[petsc-users] Scalable Solver for Incompressible Flow
Mon May 8 06:42:09 CDT 2023
On Mon, May 8, 2023 at 7:27 AM Mark Adams <mfadams at lbl.gov> wrote:
> On Mon, May 8, 2023 at 2:32 AM Sebastian Blauth <
> sebastian.blauth at itwm.fraunhofer.de> wrote:
>> Hello everyone,
>> I wanted to briefly follow up on my question (see my last reply).
>> Does anyone know / have an idea why the LSC preconditioner in PETSc does
>> not seem to scale well with the problem size (the outer fgmres solver I
>> am using nearly scale nearly linearly with the problem size in my
>> example).
>> I have also already tried using -ksp_diagonal_scale but the results are
>> identical.
>> Any help is really appreciated.
> I would start by finding results in the literature that you like, in that
> they are on a problem similar to yours and you like the performance, and
> reproduce them in your code.
> If you can do that then you have a research problem to see how to get your
> problem to work well.
> If your solver does not reproduce published results then we might be
> able to provide some advice.
I have not seen LSC scale well. The only thing I have seen to actually work
is patch smoothing (I gave a paper reference). It could
be that we have a bug in LSC, but I thought we verified it with the
Shuttleworth paper.
  THanks,
     Matt
> Mark
>> Thanks a lot,
>> Sebastian
>> On 03.05.2023 09:07, Sebastian Blauth wrote:
>> > First of all, yes you are correct that I am trying to solve the
>> > stationary incompressible Navier Stokes equations.
>> > On 02.05.2023 21:33, Matthew Knepley wrote:
>> >> On Tue, May 2, 2023 at 2:29 PM Jed Brown <jed at jedbrown.org
>> >> <mailto:jed at jedbrown.org>> wrote:
>> >>     Sebastian Blauth <sebastian.blauth at itwm.fraunhofer.de
>> >>     <mailto:sebastian.blauth at itwm.fraunhofer.de>> writes:
>> >>      > I agree with your comment for the Stokes equations - for these,
>> I
>> >>     have
>> >>      > already tried and used the pressure mass matrix as part of a
>> >>     (additive)
>> >>      > block preconditioner and it gave mesh independent results.
>> >>      > However, for the Navier Stokes equations, is the Schur
>> complement
>> >>     really
>> >>      > spectrally equivalent to the pressure mass matrix?
>> >>     No, it's not. You'd want something like PCD (better, but not
>> >>     algebraic) or LSC.
>> > I would like to take a look at the LSC preconditioner. For this, I did
>> > also not achieve mesh-independent results. I am using the following
>> > options (I know that the tolerances are too high at the moment, but it
>> > should just illustrate the behavior w.r.t. mesh refinement). Again, I
>> am
>> > using a simple 2D channel problem for testing purposes.
>> > I am using the following options
>> > -ksp_type fgmres
>> > -ksp_gmres_restart 100
>> > -ksp_gmres_cgs_refinement_type refine_ifneeded
>> > -ksp_max_it 1000
>> > -ksp_rtol 1e-10
>> > -ksp_atol 1e-30
>> > -pc_type fieldsplit
>> > -pc_fieldsplit_type schur
>> > -pc_fieldsplit_schur_fact_type full
>> > -pc_fieldsplit_schur_precondition self
>> > -fieldsplit_0_ksp_type preonly
>> > -fieldsplit_0_pc_type lu
>> > -fieldsplit_1_ksp_type gmres
>> > -fieldsplit_1_ksp_pc_side right
>> > -fieldsplit_1_ksp_gmres_restart 100
>> > -fieldsplit_1_ksp_gmres_cgs_refinement_type refine_ifneeded
>> > -fieldsplit_1_ksp_max_it 1000
>> > -fieldsplit_1_ksp_rtol 1e-10
>> > -fieldsplit_1_ksp_atol 1e-30
>> > -fieldsplit_1_pc_type lsc
>> > -fieldsplit_1_lsc_ksp_type preonly
>> > -fieldsplit_1_lsc_pc_type lu
>> > -fieldsplit_1_ksp_converged_reason
>> > Again, the direct solvers are used so that only the influence of the
>> LSC
>> > preconditioner is seen. I have suitable preconditioners for all of
>> these
>> > available (using boomeramg).
>> > At the bottom, I attach the output for different discretizations. As
>> you
>> > can see there, the number of iterations increases nearly linearly with
>> > the problem size.
>> > I think that the problem could occur due to a wrong scaling. In your
>> > docs https://petsc.org/release/manualpages/PC/PCLSC/ , you write that
>> > the LSC preconditioner is implemented as
>> >     inv(S) \approx inv(A10 A01) A10 A00 A01 inv(A10 A01)
>> > However, in the book of Elman, Sylvester and Wathen (Finite Elements
>> and
>> > Fast Iterative Solvers), the LSC preconditioner is defined as
>> >      inv(S) \approx inv(A10 inv(T) A01) A10 inv(T) A00 inv(T) A01
>> > inv(A10 inv(T) A01)
>> > where T = diag(Q) and Q is the velocity mass matrix.
>> > There is an options -pc_lsc_scale_diag, which states that it uses the
>> > diagonal of A for scaling. I suppose, that this means, that the
>> diagonal
>> > of the A00 block is used for scaling - however, this is not the right
>> > scaling, is it? Even in the source code for the LSC preconditioner, in
>> > /src/ksp/pc/impls/lsc/lsc.c it is mentioned, that a mass matrix should
>> > be used...
>> > Is there any way to implement this in PETSc? Maybe by supplying the
>> mass
>> > matrix as Pmat?
>> > Thanks a lot in advance,
>> > Sebastian
>> >> I think you can do a better job than that using something like
>> >> https://arxiv.org/abs/1810.03315 <https://arxiv.org/abs/1810.03315>
>> >> Basically, you use an augmented Lagrangian thing to make the Schur
>> >> complement well-conditioned,
>> >> and then use a special smoother to handle that perturbation.
>> >>      > And even if it is, the convergence is only good for small
>> >>     Reynolds numbers, for moderately high ones the convergence really
>> >>     deteriorates. This is why I am trying to make
>> >>     fieldsplit_schur_precondition selfp work better (this is, if I
>> >>     understand it correctly, a SIMPLE type preconditioner).
>> >>     SIMPLE is for short time steps (not too far from resolving CFL) and
>> >>     bad for steady. This taxonomy is useful, though the problems are
>> >>     super academic and they don't use high aspect ratio.
>> > Okay, I get that I cannot expect the SIMPLE preconditioning
>> > (schur_precondition selfp) to work efficiently. I guess the reason it
>> > works for small time steps (for the instationary equations) is that the
>> > velocity block becomes diagonally dominant in this case, so that
>> diag(A)
>> > is a good approximation of A.
>> >>     https://doi.org/10.1016/j.jcp.2007.09.026
>> >>     <https://doi.org/10.1016/j.jcp.2007.09.026>
>> >>     Thanks,
>> >>        Matt
>> >> What most experimenters take for granted before they begin their
>> >> experiments is infinitely more interesting than any results to which
>> >> their experiments lead.
>> >> -- Norbert Wiener
>> >> https://www.cse.buffalo.edu/~knepley/
>> >> <http://www.cse.buffalo.edu/~knepley/>
>> > And here is the output of my scaling tests
>> > 8x8 discretization
>> > Newton solver:  iter,  abs. residual (abs. tol),  rel. residual (rel.
>> tol)
>> > Newton solver:     0,      1.023e+03 (1.00e-30),      1.000e+00
>> (1.00e-10)
>> >    Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL
>> iterations 38
>> > Newton solver:     1,      1.313e+03 (1.00e-30),      1.283e+00
>> (1.00e-10)
>> iterations 76
>> > Newton solver:     2,      1.198e+02 (1.00e-30),      1.171e-01
>> (1.00e-10)
>> iterations 74
>> > Newton solver:     3,      7.249e-01 (1.00e-30),      7.084e-04
>> (1.00e-10)
>> iterations 74
>> > Newton solver:     4,      3.883e-05 (1.00e-30),      3.795e-08
>> (1.00e-10)
>> iterations 74
>> > Newton solver:     5,      2.778e-12 (1.00e-30),      2.714e-15
>> (1.00e-10)
>> > 16x16 discretization
>> tol)
>> > Newton solver:     0,      1.113e+03 (1.00e-30),      1.000e+00
>> (1.00e-10)
>> iterations 62
>> > Newton solver:     1,      8.316e+02 (1.00e-30),      7.475e-01
>> (1.00e-10)
>> iterations
>> > 141
>> > Newton solver:     2,      5.806e+01 (1.00e-30),      5.218e-02
>> (1.00e-10)
>> iterations
>> > 119
>> > Newton solver:     3,      3.309e-01 (1.00e-30),      2.974e-04
>> (1.00e-10)
>> iterations
>> > 118
>> > Newton solver:     4,      9.085e-06 (1.00e-30),      8.166e-09
>> (1.00e-10)
>> iterations
>> > 120
>> > Newton solver:     5,      3.475e-12 (1.00e-30),      3.124e-15
>> (1.00e-10)
>> > 32x32 discretization
>> tol)
>> > Newton solver:     0,      1.330e+03 (1.00e-30),      1.000e+00
>> (1.00e-10)
>> iterations 98
>> > Newton solver:     1,      5.913e+02 (1.00e-30),      4.445e-01
>> (1.00e-10)
>> iterations
>> > 183
>> > Newton solver:     2,      3.214e+01 (1.00e-30),      2.416e-02
>> (1.00e-10)
>> iterations
>> > 152
>> > Newton solver:     3,      2.059e-01 (1.00e-30),      1.547e-04
>> (1.00e-10)
>> iterations
>> > 151
>> > Newton solver:     4,      6.949e-06 (1.00e-30),      5.223e-09
>> (1.00e-10)
>> iterations
>> > 149
>> > Newton solver:     5,      5.300e-12 (1.00e-30),      3.983e-15
>> (1.00e-10)
>> > 64x64 discretization
>> tol)
>> > Newton solver:     0,      1.707e+03 (1.00e-30),      1.000e+00
>> (1.00e-10)
>> iterations
>> > 198
>> > Newton solver:     1,      4.259e+02 (1.00e-30),      2.494e-01
>> (1.00e-10)
>> iterations
>> > 357
>> > Newton solver:     2,      1.706e+01 (1.00e-30),      9.993e-03
>> (1.00e-10)
>> iterations
>> > 266
>> > Newton solver:     3,      1.134e-01 (1.00e-30),      6.639e-05
>> (1.00e-10)
>> iterations
>> > 261
>> > Newton solver:     4,      4.285e-06 (1.00e-30),      2.510e-09
>> (1.00e-10)
>> iterations
>> > 263
>> > Newton solver:     5,      9.650e-12 (1.00e-30),      5.652e-15
>> (1.00e-10)
>> Dr. Sebastian Blauth
>> Fraunhofer-Institut für
>> Techno- und Wirtschaftsmathematik ITWM
>> Abteilung Transportvorgänge
>> Fraunhofer-Platz 1, 67663 Kaiserslautern
>> Telefon: +49 631 31600-4968
>> www.itwm.fraunhofer.de
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230508/b3f48660/attachment.html>
