[petsc-users] PCMG questions
Barry Smith bsmith at petsc.dev
Tue May 9 14:01:30 CDT 2023
> On May 9, 2023, at 12:32 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I have a MG hierarchy that I construct manually with DMRefine and DMPlexExtrude.
> * The solver works great with chevy/sor but with chevy/sor it converges slowly or I get indefinite PC errors from CG. And the eigen estimates in cheby are really high, like 10-15.
   So with Cheby/SOR it works great but with the exact same options Cheby/SOR it behaves poorly? Are you using  some quantum computer and NERSc?
> * I tried turning galerkin=none and I got this error.
  This is because without Garkin it needs to restrict the current solution and then compute the coarse grid Jacobian. Since you did not provide a DM that has the ability to even generate coarse grid vectors the process can work. You need a DM that can provide the coarse grid vectors and restrict solutions. Did you forget to pass a DM to the solver?
> Any thoughts on either of these issues?
> Thanks,
> Mark
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Must call DMShellSetGlobalVector() or DMShellSetCreateGlobalVector()
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-ksp_converged_reason (no value) source: command line
> [0]PETSC ERROR:   Option left: name:-mg_levels_esteig_ksp_type value: cg source: command line
> [0]PETSC ERROR:   Option left: name:-mg_levels_pc_type value: sor source: command line
> [0]PETSC ERROR:   Option left: name:-options_left (no value) source: command line
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.19.1-224-g9ed82936d20  GIT Date: 2023-05-07 12:33:48 -0400
> [0]PETSC ERROR: ./ex96 on a arch-macosx-gnu-O named MarksMac-302.local by markadams Tue May  9 12:26:52 2023
> [0]PETSC ERROR: Configure options CFLAGS="-g  -Wall" CXXFLAGS="-g  -Wall" COPTFLAGS=-O CXXOPTFLAGS=-O --with-cc=/usr/local/opt/llvm/bin/clang --with-cxx=/usr/local/opt/llvm/bin/clang++ --download-mpich --with-strict-petscerrorcode --download-triangle=1 --with-x=0 --with-debugging=0 --download-hdf5=1 PETSC_ARCH=arch-macosx-gnu-O
> [0]PETSC ERROR: #1 DMCreateGlobalVector_Shell() at /Users/markadams/Codes/petsc/src/dm/impls/shell/dmshell.c:210
> [0]PETSC ERROR: #2 DMCreateGlobalVector() at /Users/markadams/Codes/petsc/src/dm/interface/dm.c:1022
> [0]PETSC ERROR: #3 DMGetNamedGlobalVector() at /Users/markadams/Codes/petsc/src/dm/interface/dmget.c:377
> [0]PETSC ERROR: #4 DMRestrictHook_SNESVecSol() at /Users/markadams/Codes/petsc/src/snes/interface/snes.c:649
> [0]PETSC ERROR: #5 DMRestrict() at /Users/markadams/Codes/petsc/src/dm/interface/dm.c:3407
> [0]PETSC ERROR: #6 PCSetUp_MG() at /Users/markadams/Codes/petsc/src/ksp/pc/impls/mg/mg.c:1074
> [0]PETSC ERROR: #7 PCSetUp() at /Users/markadams/Codes/petsc/src/ksp/pc/interface/precon.c:994
> [0]PETSC ERROR: #8 KSPSetUp() at /Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c:406
> [0]PETSC ERROR: #9 KSPSolve_Private() at /Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c:824
> [0]PETSC ERROR: #10 KSPSolve() at /Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c:1070
> [0]PETSC ERROR: #11 SNESSolve_KSPONLY() at /Users/markadams/Codes/petsc/src/snes/impls/ksponly/ksponly.c:48
> [0]PETSC ERROR: #12 SNESSolve() at /Users/markadams/Codes/petsc/src/snes/interface/snes.c:4663
> [0]PETSC ERROR: #13 main() at ex96.c:433
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230509/008422f5/attachment.html>
