmentation fault: 11 (11)*
> *# [excess:98681] Signal code: Address not mapped (1)*
> *# [excess:98681] Failing at address: 0x7f*
> *# [excess:98681] *** End of error message ****
> # Primary job  terminated normally, but 1 process returned
> # a non-zero exit code. Per user-direction, the job has been aborted.
> # mpiexec noticed that process rank 0 with PID 0 on node excess exited on
>  ok sys_classes_draw_tests-ex1_1 # SKIP Command failed so no diff
> I see the same segfault error in all PETSc examples.
> Any help is mostly appreciated, I'm starting to work with PETSc. Our plan
> is to use the linear solver from PETSc for the Poisson equation on our
> numerical scheme and test this on a GPU cluster. So also, any guideline on
> how to interface PETSc with a fortran code and personal experience is also
> most appreciated!
> Marcos
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230515/a9bbd571/attachment-0001.html>
