[petsc-users] Step size setting in TS
Jorti, Zakariae zjorti at lanl.gov
Sat May 6 18:24:59 CDT 2023
Hello,
I have a time-dependent model that I solve using TSSolve.
And I am trying to adaptively change the step size (dt).
I found that there are some TSAdapt schemes already available.
I have tried TSADAPTBASIC and TSADAPTCFL.
The former runs without any problems, whereas the latter yields the following error:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Step rejection not implemented. The CFL implementation is incomplete/unusable
How/where the step rejection should be implemented? Are there any examples available?
Besides, I was also attempting to change the step size through the monitor:
 SNES snes;
  TSGetSNES(ts, & snes);
  SNESConvergedReason reason = SNES_CONVERGED_ITERATING;
  PetscCall(SNESGetConvergedReason(snes, &reason));
  if(reason < 0){
    TSSetTimeStep(ts,28618.7);
  else{
    TSSetTimeStep(ts,57237.4);
But when I try this solution, the TSStep seems to diverge even though the SNES solver converges (see log file below).
Am I doing something wrong here by changing the value of the step size inside the monitor?
Thank you.
Best,
Zakariae
Timestep   0: step size = 57237.4, time = 0.,
    0 SNES Function norm 2.854104379157e-02
      0 KSP Residual norm 2.854104379157e-02
      1 KSP Residual norm 8.393431982129e-04
    Linear solve converged due to CONVERGED_RTOL iterations 1
      0 KSP Residual norm 1.985106864162e-01
      1 KSP Residual norm 2.509248490095e-04
    1 SNES Function norm 1.985106864162e-01
      1 KSP Residual norm 2.739697200542e-04
      0 KSP Residual norm 1.885623182909e-01
      1 KSP Residual norm 8.784869181255e-04
      0 KSP Residual norm 1.664114929279e-01
      1 KSP Residual norm 2.277701872167e-04
    2 SNES Function norm 1.664114929279e-01
      1 KSP Residual norm 2.062369048201e-04
      0 KSP Residual norm 6.155996487462e-02
      1 KSP Residual norm 8.830688649637e-05
    3 SNES Function norm 6.155996487462e-02
      1 KSP Residual norm 6.231091742747e-05
      0 KSP Residual norm 1.828806540636e-02
      1 KSP Residual norm 3.623270770725e-05
    4 SNES Function norm 1.828806540636e-02
      1 KSP Residual norm 7.390325185746e-05
      0 KSP Residual norm 1.659571588896e-02
      1 KSP Residual norm 5.280284947190e-05
    5 SNES Function norm 1.659571588896e-02
      1 KSP Residual norm 8.311611006756e-05
      0 KSP Residual norm 1.475636107890e-02
      1 KSP Residual norm 1.890387034462e-04
      0 KSP Residual norm 1.635129206894e-02
      1 KSP Residual norm 8.192897103059e-05
    6 SNES Function norm 1.635129206894e-02
      1 KSP Residual norm 9.049749505225e-04
      0 KSP Residual norm 1.634946381608e-02
      1 KSP Residual norm 9.038879304284e-04
      0 KSP Residual norm 1.635085731721e-02
      1 KSP Residual norm 9.050535714933e-04
    7 SNES Function norm 1.635085731721e-02
      1 KSP Residual norm 1.248783858778e-03
      0 KSP Residual norm 1.635003937816e-02
      1 KSP Residual norm 1.248746884526e-03
    8 SNES Function norm 1.635003937816e-02
      1 KSP Residual norm 1.631242803481e-02
      2 KSP Residual norm 1.551854905139e-02
      3 KSP Residual norm 7.586491369138e-03
      4 KSP Residual norm 2.304721992110e-04
    Linear solve converged due to CONVERGED_RTOL iterations 4
      0 KSP Residual norm 1.635003936717e-02
      1 KSP Residual norm 1.631242801091e-02
      2 KSP Residual norm 1.551784322549e-02
      3 KSP Residual norm 7.706018759197e-03
      4 KSP Residual norm 2.652435205967e-04
    9 SNES Function norm 1.282692400720e+06
  Nonlinear solve did not converge due to DIVERGED_DTOL iterations 9
      1 KSP Residual norm 5.698410682663e-04
      0 KSP Residual norm 8.618385788411e-02
      1 KSP Residual norm 9.179214337527e-05
    1 SNES Function norm 8.618385788411e-02
      1 KSP Residual norm 9.659611612697e-05
      0 KSP Residual norm 2.763975792565e-02
      1 KSP Residual norm 2.674728432525e-05
    2 SNES Function norm 2.763975792565e-02
      1 KSP Residual norm 1.836844517206e-05
      0 KSP Residual norm 2.773540750989e-03
      1 KSP Residual norm 1.340353004310e-05
    3 SNES Function norm 2.773540750989e-03
      1 KSP Residual norm 5.382019472069e-06
      0 KSP Residual norm 3.441017533038e-04
      1 KSP Residual norm 5.218147408275e-07
    4 SNES Function norm 3.441017533038e-04
      1 KSP Residual norm 4.811955757758e-07
      0 KSP Residual norm 3.991606932979e-06
      1 KSP Residual norm 8.670005394864e-09
    5 SNES Function norm 3.991606932979e-06
      1 KSP Residual norm 8.920137762569e-09
      0 KSP Residual norm 7.982782045945e-10
      1 KSP Residual norm 3.185856555648e-12
    6 SNES Function norm 7.982782045945e-10
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 6
    0 SNES Function norm 3.475518085003e-04
      0 KSP Residual norm 3.475518085003e-04
      1 KSP Residual norm 2.328087365783e-04
      2 KSP Residual norm 5.062641920970e-09
    Linear solve converged due to CONVERGED_RTOL iterations 2
      0 KSP Residual norm 3.256441726122e-02
      1 KSP Residual norm 8.957860841275e-05
    1 SNES Function norm 3.256441726122e-02
      1 KSP Residual norm 5.886144296665e-05
      0 KSP Residual norm 4.876417342600e-03
      1 KSP Residual norm 5.064113356579e-06
    2 SNES Function norm 4.876417342600e-03
      1 KSP Residual norm 7.010281488349e-06
      0 KSP Residual norm 6.144574635801e-04
      1 KSP Residual norm 9.768499579865e-07
    3 SNES Function norm 6.144574635801e-04
      1 KSP Residual norm 8.324370478600e-07
      0 KSP Residual norm 8.721913471286e-06
      1 KSP Residual norm 1.370545428753e-08
    4 SNES Function norm 8.721913471286e-06
      1 KSP Residual norm 1.353680905072e-08
      0 KSP Residual norm 3.399977638261e-09
      1 KSP Residual norm 5.989016835446e-12
    5 SNES Function norm 3.399977638261e-09
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 5
      1 KSP Residual norm 1.733028652796e-04
      0 KSP Residual norm 7.490800616133e-03
      1 KSP Residual norm 8.231034393757e-06
    1 SNES Function norm 7.490800616133e-03
      1 KSP Residual norm 8.349300836114e-06
      0 KSP Residual norm 1.394207859364e-04
      1 KSP Residual norm 5.991798196295e-08
    2 SNES Function norm 1.394207859364e-04
      1 KSP Residual norm 5.941984242417e-08
      0 KSP Residual norm 2.985895331367e-08
      1 KSP Residual norm 1.522240176483e-11
    3 SNES Function norm 2.985895331367e-08
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 3
    0 SNES Function norm 1.026110861069e-03
      0 KSP Residual norm 1.026110861069e-03
      1 KSP Residual norm 1.768297003974e-04
      0 KSP Residual norm 7.742520550463e-03
      1 KSP Residual norm 4.379214132544e-06
    1 SNES Function norm 7.742520550463e-03
      1 KSP Residual norm 4.526371657285e-06
      0 KSP Residual norm 2.574467856482e-05
      1 KSP Residual norm 2.285626422848e-08
    2 SNES Function norm 2.574467856482e-05
      1 KSP Residual norm 2.274220735999e-08
      0 KSP Residual norm 4.797870687759e-09
      1 KSP Residual norm 2.841037171618e-12
    3 SNES Function norm 4.797870687759e-09
      1 KSP Residual norm 5.979305049211e-05
      0 KSP Residual norm 8.195748548281e-04
      1 KSP Residual norm 1.017772307359e-06
    1 SNES Function norm 8.195748548281e-04
      1 KSP Residual norm 1.026961867317e-06
      0 KSP Residual norm 1.717269750886e-06
      1 KSP Residual norm 4.675717893044e-10
    2 SNES Function norm 1.717269750886e-06
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
    0 SNES Function norm 1.325295461903e-03
      0 KSP Residual norm 1.325295461903e-03
      1 KSP Residual norm 7.421950279125e-05
      0 KSP Residual norm 1.330639207844e-03
      1 KSP Residual norm 3.764830059967e-07
    1 SNES Function norm 1.330639207844e-03
      1 KSP Residual norm 3.764587772248e-07
      0 KSP Residual norm 2.146996236879e-07
      1 KSP Residual norm 1.459926588396e-10
    2 SNES Function norm 2.146996236879e-07
      1 KSP Residual norm 1.470407475325e-10
      0 KSP Residual norm 2.171052440924e-11
      1 KSP Residual norm 1.397958787200e-15
    3 SNES Function norm 2.171052440924e-11
      1 KSP Residual norm 3.067250018894e-05
      0 KSP Residual norm 1.608120509564e-04
      1 KSP Residual norm 2.171575389779e-07
    1 SNES Function norm 1.608120509564e-04
      1 KSP Residual norm 2.240227170220e-07
      0 KSP Residual norm 9.106906778906e-08
      1 KSP Residual norm 1.799636201836e-11
    2 SNES Function norm 9.106906778906e-08
    0 SNES Function norm 1.418151440967e-03
      0 KSP Residual norm 1.418151440967e-03
      1 KSP Residual norm 3.515151918636e-05
      0 KSP Residual norm 2.938727941997e-04
      1 KSP Residual norm 6.040565904176e-08
    1 SNES Function norm 2.938727941997e-04
      1 KSP Residual norm 6.089297895562e-08
      0 KSP Residual norm 1.093551284505e-08
      1 KSP Residual norm 2.891462873664e-12
    2 SNES Function norm 1.093551284505e-08
      1 KSP Residual norm 2.050867218313e-05
      0 KSP Residual norm 3.054570961709e-05
      1 KSP Residual norm 4.596885059357e-08
    1 SNES Function norm 3.054570961709e-05
      1 KSP Residual norm 4.828909801995e-08
      0 KSP Residual norm 1.248104282690e-08
      1 KSP Residual norm 8.831951540120e-13
    2 SNES Function norm 1.248104282690e-08
    0 SNES Function norm 1.460190420374e-03
      0 KSP Residual norm 1.460190420374e-03
      1 KSP Residual norm 1.580519450452e-05
      0 KSP Residual norm 5.884986293527e-05
      1 KSP Residual norm 9.020937669734e-09
    1 SNES Function norm 5.884986293527e-05
      1 KSP Residual norm 9.054367061995e-09
      0 KSP Residual norm 1.698647259662e-09
      1 KSP Residual norm 1.767366286599e-13
    2 SNES Function norm 1.698647259662e-09
      1 KSP Residual norm 1.834492501580e-05
      0 KSP Residual norm 5.663374849972e-06
      1 KSP Residual norm 9.752865227095e-09
    1 SNES Function norm 5.663374849972e-06
      1 KSP Residual norm 1.014567990183e-08
      0 KSP Residual norm 2.600155584863e-09
      1 KSP Residual norm 8.580477366667e-14
    2 SNES Function norm 2.600155584863e-09
    0 SNES Function norm 1.479145244919e-03
      0 KSP Residual norm 1.479145244919e-03
      1 KSP Residual norm 6.804553002336e-06
      0 KSP Residual norm 1.118291636442e-05
      1 KSP Residual norm 1.397149309582e-09
    1 SNES Function norm 1.118291636442e-05
      1 KSP Residual norm 1.386385106529e-09
      0 KSP Residual norm 2.800461695540e-10
      1 KSP Residual norm 3.217319587127e-14
    2 SNES Function norm 2.800461695540e-10
      1 KSP Residual norm 1.776151497065e-05
      0 KSP Residual norm 1.076105708636e-06
      1 KSP Residual norm 2.155085223926e-09
    1 SNES Function norm 1.076105708636e-06
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
    0 SNES Function norm 1.489507915803e-03
      0 KSP Residual norm 1.489507915803e-03
      1 KSP Residual norm 2.921538148329e-06
      0 KSP Residual norm 2.172405782412e-06
      1 KSP Residual norm 2.719699969205e-10
    1 SNES Function norm 2.172405782412e-06
      1 KSP Residual norm 2.731813669182e-10
      0 KSP Residual norm 5.323734019212e-11
      1 KSP Residual norm 6.095298326433e-15
    2 SNES Function norm 5.323734019212e-11
      1 KSP Residual norm 1.746846293829e-05
      0 KSP Residual norm 2.376406135686e-07
      1 KSP Residual norm 5.310287317591e-10
    1 SNES Function norm 2.376406135686e-07
    0 SNES Function norm 1.497239199277e-03
      0 KSP Residual norm 1.497239199277e-03
      1 KSP Residual norm 1.251830706962e-06
      0 KSP Residual norm 5.023668872625e-07
      1 KSP Residual norm 7.656373075632e-11
    1 SNES Function norm 5.023668872625e-07
      1 KSP Residual norm 7.473091471413e-11
      0 KSP Residual norm 2.003331377435e-11
      1 KSP Residual norm 1.347408932811e-15
    2 SNES Function norm 2.003331377435e-11
      1 KSP Residual norm 1.757419385096e-05
      0 KSP Residual norm 7.310279661922e-08
      1 KSP Residual norm 1.417918576189e-10
    1 SNES Function norm 7.310279661922e-08
    0 SNES Function norm 1.503392083665e-03
      0 KSP Residual norm 1.503392083665e-03
      1 KSP Residual norm 5.327548050375e-07
      0 KSP Residual norm 1.611770751552e-07
      1 KSP Residual norm 2.611036263545e-11
    1 SNES Function norm 1.611770751552e-07
      1 KSP Residual norm 2.607692240234e-11
      0 KSP Residual norm 1.627978707015e-11
      1 KSP Residual norm 4.254078683385e-16
    2 SNES Function norm 1.627978707015e-11
      1 KSP Residual norm 1.747957348554e-05
      0 KSP Residual norm 2.999731614900e-08
      1 KSP Residual norm 3.643836796648e-11
    1 SNES Function norm 2.999731614900e-08
    0 SNES Function norm 1.507740473908e-03
      0 KSP Residual norm 1.507740473908e-03
      1 KSP Residual norm 2.263876724496e-07
      0 KSP Residual norm 6.390049329095e-08
      1 KSP Residual norm 9.745723464126e-12
    1 SNES Function norm 6.390049329095e-08
[0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230506/7f40cba2/attachment-0001.html>
