[petsc-users] Fortran preprocessor not work in pets-dev
Danyang Su danyang.su at gmail.com
Sat May 6 19:12:27 CDT 2023
Hi All,
My code has some FPP. It works fine in PETSc 3.18 and earlier version, but stops working in the latest PETSc-Dev. For example the following FPP STANDARD_FORTRAN is not recognized.
#ifdef STANDARD_FORTRAN
    1 format(15x,1000a15)
    2 format(1pe15.6e3,1000(1pe15.6e3))
#else
    1 format(15x,<ncol>a15)
    2 format(1pe15.6e3,<ncol>(1pe15.6e3))
#endif
In the makefile, I define the preprocessor as PPFLAGS.
PPFLAGS := -DLINUX -DRELEASE -DRELEASE_X64 -DSTANDARD_FORTRAN
exe: $(OBJS) chkopts
                -${FLINKER} $(FFLAGS) $(FPPFLAGS) $(CPPFLAGS) -o $(EXENAME) $(OBJS) ${PETSC_LIB} ${LIS_LIB} ${DLIB} ${SLIB}
Any idea on this problem?
All the best,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230506/0be36012/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230506/0be36012/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230506/0be36012/attachment-0003.obj>
