[petsc-users] Question on ISLocalToGlobalMappingGetIndices Fortran Interface
Danyang Su danyang.su at gmail.com
Mon May 8 17:50:09 CDT 2023
Dear PETSc-Users,
Is there any changes in ISLocalToGlobalMappingGetIndices function after PETSc 3.17?
In the previous PETSc version (<= 3.17), the function ‘ISLocalToGlobalMappingGetIndices(ltogm,ltog,idltog,ierr)’ works fine, even though the value of idltog looks out of bound (-11472655627481), https://www.mcs.anl.gov/petsc/petsc-3.14/src/ksp/ksp/tutorials/ex14f.F90.html. The value of idltog is not clear.
In the latest PETSc version,  this function can be called, but due to the extreme value of idltog, the code fails. I also tried to use ‘ISLocalToGlobalMappingGetIndicesF90(ltogm,ltog,ierr)’ () but no success.
#if (PETSC_VERSION_MAJOR == 3 && PETSC_VERSION_MINOR <= 4)
        call DMDAGetGlobalIndicesF90(dmda_flow%da,PETSC_NULL_INTEGER,  &
                                     idx,ierr)
        CHKERRQ(ierr)
#else
        call DMGetLocalToGlobalMapping(dmda_flow%da,ltogm,ierr)
        CHKERRQ(ierr)
        call ISLocalToGlobalMappingGetIndices(ltogm,ltog,idltog,ierr)
        CHKERRQ(ierr)
#endif
        dof = dmda_flow%dof
        do ivol = 1, nngl
            node_idx_lg2pg(ivol) = (idx(ivol*dof)+1)/dof
#else
            node_idx_lg2pg(ivol) = (ltog(ivol*dof + idltog)+1)/dof
#endif
        end do
Any suggestions on that.
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230508/eeff948e/attachment.html>
