[petsc-users] Understanding index sets for PCGASM
Fri May 5 04:28:13 CDT 2023
On Fri, May 5, 2023 at 2:45 AM LEONARDO MUTTI <
leonardo.mutti01 at universitadipavia.it> wrote:
> Interesting, a priori I'm not sure this will work better, mainly because
> I'd lose the compact band structure.
> As for waveform relaxation: I excluded it at first since it appears to be
> requiring too many CPUs than I have to beat sequential solvers, plus it is
> more complicated and I have very limited time at this project.
> For both suggestions, because of the way the space-time matrix is
> generated, it is much more convenient for me to mess with the time
> dimension than with space.
> Overall GASM seems a simpler way to go before trying other things.
> Please let me know if you decide to add the GASM interfaces.
We will add them. It might take until the end of classes this term.
    Matt
> Thanks again.
> Best,
> Leonardo
> Il ven 5 mag 2023, 00:01 Matthew Knepley <knepley at gmail.com> ha scritto:
>> On Thu, May 4, 2023 at 1:43 PM LEONARDO MUTTI <
>>> Of course, I'll try to explain.
>>> I am solving a parabolic equation with space-time FEM and I want an
>>> efficient solver/preconditioner for the resulting system.
>>> The corresponding matrix, call it X, has an e.g. block bi-diagonal
>>> structure, if the cG(1)-dG(0) method is used (i.e. implicit Euler solved in
>>> batch).
>>> Every block-row of X corresponds to a time instant.
>>> I want to introduce parallelism in time by subdividing X into
>>> overlapping submatrices of e.g 2x2 or 3x3 blocks, along the block diagonal.
>>> For instance, call X_i the individual blocks. The submatrices would be,
>>> for various i, (X_{i-1,i-1},X_{i-1,i};X_{i,i-1},X_{i,i}).
>>> I'd like each submatrix to be solved in parallel, to combine the various
>>> results together in an ASM like fashion.
>>> Every submatrix has thus a predecessor and a successor, and it overlaps
>>> with both, so that as far as I could understand, GASM has to be used in
>>> place of ASM.
>> Yes, ordered that way you need GASM. I wonder if inverting the ordering
>> would be useful, namely putting the time index on the inside.
>> Then the blocks would be over all time, but limited space, which is more
>> the spirit of ASM I think.
>> Have you considered waveform relaxation for this problem?
>>    Thanks,
>>      Matt
>>> Hope this helps.
>>> Best,
>>> Leonardo
>>> Il giorno gio 4 mag 2023 alle ore 18:05 Matthew Knepley <
>>>> On Thu, May 4, 2023 at 11:24 AM LEONARDO MUTTI <
>>>>> Thank you for the help.
>>>>> Adding to my example:
>>>>> *      call PCGASMSetSubdomains(pc,NSub, subdomains_IS,
>>>>> inflated_IS,ierr)      call
>>>>> PCGASMDestroySubdomains(NSub,subdomains_IS,inflated_IS,ierr)*
>>>>> results in:
>>>>> *      Error LNK2019 unresolved external symbol
>>>>> PCGASMDESTROYSUBDOMAINS referenced in function ...  *
>>>>> *      Error LNK2019 unresolved external symbol PCGASMSETSUBDOMAINS
>>>>> I'm not sure if the interfaces are missing or if I have a compilation
>>>>> problem.
>>>> I just want to make sure you really want GASM. It sounded like you
>>>> might able to do what you want just with ASM.
>>>> Can you tell me again what you want to do overall?
>>>>   Thanks,
>>>>     Matt
>>>>> Thank you again.
>>>>> Best,
>>>>> Leonardo
>>>>> Il giorno sab 29 apr 2023 alle ore 20:30 Barry Smith <bsmith at petsc.dev>
>>>>> ha scritto:
>>>>>>    Thank you for the test code. I have a fix in the branch
>>>>>> barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>>> <https://gitlab.com/petsc/petsc/-/commits/barry/2023-04-29/fix-pcasmcreatesubdomains2d> with
>>>>>> merge request https://gitlab.com/petsc/petsc/-/merge_requests/6394
>>>>>>    The functions did not have proper Fortran stubs and interfaces so
>>>>>> I had to provide them manually in the new branch.
>>>>>>    Use
>>>>>>    git fetch
>>>>>>    git checkout barry/2023-04-29/fix-pcasmcreatesubdomains2d
>>>>>>    ./configure etc
>>>>>>    Your now working test code is in src/ksp/ksp/tests/ex71f.F90  I
>>>>>> had to change things slightly and I updated the error handling for the
>>>>>> latest version.
>>>>>>    Please let us know if you have any later questions.
>>>>>>   Barry
>>>>>> On Apr 28, 2023, at 12:07 PM, LEONARDO MUTTI <
>>>>>> Hello. I am having a hard time understanding the index sets to feed
>>>>>> PCGASMSetSubdomains, and I am working in Fortran (as a PETSc novice). To
>>>>>> get more intuition on how the IS objects behave I tried the following
>>>>>> minimal (non) working example, which should tile a 16x16 matrix into 16
>>>>>> square, non-overlapping submatrices:
>>>>>> #include <petsc/finclude/petscmat.h>
>>>>>> #include <petsc/finclude/petscksp.h>
>>>>>> #include <petsc/finclude/petscpc.h>
>>>>>>       USE petscmat
>>>>>>       USE petscksp
>>>>>>       USE petscpc
>>>>>>       Mat   :: A
>>>>>>       PetscInt :: M, NSubx, dof, overlap, NSub
>>>>>>       INTEGER :: I,J
>>>>>>       PetscErrorCode      :: ierr
>>>>>>       PetscScalar :: v
>>>>>>       KSP            :: ksp
>>>>>>       PC             :: pc
>>>>>>       IS :: subdomains_IS, inflated_IS
>>>>>>       call PetscInitialize(PETSC_NULL_CHARACTER , ierr)
>>>>>> !-----Create a dummy matrix
>>>>>>       M = 16
>>>>>>       call MatCreateAIJ(MPI_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>>>>>      & M, M,
>>>>>>      & PETSC_DEFAULT_INTEGER, PETSC_NULL_INTEGER,
>>>>>>      & A, ierr)
>>>>>>       DO I=1,M
>>>>>>          DO J=1,M
>>>>>>             v = I*J
>>>>>>             CALL MatSetValue (A,I-1,J-1,v,
>>>>>>      &                     INSERT_VALUES , ierr)
>>>>>>          END DO
>>>>>>       END DO
>>>>>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY , ierr)
>>>>>> !-----Create KSP and PC
>>>>>>       call KSPCreate(PETSC_COMM_WORLD,ksp, ierr)
>>>>>>       call KSPSetOperators(ksp,A,A, ierr)
>>>>>>       call KSPSetType(ksp,"bcgs",ierr)
>>>>>>       call KSPGetPC(ksp,pc,ierr)
>>>>>>       call KSPSetUp(ksp, ierr)
>>>>>>       call PCSetType(pc,PCGASM, ierr)
>>>>>>       call PCSetUp(pc , ierr)
>>>>>> !-----GASM setup
>>>>>>       NSubx = 4
>>>>>>       dof = 1
>>>>>>       overlap = 0
>>>>>>       call PCGASMCreateSubdomains2D(pc,
>>>>>>      &      M, M,
>>>>>>      &      NSubx, NSubx,
>>>>>>      &      dof, overlap,
>>>>>>      &      NSub, subdomains_IS, inflated_IS, ierr)
>>>>>>       call ISView(subdomains_IS, PETSC_VIEWER_STDOUT_WORLD, ierr)
>>>>>>       call KSPDestroy(ksp, ierr)
>>>>>>       call PetscFinalize(ierr)
>>>>>> Running this on one processor, I get NSub = 4.
>>>>>> If PCASM and PCASMCreateSubdomains2D are used instead, I get NSub =
>>>>>> 16 as expected.
>>>>>> Moreover, I get in the end "forrtl: severe (157): Program Exception -
>>>>>> access violation". So:
>>>>>> 1) why do I get two different results with ASM, and GASM?
>>>>>> 2) why do I get access violation and how can I solve this?
>>>>>> In fact, in C, subdomains_IS, inflated_IS should pointers to IS
>>>>>> objects. As I see on the Fortran interface, the arguments to
>>>>>> PCGASMCreateSubdomains2D are IS objects:
>>>>>>        subroutine PCGASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,j,z)
>>>>>>        import tPC,tIS
>>>>>>        PC a ! PC
>>>>>>        PetscInt b ! PetscInt
>>>>>>        PetscInt c ! PetscInt
>>>>>>        PetscInt d ! PetscInt
>>>>>>        PetscInt e ! PetscInt
>>>>>>        PetscInt f ! PetscInt
>>>>>>        PetscInt g ! PetscInt
>>>>>>        PetscInt h ! PetscInt
>>>>>>        IS i ! IS
>>>>>>        IS j ! IS
>>>>>>        PetscErrorCode z
>>>>>>        end subroutine PCGASMCreateSubdomains2D
>>>>>> Thus:
>>>>>> 3) what should be inside e.g., subdomains_IS? I expect it to contain,
>>>>>> for every created subdomain, the list of rows and columns defining the
>>>>>> subblock in the matrix, am I right?
>>>>>> Context: I have a block-tridiagonal system arising from space-time
>>>>>> finite elements, and I want to solve it with GMRES+PCGASM preconditioner,
>>>>>> where each overlapping submatrix is on the diagonal and of size 3x3 blocks
>>>>>> (and spanning multiple processes). This is PETSc 3.17.1 on Windows.
>>>>>> Thanks in advance,
>>>>>> Leonardo
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230505/88e8f1e1/attachment-0001.html>
