[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
Zongze Yang yangzongze at gmail.com
Sun May 14 08:20:58 CDT 2023
Hi, Matt,
The issue has been resolved while testing on the latest version of PETSc.
It seems that the problem has been fixed in the following merge request:
https://gitlab.com/petsc/petsc/-/merge_requests/5970
I sincerely apologize for any inconvenience caused by my previous message.
However, I would like to provide you with additional information regarding
the test files. Attached to this email, you will find two Gmsh files:
"square_2rd.msh" and "square_3rd.msh." These files contain high-order
triangulated mesh data for the unit square.
$ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh
-dm_plex_gmsh_project
-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true
-dm_plex_gmsh_project_fe_view -volume 1
PetscFE Object: P2 1 MPI process
  type: basic
  Basic Finite Element in 2 dimensions with 2 components
  PetscSpace Object: P2 1 MPI process
    type: sum
    Space in 2 variables with 2 components, size 12
    Sum space of 2 concatenated subspaces (all identical)
      PetscSpace Object: sum component (sumcomp_) 1 MPI process
        type: poly
        Space in 2 variables with 1 components, size 6
        Polynomial space of degree 2
  PetscDualSpace Object: P2 1 MPI process
    type: lagrange
    Dual space with 2 components, size 12
    Continuous Lagrange dual space
    Quadrature on a triangle of order 5 on 9 points (dim 2)
Volume: 1.
$ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh
PetscFE Object: P3 1 MPI process
  type: basic
  PetscSpace Object: P3 1 MPI process
    type: sum
    Space in 2 variables with 2 components, size 20
        type: poly
        Space in 2 variables with 1 components, size 10
        Polynomial space of degree 3
  PetscDualSpace Object: P3 1 MPI process
    type: lagrange
    Dual space with 2 components, size 20
    Quadrature on a triangle of order 7 on 16 points (dim 2)
Volume: 1.
Thank you for your attention and understanding. I apologize once again for
my previous oversight.
Best wishes,
Zongze
On Sun, 14 May 2023 at 16:44, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, May 13, 2023 at 6:08 AM Zongze Yang <yangzongze at gmail.com> wrote:
>> Hi, Matt,
>> There seem to be ongoing issues with projecting high-order coordinates
>> from a gmsh file to other spaces. I would like to inquire whether there are
>> any plans to resolve this problem.
>> Thank you for your attention to this matter.
> Yes, I will look at it. The important thing is to have a good test. Here
> are the higher order geometry tests
> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c
> I take shapes with known volume, mesh them with higher order geometry, and
> look at the convergence to the true volume. Could you add a GMsh test,
> meaning the .msh file and known volume, and I will fix it?
>   Thanks,
>      Matt
>> Best wishes,
>> Zongze
>> On Sat, 18 Jun 2022 at 20:31, Zongze Yang <yangzongze at gmail.com> wrote:
>>> Thank you for your reply. May I ask for some references on the order of
>>> the dofs on PETSc's FE Space (especially high order elements)?
>>> Thanks,
>>>  Zongze
>>> Matthew Knepley <knepley at gmail.com> 于2022年6月18日周六 20:02写道:
>>>> On Sat, Jun 18, 2022 at 2:16 AM Zongze Yang <yangzongze at gmail.com>
>>>> wrote:
>>>>> In order to check if I made mistakes in the python code, I try to use
>>>>> c code to show the issue on DMProjectCoordinates. The code and mesh file is
>>>>> attached.
>>>>> If the code is correct, there must be something wrong with
>>>>> `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh.
>>>> Something is definitely wrong with high order, periodic simplices from
>>>> Gmsh. We had not tested that case. I am at a conference and cannot look at
>>>> it for a week.
>>>> My suspicion is that the space we make when reading in the Gmsh
>>>> coordinates does not match the values (wrong order).
>>>>   Thanks,
>>>>     Matt
>>>>> The command and the output are listed below: (Obviously the bounding
>>>>> box is changed.)
>>>>> $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view -new_fe_view
>>>>> Old Bounding Box:
>>>>>   0: lo = 0. hi = 1.
>>>>>   1: lo = 0. hi = 1.
>>>>>   2: lo = 0. hi = 1.
>>>>> PetscFE Object: OldCoordinatesFE 1 MPI processes
>>>>>   type: basic
>>>>>   Basic Finite Element in 3 dimensions with 3 components
>>>>>   PetscSpace Object: P2 1 MPI processes
>>>>>     type: sum
>>>>>     Space in 3 variables with 3 components, size 30
>>>>>     Sum space of 3 concatenated subspaces (all identical)
>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI processes
>>>>>         type: poly
>>>>>         Space in 3 variables with 1 components, size 10
>>>>>   PetscDualSpace Object: P2 1 MPI processes
>>>>>     type: lagrange
>>>>>     Dual space with 3 components, size 30
>>>>>     Discontinuous Lagrange dual space
>>>>>     Quadrature of order 5 on 27 points (dim 3)
>>>>> PetscFE Object: NewCoordinatesFE 1 MPI processes
>>>>>   type: basic
>>>>>     type: sum
>>>>>         type: poly
>>>>>     type: lagrange
>>>>> New Bounding Box:
>>>>>   0: lo = 2.5624e-17 hi = 8.
>>>>>   1: lo = -9.23372e-17 hi = 7.
>>>>>   2: lo = 2.72091e-17 hi = 8.5
>>>>> Thanks,
>>>>> Zongze
>>>>> Zongze Yang <yangzongze at gmail.com> 于2022年6月17日周五 14:54写道:
>>>>>> I tried the projection operation. However, it seems that the
>>>>>> projection gives the wrong solution. After projection, the bounding box is
>>>>>> changed! See logs below.
>>>>>> First, I patch the petsc4py by adding `DMProjectCoordinates`:
>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>> b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>> index d8a58d183a..dbcdb280f1 100644
>>>>>> --- a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>> +++ b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>> @@ -307,6 +307,12 @@ cdef class DM(Object):
>>>>>>          PetscINCREF(c.obj)
>>>>>>          return c
>>>>>> +    def projectCoordinates(self, FE fe=None):
>>>>>> +        if fe is None:
>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, NULL) )
>>>>>> +        else:
>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, fe.fe) )
>>>>>>      def getBoundingBox(self):
>>>>>>          cdef PetscInt i,dim=0
>>>>>>          CHKERR( DMGetCoordinateDim(self.dm, &dim) )
>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>> b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>> index 514b6fa472..c778e39884 100644
>>>>>> --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>> +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>> @@ -90,6 +90,7 @@ cdef extern from * nogil:
>>>>>>      int DMGetCoordinateDim(PetscDM,PetscInt*)
>>>>>>      int DMSetCoordinateDim(PetscDM,PetscInt)
>>>>>>      int DMLocalizeCoordinates(PetscDM)
>>>>>> +    int DMProjectCoordinates(PetscDM, PetscFE)
>>>>>>      int DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*)
>>>>>>      int DMCreateInjection(PetscDM,PetscDM,PetscMat*)
>>>>>> Then in python, I load a mesh and project the coordinates to P2:
>>>>>> import firedrake as fd
>>>>>> from firedrake.petsc import PETSc
>>>>>> # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh')
>>>>>> plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
>>>>>> print('old bbox:', plex.getBoundingBox())
>>>>>> dim = plex.getDimension()
>>>>>> #                                 (dim,  nc, isSimplex, k,
>>>>>>  qorder, comm=None)
>>>>>> fe_new = PETSc.FE().createLagrange(dim, dim,      True, 2,
>>>>>> PETSc.DETERMINE)
>>>>>> plex.projectCoordinates(fe_new)
>>>>>> fe_new.view()
>>>>>> print('new bbox:', plex.getBoundingBox())
>>>>>> The output is (The bounding box is changed!)
>>>>>> old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0))
>>>>>> PetscFE Object: P2 1 MPI processes
>>>>>>   type: basic
>>>>>>     type: sum
>>>>>>         type: poly
>>>>>>     type: lagrange
>>>>>> new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224))
>>>>>> By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell?
>>>>>> Thanks!
>>>>>>   Zongze
>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月17日周五 01:11写道:
>>>>>>> On Thu, Jun 16, 2022 at 12:06 PM Zongze Yang <yangzongze at gmail.com>
>>>>>>> wrote:
>>>>>>>> 在 2022年6月16日,23:22,Matthew Knepley <knepley at gmail.com> 写道:
>>>>>>>> On Thu, Jun 16, 2022 at 11:11 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi, if I load a `gmsh` file with second-order elements, the
>>>>>>>>> coordinates will be stored in a DG-P2 space. After obtaining the
>>>>>>>>> coordinates of a cell, how can I map the coordinates to vertex and edge?
>>>>>>>> By default, they are stored as P2, not DG.
>>>>>>>> I checked the coordinates vector, and found the dogs only defined
>>>>>>>> on cell other than vertex and edge, so I said they are stored as DG.
>>>>>>>> Then the function DMPlexVecGetClosure
>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return
>>>>>>>> the coordinates in lex order.
>>>>>>>> Some code in reading gmsh file reads that
>>>>>>>> 1756:     if (isSimplex) continuity = PETSC_FALSE
>>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>; /* XXX
>>>>>>>> FIXME Requires DMPlexSetClosurePermutationLexicographic() */
>>>>>>>> 1758:     GmshCreateFE(comm, NULL, isSimplex, continuity,
>>>>>>>> nodeType, dim, coordDim, order, &fe)
>>>>>>>> The continuity is set to false for simplex.
>>>>>>> Oh, yes. That needs to be fixed. For now, you can just project it to
>>>>>>> P2 if you want using
>>>>>>>   https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thanks,
>>>>>>>> Zongze
>>>>>>>> You can ask for the coordinates of a vertex or an edge directly
>>>>>>>> using
>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/
>>>>>>>> by giving the vertex or edge point. You can get all the coordinates
>>>>>>>> on a cell, in the closure order, using
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Below is some code load the gmsh file, I want to know the relation
>>>>>>>>> between `cl` and `cell_coords`.
>>>>>>>>> import numpy as np
>>>>>>>>> # Load gmsh file (2rd)
>>>>>>>>> cs, ce = plex.getHeightStratum(0)
>>>>>>>>> cdm = plex.getCoordinateDM()
>>>>>>>>> csec = dm.getCoordinateSection()
>>>>>>>>> coords_gvec = dm.getCoordinates()
>>>>>>>>> for i in range(cs, ce):
>>>>>>>>>     cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
>>>>>>>>>     print(f'coordinates for cell {i} :\n{cell_coords.reshape([-1,
>>>>>>>>> 3])}')
>>>>>>>>>     cl = dm.getTransitiveClosure(i)
>>>>>>>>>     print('closure:', cl)
>>>>>>>>>     break
>>>>>>>>> Best wishes,
>>>>>>>>> Zongze
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230514/8e87f93e/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230514/8e87f93e/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230514/8e87f93e/attachment-0003.obj>
