[petsc-users] Issues creating DMPlex from higher order mesh generated by gmsh
Mon May 15 08:42:20 CDT 2023
On Mon, May 15, 2023 at 9:30 AM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Fri, May 5, 2023 at 10:55 AM Vilmer Dahlberg via petsc-users <
> > petsc-users at mcs.anl.gov> wrote:
> >> Hi.
> >> I'm trying to read a mesh of higher element order, in this example a
> mesh
> >> consisting of 10-node tetrahedral elements, from gmsh, into PETSC. But
> It
> >> looks like the mesh is not properly being loaded and converted into a
> >> DMPlex. gmsh tells me it has generated a mesh with 7087 nodes, but when
> I
> >> view my dm object it tells me it has 1081 0-cells. This is the printout
> I
> >> get
> > Hi Vilmer,
> > Plex makes a distinction between topological entities, like vertices,
> edges
> > and cells, and the function spaces used to represent fields, like
> velocity
> > or coordinates. When formats use "nodes", they mix the two concepts
> > together.
> > You see that if you add the number of vertices and edges, you get 7087,
> > since for P2 there is a "node" on every edge. Is anything else wrong?
> Note that quadratic (and higher order) tets are broken with the Gmsh
> reader. It's been on my todo list for a while.
> As an example, this works when using linear elements (the projection makes
> them quadratic and visualization is correct), but is tangled when holes.msh
> is quadratic.
> $ $PETSC_ARCH/tests/dm/impls/plex/tutorials/ex1 -dm_plex_filename
> ~/meshes/holes.msh -dm_view cgns:s.cgns -dm_coord_petscspace_degree 2
Projection to the continuous space is broken because we do not have the
lexicographic order on simplicies done. Are you sure you are projecting
into the broken space?
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230515/18e9f3be/attachment-0001.html>
