[petsc-users] Understanding index sets for PCGASM
LEONARDO MUTTI leonardo.mutti01 at universitadipavia.it
Tue May 9 09:02:00 CDT 2023
Great thanks! I can now successfully run
https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tests/ex71f.F90.
Going forward with my experiments, let me post a new code snippet (very
similar to  ex71f.F90) that I cannot get to work, probably I must be
setting up the IS objects incorrectly.
I have an 8x8 matrix A=diag(1,1,2,2,...,2) and a vector  b=(0.5,...,0.5).
We have only one processor, and I want to solve Ax=b using GASM. In
particular, KSP is set to preonly, GASM is the preconditioner and it uses
on each submatrix an lu direct solver (sub_ksp = preonly, sub_pc = lu).
For the GASM algorithm, I divide A into diag(1,1) and diag(2,2,...,2). For
simplicity I set 0 overlap. Now I want to use GASM to solve Ax=b. The code
follows.
#include <petsc/finclude/petscmat.h>
#include <petsc/finclude/petscksp.h>
#include <petsc/finclude/petscpc.h>
      USE petscmat
      USE petscksp
      USE petscpc
      USE MPI
      Mat   :: A
      Vec   :: b, x
      PetscInt :: M, I, J, ISLen, NSub
      PetscMPIInt :: size
      PetscErrorCode :: ierr
      PetscScalar :: v
      KSP            :: ksp
      PC             :: pc
      IS :: subdomains_IS(2), inflated_IS(2)
      PetscInt,DIMENSION(4) :: indices_first_domain
      PetscInt,DIMENSION(36) :: indices_second_domain
      call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
      call MPI_Comm_size(PETSC_COMM_WORLD, size, ierr)
      ! INTRO: create matrix and right hand side
      WRITE(*,*) "Assembling A,b"
      M = 8
      call MatCreateAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
     & M, M, PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,
     & PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,A, ierr)
      DO I=1,M
         DO J=1,M
            IF ((I .EQ. J) .AND. (I .LE. 2 )) THEN
               v = 1
            ELSE IF ((I .EQ. J) .AND. (I .GT. 2 )) THEN
               v = 2
            ELSE
               v = 0
            ENDIF
            call MatSetValue(A, I-1, J-1, v, INSERT_VALUES, ierr)
         END DO
      END DO
      call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
      call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
      call VecCreate(PETSC_COMM_WORLD,b,ierr)
      call VecSetSizes(b, PETSC_DECIDE, M,ierr)
      call VecSetFromOptions(b,ierr)
      do I=1,M
         v = 0.5
         call VecSetValue(b,I-1,v, INSERT_VALUES,ierr)
      end do
      call VecAssemblyBegin(b,ierr)
      call VecAssemblyEnd(b,ierr)
      ! FIRST KSP/PC SETUP
      WRITE(*,*) "KSP/PC first setup"
      call KSPCreate(PETSC_COMM_WORLD, ksp, ierr)
      call KSPSetOperators(ksp, A, A, ierr)
      call KSPSetType(ksp, 'preonly', ierr)
      call KSPGetPC(ksp, pc, ierr)
      call KSPSetUp(ksp, ierr)
      call PCSetType(pc, PCGASM, ierr)
      ! GASM, SETTING SUBDOMAINS
      WRITE(*,*) "Setting GASM subdomains"
      ! Let's create the subdomain IS and inflated_IS
      ! They are equal if no overlap is present
      ! They are 1: 0,1,8,9
      !          2: 10,...,15,18,...,23,...,58,...,63
      indices_first_domain = [0,1,8,9] ! corresponds to diag(1,1)
      do I=0,5
         do J=0,5
            indices_second_domain(I*6+1+J) = 18 + J + 8*I ! corresponds to
diag(2,2,...,2)
            !WRITE(*,*) I*6+1+J, 18 + J + 8*I
         end do
      end do
      ! Convert into IS
      ISLen = 4
      call ISCreateGeneral(PETSC_COMM_WORLD,ISLen,indices_first_domain,
     & PETSC_COPY_VALUES, subdomains_IS(1), ierr)
     & PETSC_COPY_VALUES, inflated_IS(1), ierr)
      ISLen = 36
      call ISCreateGeneral(PETSC_COMM_WORLD,ISLen,indices_second_domain,
     & PETSC_COPY_VALUES, subdomains_IS(2), ierr)
     & PETSC_COPY_VALUES, inflated_IS(2), ierr)
      NSub = 2
      call PCGASMSetSubdomains(pc,NSub,
     & subdomains_IS,inflated_IS,ierr)
      call PCGASMDestroySubdomains(NSub,
      ! GASM: SET SUBSOLVERS
      WRITE(*,*) "Setting subsolvers for GASM"
      call PCSetUp(pc, ierr) ! should I add this?
      call PetscOptionsSetValue(PETSC_NULL_OPTIONS,
     & "-sub_pc_type", "lu", ierr)
     & "-sub_ksp_type", "preonly", ierr)
      call KSPSetFromOptions(ksp, ierr)
      call PCSetFromOptions(pc, ierr)
      ! DUMMY SOLUTION: DID IT WORK?
      WRITE(*,*) "Solve"
      call VecDuplicate(b,x,ierr)
      call KSPSolve(ksp,b,x,ierr)
      call MatDestroy(A, ierr)
      call KSPDestroy(ksp, ierr)
      call PetscFinalize(ierr)
This code is failing in multiple points. At  call PCSetUp(pc, ierr) it
produces:
*[0]PETSC ERROR: Argument out of range*
*[0]PETSC ERROR: Scatter indices in ix are out of range*
*[0]PETSC ERROR: #1 VecScatterCreate() at
***\src\vec\is\sf\INTERF~1\vscat.c:736*
*[0]PETSC ERROR: #2 PCSetUp_GASM() at ***\src\ksp\pc\impls\gasm\gasm.c:433*
*[0]PETSC ERROR: #3 PCSetUp() at ***\src\ksp\pc\INTERF~1\precon.c:994*
And at call KSPSolve(ksp,b,x,ierr) it produces:
*forrtl: severe (157): Program Exception - access violation*
The index sets are setup coherently with the outputs of e.g.
https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/ksp/tests/output/ex71f_1.out:
in particular each element of the matrix A corresponds to a number from 0
to 63.
Note that each submatrix does not represent some physical subdomain, the
subdivision is just at the algebraic level.
I thus have the following questions:
   - is this the correct way of creating the IS objects, given my objective
   at the beginning of the email? Is the ordering correct?
   - what am I doing wrong that is generating the above errors?
Thanks for the patience and the time.
Best,
Leonardo
Il giorno ven 5 mag 2023 alle ore 18:43 Barry Smith <bsmith at petsc.dev> ha
scritto:
>   Added in *barry/2023-05-04/add-pcgasm-set-subdomains *see also
> https://gitlab.com/petsc/petsc/-/merge_requests/6419
>   Barry
> On May 4, 2023, at 11:23 AM, LEONARDO MUTTI <
> leonardo.mutti01 at universitadipavia.it> wrote:
> Thank you for the help.
> Adding to my example:
> *      call PCGASMSetSubdomains(pc,NSub, subdomains_IS, inflated_IS,ierr)
>     call PCGASMDestroySubdomains(NSub,subdomains_IS,inflated_IS,ierr)*
> results in:
> *      Error LNK2019 unresolved external symbol PCGASMDESTROYSUBDOMAINS
> referenced in function ...  *
> *      Error LNK2019 unresolved external symbol PCGASMSETSUBDOMAINS
> I'm not sure if the interfaces are missing or if I have a compilation
> problem.
> Thank you again.
> Best,
> Leonardo
> Il giorno sab 29 apr 2023 alle ore 20:30 Barry Smith <bsmith at petsc.dev>
> ha scritto:
>>    Thank you for the test code. I have a fix in the branch
>> barry/2023-04-29/fix-pcasmcreatesubdomains2d
>> <https://gitlab.com/petsc/petsc/-/commits/barry/2023-04-29/fix-pcasmcreatesubdomains2d> with
>> merge request https://gitlab.com/petsc/petsc/-/merge_requests/6394
>>    The functions did not have proper Fortran stubs and interfaces so I
>> had to provide them manually in the new branch.
>>    Use
>>    git fetch
>>    git checkout barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>    ./configure etc
>>    Your now working test code is in src/ksp/ksp/tests/ex71f.F90  I had to
>> change things slightly and I updated the error handling for the latest
>> version.
>>    Please let us know if you have any later questions.
>>   Barry
>> On Apr 28, 2023, at 12:07 PM, LEONARDO MUTTI <
>> Hello. I am having a hard time understanding the index sets to feed
>> PCGASMSetSubdomains, and I am working in Fortran (as a PETSc novice). To
>> get more intuition on how the IS objects behave I tried the following
>> minimal (non) working example, which should tile a 16x16 matrix into 16
>> square, non-overlapping submatrices:
>>       USE petscmat
>>       USE petscksp
>>       USE petscpc
>>       Mat   :: A
>>       PetscInt :: M, NSubx, dof, overlap, NSub
>>       INTEGER :: I,J
>>       PetscScalar :: v
>>       KSP            :: ksp
>>       PC             :: pc
>>       IS :: subdomains_IS, inflated_IS
>>       call PetscInitialize(PETSC_NULL_CHARACTER , ierr)
>> !-----Create a dummy matrix
>>       M = 16
>>       call MatCreateAIJ(MPI_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>      & M, M,
>>      & A, ierr)
>>       DO I=1,M
>>          DO J=1,M
>>             v = I*J
>>             CALL MatSetValue (A,I-1,J-1,v,
>>      &                     INSERT_VALUES , ierr)
>>          END DO
>>       END DO
>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY , ierr)
>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY , ierr)
>> !-----Create KSP and PC
>>       call KSPCreate(PETSC_COMM_WORLD,ksp, ierr)
>>       call KSPSetOperators(ksp,A,A, ierr)
>>       call KSPSetType(ksp,"bcgs",ierr)
>>       call KSPGetPC(ksp,pc,ierr)
>>       call PCSetType(pc,PCGASM, ierr)
>>       call PCSetUp(pc , ierr)
>> !-----GASM setup
>>       NSubx = 4
>>       dof = 1
>>       overlap = 0
>>       call PCGASMCreateSubdomains2D(pc,
>>      &      M, M,
>>      &      NSubx, NSubx,
>>      &      dof, overlap,
>>      &      NSub, subdomains_IS, inflated_IS, ierr)
>>       call ISView(subdomains_IS, PETSC_VIEWER_STDOUT_WORLD, ierr)
>> Running this on one processor, I get NSub = 4.
>> If PCASM and PCASMCreateSubdomains2D are used instead, I get NSub = 16 as
>> expected.
>> Moreover, I get in the end "forrtl: severe (157): Program Exception -
>> access violation". So:
>> 1) why do I get two different results with ASM, and GASM?
>> 2) why do I get access violation and how can I solve this?
>> In fact, in C, subdomains_IS, inflated_IS should pointers to IS objects.
>> As I see on the Fortran interface, the arguments to
>> PCGASMCreateSubdomains2D are IS objects:
>>        subroutine PCGASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,j,z)
>>        import tPC,tIS
>>        PC a ! PC
>>        PetscInt b ! PetscInt
>>        PetscInt c ! PetscInt
>>        PetscInt d ! PetscInt
>>        PetscInt e ! PetscInt
>>        PetscInt f ! PetscInt
>>        PetscInt g ! PetscInt
>>        PetscInt h ! PetscInt
>>        IS i ! IS
>>        IS j ! IS
>>        PetscErrorCode z
>>        end subroutine PCGASMCreateSubdomains2D
>> Thus:
>> 3) what should be inside e.g., subdomains_IS? I expect it to contain, for
>> every created subdomain, the list of rows and columns defining the subblock
>> in the matrix, am I right?
>> Context: I have a block-tridiagonal system arising from space-time finite
>> elements, and I want to solve it with GMRES+PCGASM preconditioner, where
>> each overlapping submatrix is on the diagonal and of size 3x3 blocks (and
>> spanning multiple processes). This is PETSc 3.17.1 on Windows.
>> Thanks in advance,
>> Leonardo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230509/3daf06a5/attachment-0001.html>
