[petsc-users] sources of floating point randomness in JFNK in serial
Barry Smith bsmith at petsc.dev
Thu May 4 20:51:29 CDT 2023
  Send configure.log
> On May 4, 2023, at 5:35 PM, Mark Lohry <mlohry at gmail.com> wrote:
>> Sure, but why only once and why save to disk? Why not just use that computed approximate Jacobian at each Newton step to drive the Newton solves along for a bunch of time steps?
> Ah I get what you mean. Okay I did three newton steps with the same LHS, with a few repeated manual tests. 3 out of 4 times i got the same exact history. is it in the realm of possibility that a hardware error could cause something this subtle, bad memory bit or something?
> 2 runs of 3 newton solves below, ever-so-slightly different.
>  0 SNES Function norm 3.424003312857e+04
>     0 KSP Residual norm 3.424003312857e+04
>     1 KSP Residual norm 2.886124328003e+04
>     2 KSP Residual norm 2.504664994246e+04
>     3 KSP Residual norm 2.104615835161e+04
>     4 KSP Residual norm 1.938102896632e+04
>     5 KSP Residual norm 1.793774642408e+04
>     6 KSP Residual norm 1.671392566980e+04
>     7 KSP Residual norm 1.501504103873e+04
>     8 KSP Residual norm 1.366362900747e+04
>     9 KSP Residual norm 1.240398500429e+04
>    10 KSP Residual norm 1.156293733914e+04
>    11 KSP Residual norm 1.066296477958e+04
>    12 KSP Residual norm 9.835601966950e+03
>    13 KSP Residual norm 9.017480191491e+03
>    14 KSP Residual norm 8.415336139780e+03
>    15 KSP Residual norm 7.807497808435e+03
>    16 KSP Residual norm 7.341703768294e+03
>    17 KSP Residual norm 6.979298049282e+03
>    18 KSP Residual norm 6.521277772081e+03
>    19 KSP Residual norm 6.174842408773e+03
>    20 KSP Residual norm 5.889819665003e+03
>   Linear solve converged due to CONVERGED_ITS iterations 20
> KSP Object: 1 MPI process
>   type: gmres
>     restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=20, initial guess is zero
>   tolerances:  relative=0.1, absolute=1e-15, divergence=10.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI process
>   type: none
>   linear system matrix = precond matrix:
>   Mat Object: 1 MPI process
>     type: seqbaij
>     rows=16384, cols=16384, bs=16
>     total: nonzeros=1277952, allocated nonzeros=1277952
>     total number of mallocs used during MatSetValues calls=0
>         block size is 16
>   1 SNES Function norm 1.000525348433e+04
> Nonlinear solve converged due to CONVERGED_ITS iterations 1
> SNES Object: 1 MPI process
>   type: newtonls
>   maximum iterations=1, maximum function evaluations=-1
>   tolerances: relative=0.1, absolute=1e-15, solution=1e-15
>   total number of linear solver iterations=20
>   total number of function evaluations=2
>   norm schedule ALWAYS
>   Jacobian is never rebuilt
>   Jacobian is built using finite differences with coloring
>   SNESLineSearch Object: 1 MPI process
>     type: basic
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
>     maximum iterations=40
>     type: gmres
>     type: none
>       type: seqbaij
>           block size is 16
>   0 SNES Function norm 1.000525348433e+04
>     0 KSP Residual norm 1.000525348433e+04
>     1 KSP Residual norm 7.908741564765e+03
>     2 KSP Residual norm 6.825263536686e+03
>     3 KSP Residual norm 6.224930664968e+03
>     4 KSP Residual norm 6.095547180532e+03
>     5 KSP Residual norm 5.952968230430e+03
>     6 KSP Residual norm 5.861251998116e+03
>     7 KSP Residual norm 5.712439327755e+03
>     8 KSP Residual norm 5.583056913266e+03
>     9 KSP Residual norm 5.461768804626e+03
>    10 KSP Residual norm 5.351937611098e+03
>    11 KSP Residual norm 5.224288337578e+03
>    12 KSP Residual norm 5.129863847081e+03
>    13 KSP Residual norm 5.010818237218e+03
>    14 KSP Residual norm 4.907162936199e+03
>    15 KSP Residual norm 4.789564773955e+03
>    16 KSP Residual norm 4.695173370720e+03
>    17 KSP Residual norm 4.584070962171e+03
>    18 KSP Residual norm 4.483061424742e+03
>    19 KSP Residual norm 4.373384070745e+03
>    20 KSP Residual norm 4.260704657592e+03
>   type: gmres
>   type: none
>     type: seqbaij
>         block size is 16
>   1 SNES Function norm 4.662386014882e+03
>   type: newtonls
>     type: basic
>     type: gmres
>     type: none
>       type: seqbaij
>           block size is 16
>   0 SNES Function norm 4.662386014882e+03
>     0 KSP Residual norm 4.662386014882e+03
>     1 KSP Residual norm 4.408316259864e+03
>     2 KSP Residual norm 4.184867769829e+03
>     3 KSP Residual norm 4.079091244351e+03
>     4 KSP Residual norm 4.009247390166e+03
>     5 KSP Residual norm 3.928417371428e+03
>     6 KSP Residual norm 3.865152075780e+03
>     7 KSP Residual norm 3.795606446033e+03
>     8 KSP Residual norm 3.735294554158e+03
>     9 KSP Residual norm 3.674393726487e+03
>    10 KSP Residual norm 3.617795166786e+03
>    11 KSP Residual norm 3.563807982274e+03
>    12 KSP Residual norm 3.512269444921e+03
>    13 KSP Residual norm 3.455110223236e+03
>    14 KSP Residual norm 3.407141247372e+03
>    15 KSP Residual norm 3.356562415982e+03
>    16 KSP Residual norm 3.312720047685e+03
>    17 KSP Residual norm 3.263690150810e+03
>    18 KSP Residual norm 3.219359862444e+03
>    19 KSP Residual norm 3.173500955995e+03
>    20 KSP Residual norm 3.127528790155e+03
>   type: gmres
>   type: none
>     type: seqbaij
>         block size is 16
>   1 SNES Function norm 3.186752172556e+03
>   type: newtonls
>     type: basic
>     type: gmres
>     type: none
>       type: seqbaij
>           block size is 16
>     2 KSP Residual norm 2.504664994221e+04
>     3 KSP Residual norm 2.104615835130e+04
>     4 KSP Residual norm 1.938102896610e+04
>     5 KSP Residual norm 1.793774642406e+04
>     6 KSP Residual norm 1.671392566981e+04
>     7 KSP Residual norm 1.501504103854e+04
>     8 KSP Residual norm 1.366362900726e+04
>     9 KSP Residual norm 1.240398500414e+04
>    11 KSP Residual norm 1.066296477972e+04
>    12 KSP Residual norm 9.835601967036e+03
>    13 KSP Residual norm 9.017480191500e+03
>    14 KSP Residual norm 8.415336139732e+03
>    15 KSP Residual norm 7.807497808414e+03
>    16 KSP Residual norm 7.341703768300e+03
>    17 KSP Residual norm 6.979298049244e+03
>    18 KSP Residual norm 6.521277772042e+03
>    19 KSP Residual norm 6.174842408713e+03
>    20 KSP Residual norm 5.889819664983e+03
>   type: gmres
>   type: none
>     type: seqbaij
>         block size is 16
>   1 SNES Function norm 1.000525348435e+04
>   type: newtonls
>     type: basic
>     type: gmres
>     type: none
>       type: seqbaij
>           block size is 16
>   0 SNES Function norm 1.000525348435e+04
>     0 KSP Residual norm 1.000525348435e+04
>     1 KSP Residual norm 7.908741565645e+03
>     2 KSP Residual norm 6.825263536988e+03
>     3 KSP Residual norm 6.224930664967e+03
>     4 KSP Residual norm 6.095547180474e+03
>     5 KSP Residual norm 5.952968230397e+03
>     6 KSP Residual norm 5.861251998127e+03
>     7 KSP Residual norm 5.712439327726e+03
>     8 KSP Residual norm 5.583056913167e+03
>     9 KSP Residual norm 5.461768804526e+03
>    10 KSP Residual norm 5.351937611030e+03
>    11 KSP Residual norm 5.224288337536e+03
>    12 KSP Residual norm 5.129863847028e+03
>    13 KSP Residual norm 5.010818237161e+03
>    14 KSP Residual norm 4.907162936143e+03
>    15 KSP Residual norm 4.789564773923e+03
>    16 KSP Residual norm 4.695173370709e+03
>    17 KSP Residual norm 4.584070962145e+03
>    18 KSP Residual norm 4.483061424714e+03
>    19 KSP Residual norm 4.373384070713e+03
>    20 KSP Residual norm 4.260704657576e+03
>   type: gmres
>   type: none
>     type: seqbaij
>         block size is 16
>   1 SNES Function norm 4.662386014874e+03
>   type: newtonls
>     type: basic
>     type: gmres
>     type: none
>       type: seqbaij
>           block size is 16
>   0 SNES Function norm 4.662386014874e+03
>     0 KSP Residual norm 4.662386014874e+03
>     1 KSP Residual norm 4.408316259834e+03
>     2 KSP Residual norm 4.184867769891e+03
>     3 KSP Residual norm 4.079091244367e+03
>     4 KSP Residual norm 4.009247390184e+03
>     5 KSP Residual norm 3.928417371457e+03
>     6 KSP Residual norm 3.865152075802e+03
>     7 KSP Residual norm 3.795606446041e+03
>     8 KSP Residual norm 3.735294554160e+03
>     9 KSP Residual norm 3.674393726485e+03
>    10 KSP Residual norm 3.617795166775e+03
>    11 KSP Residual norm 3.563807982249e+03
>    12 KSP Residual norm 3.512269444873e+03
>    13 KSP Residual norm 3.455110223193e+03
>    14 KSP Residual norm 3.407141247334e+03
>    15 KSP Residual norm 3.356562415949e+03
>    16 KSP Residual norm 3.312720047652e+03
>    17 KSP Residual norm 3.263690150782e+03
>    18 KSP Residual norm 3.219359862425e+03
>    19 KSP Residual norm 3.173500955997e+03
>    20 KSP Residual norm 3.127528790156e+03
>   type: gmres
>   type: none
>     type: seqbaij
>         block size is 16
>   1 SNES Function norm 3.186752172503e+03
>   type: newtonls
>     type: basic
>     type: gmres
>     type: none
>       type: seqbaij
>           block size is 16
> On Thu, May 4, 2023 at 5:22 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Thu, May 4, 2023 at 5:03 PM Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>> Do you get different results (in different runs) without  -snes_mf_operator? So just using an explicit matrix?
>>> Unfortunately I don't have an explicit matrix available for this, hence the MFFD/JFNK.
>> I don't mean the actual matrix, I mean a representative matrix.
>>>>   (Note: I am not convinced there is even a problem and think it may be simply different order of floating point operations in different runs.)
>>> I'm not convinced either, but running explicit RK for 10,000 iterations i get exactly the same results every time so i'm fairly confident it's not the residual evaluation.
>>> How would there be a different order of floating point ops in different runs in serial?
>>>> No, I mean without -snes_mf_* (as Barry says), so we are just running that solver with a sparse matrix. This would give me confidence
>>>> that nothing in the solver is variable.
>>> I could do the sparse finite difference jacobian once, save it to disk, and then use that system each time.
>> Yes. That would work.
>>   Thanks,
>>      Matt
>>> On Thu, May 4, 2023 at 4:57 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> On Thu, May 4, 2023 at 4:44 PM Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>>>> Is your code valgrind clean?
>>>>> Yes, I also initialize all allocations with NaNs to be sure I'm not using anything uninitialized.
>>>>>> We can try and test this. Replace your MatMFFD with an actual matrix and run. Do you see any variability?
>>>>> I think I did what you're asking. I have -snes_mf_operator set, and then SNESSetJacobian(snes, diag_ones, diag_ones, NULL, NULL) where diag_ones is a matrix with ones on the diagonal. Two runs below, still with differences but sometimes identical.
>>>>   Thanks,
>>>>      Matt
>>>>>     1 KSP Residual norm 2.871734444536e+04
>>>>>     2 KSP Residual norm 2.490276930242e+04
>>>>>     3 KSP Residual norm 2.131675872968e+04
>>>>>     4 KSP Residual norm 1.973129814235e+04
>>>>>     5 KSP Residual norm 1.832377856317e+04
>>>>>     6 KSP Residual norm 1.716783617436e+04
>>>>>     7 KSP Residual norm 1.583963149542e+04
>>>>>     8 KSP Residual norm 1.482272170304e+04
>>>>>     9 KSP Residual norm 1.380312106742e+04
>>>>>    10 KSP Residual norm 1.297793480658e+04
>>>>>    11 KSP Residual norm 1.208599123244e+04
>>>>>    12 KSP Residual norm 1.137345655227e+04
>>>>>    13 KSP Residual norm 1.059676909366e+04
>>>>>    14 KSP Residual norm 1.003823862398e+04
>>>>>    15 KSP Residual norm 9.425879221354e+03
>>>>>    16 KSP Residual norm 8.954805890038e+03
>>>>>    17 KSP Residual norm 8.592372470456e+03
>>>>>    18 KSP Residual norm 8.060707175821e+03
>>>>>    19 KSP Residual norm 7.782057728723e+03
>>>>>    20 KSP Residual norm 7.449686095424e+03
>>>>>   type: gmres
>>>>>   type: none
>>>>>   linear system matrix followed by preconditioner matrix:
>>>>>     type: mffd
>>>>>       Matrix-free approximation:
>>>>>         err=1.49012e-08 (relative error in function evaluation)
>>>>>         Using wp compute h routine
>>>>>             Does not compute normU
>>>>>     type: seqaij
>>>>>     total: nonzeros=16384, allocated nonzeros=16384
>>>>>       not using I-node routines
>>>>>   1 SNES Function norm 1.085015646971e+04
>>>>>   type: newtonls
>>>>>   total number of function evaluations=23
>>>>>   Jacobian is applied matrix-free with differencing
>>>>>   Preconditioning Jacobian is built using finite differences with coloring
>>>>>     type: basic
>>>>>     type: gmres
>>>>>     type: none
>>>>>       type: mffd
>>>>>       type: seqaij
>>>>>     2 KSP Residual norm 2.490276931041e+04
>>>>>     3 KSP Residual norm 2.131675873776e+04
>>>>>     4 KSP Residual norm 1.973129814908e+04
>>>>>     5 KSP Residual norm 1.832377852186e+04
>>>>>     6 KSP Residual norm 1.716783608174e+04
>>>>>     7 KSP Residual norm 1.583963128956e+04
>>>>>     8 KSP Residual norm 1.482272160069e+04
>>>>>     9 KSP Residual norm 1.380312087005e+04
>>>>>    10 KSP Residual norm 1.297793458796e+04
>>>>>    11 KSP Residual norm 1.208599115602e+04
>>>>>    12 KSP Residual norm 1.137345657533e+04
>>>>>    13 KSP Residual norm 1.059676906197e+04
>>>>>    14 KSP Residual norm 1.003823857515e+04
>>>>>    15 KSP Residual norm 9.425879177747e+03
>>>>>    16 KSP Residual norm 8.954805850825e+03
>>>>>    17 KSP Residual norm 8.592372413320e+03
>>>>>    18 KSP Residual norm 8.060706994110e+03
>>>>>    19 KSP Residual norm 7.782057560782e+03
>>>>>    20 KSP Residual norm 7.449686034356e+03
>>>>>   type: gmres
>>>>>   type: none
>>>>>     type: mffd
>>>>>     type: seqaij
>>>>>   1 SNES Function norm 1.085015821006e+04
>>>>>   type: newtonls
>>>>>     type: basic
>>>>>     type: gmres
>>>>>     type: none
>>>>>       type: mffd
>>>>>       type: seqaij
>>>>> On Thu, May 4, 2023 at 10:10 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>>> On Thu, May 4, 2023 at 8:54 AM Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>>>>>> Try -pc_type none.
>>>>>>> With -pc_type none the 0 KSP residual looks identical. But *sometimes* it's producing exactly the same history and others it's gradually changing.  I'm reasonably confident my residual evaluation has no randomness, see info after the petsc output.
>>>>>> If not, then it could be your routine, or it could be MatMFFD. So run a few with -snes_view, and we can see if the
>>>>>> "w" parameter changes.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> solve history 1:
>>>>>>> solve history 2, identical to 1:
>>>>>>> solve history 3, identical KSP at 0 and 1, slight change at 2, growing difference to the end:
>>>>>>> Ths is using a standard explicit 3-stage Runge-Kutta smoother for 10 iterations, so 30 calls of the same residual evaluation, identical residuals every time
>>>>>>> run 1:
>>>>>>> # iteration            rho                 rhou                rhov                rhoE                abs_res             rel_res             umin                vmax                vmin                elapsed_time
>>>>>>>           1.00000e+00  1.086860616292e+00  2.782316758416e+02  4.482867643761e+00  2.993435920340e+02         2.04353e+02         1.00000e+00        -8.23945e-15        -6.15326e-15        -1.35563e-14         6.34834e-01
>>>>>>>           2.00000e+00  2.310547487017e+00  1.079059352425e+02  3.958323921837e+00  5.058927165686e+02         2.58647e+02         1.26568e+00        -1.02539e-14        -9.35368e-15        -1.69925e-14         6.40063e-01
>>>>>>>           3.00000e+00  2.361005867444e+00  5.706213331683e+01  6.130016323357e+00  4.688968362579e+02         2.36201e+02         1.15585e+00        -1.19370e-14        -1.15216e-14        -1.59733e-14         6.45166e-01
>>>>>>>           4.00000e+00  2.167518999963e+00  3.757541401594e+01  6.313917437428e+00  4.054310291628e+02         2.03612e+02         9.96372e-01        -1.81831e-14        -1.28312e-14        -1.46238e-14         6.50494e-01
>>>>>>>           5.00000e+00  1.941443738676e+00  2.884190334049e+01  6.237106158479e+00  3.539201037156e+02         1.77577e+02         8.68970e-01         3.56633e-14        -8.74089e-15        -1.06666e-14         6.55656e-01
>>>>>>>           6.00000e+00  1.736947124693e+00  2.429485695670e+01  5.996962200407e+00  3.148280178142e+02         1.57913e+02         7.72745e-01        -8.98634e-14        -2.41152e-14        -1.39713e-14         6.60872e-01
>>>>>>>           7.00000e+00  1.564153212635e+00  2.149609219810e+01  5.786910705204e+00  2.848717011033e+02         1.42872e+02         6.99144e-01        -2.95352e-13        -2.48158e-14        -2.39351e-14         6.66041e-01
>>>>>>>           8.00000e+00  1.419280815384e+00  1.950619804089e+01  5.627281158306e+00  2.606623371229e+02         1.30728e+02         6.39715e-01         8.98941e-13         1.09674e-13         3.78905e-14         6.71316e-01
>>>>>>>           9.00000e+00  1.296115915975e+00  1.794843530745e+01  5.514933264437e+00  2.401524522393e+02         1.20444e+02         5.89394e-01         1.70717e-12         1.38762e-14         1.09825e-13         6.76447e-01
>>>>>>>           1.00000e+01  1.189639693918e+00  1.665381754953e+01  5.433183087037e+00  2.222572900473e+02         1.11475e+02         5.45501e-01        -4.22462e-12        -7.15206e-13        -2.28736e-13         6.81716e-01
>>>>>>> run N:
>>>>>>>           1.00000e+00  1.086860616292e+00  2.782316758416e+02  4.482867643761e+00  2.993435920340e+02         2.04353e+02         1.00000e+00        -8.23945e-15        -6.15326e-15        -1.35563e-14         6.23316e-01
>>>>>>>           2.00000e+00  2.310547487017e+00  1.079059352425e+02  3.958323921837e+00  5.058927165686e+02         2.58647e+02         1.26568e+00        -1.02539e-14        -9.35368e-15        -1.69925e-14         6.28510e-01
>>>>>>>           3.00000e+00  2.361005867444e+00  5.706213331683e+01  6.130016323357e+00  4.688968362579e+02         2.36201e+02         1.15585e+00        -1.19370e-14        -1.15216e-14        -1.59733e-14         6.33558e-01
>>>>>>>           4.00000e+00  2.167518999963e+00  3.757541401594e+01  6.313917437428e+00  4.054310291628e+02         2.03612e+02         9.96372e-01        -1.81831e-14        -1.28312e-14        -1.46238e-14         6.38773e-01
>>>>>>>           5.00000e+00  1.941443738676e+00  2.884190334049e+01  6.237106158479e+00  3.539201037156e+02         1.77577e+02         8.68970e-01         3.56633e-14        -8.74089e-15        -1.06666e-14         6.43887e-01
>>>>>>>           6.00000e+00  1.736947124693e+00  2.429485695670e+01  5.996962200407e+00  3.148280178142e+02         1.57913e+02         7.72745e-01        -8.98634e-14        -2.41152e-14        -1.39713e-14         6.49073e-01
>>>>>>>           7.00000e+00  1.564153212635e+00  2.149609219810e+01  5.786910705204e+00  2.848717011033e+02         1.42872e+02         6.99144e-01        -2.95352e-13        -2.48158e-14        -2.39351e-14         6.54167e-01
>>>>>>>           8.00000e+00  1.419280815384e+00  1.950619804089e+01  5.627281158306e+00  2.606623371229e+02         1.30728e+02         6.39715e-01         8.98941e-13         1.09674e-13         3.78905e-14         6.59394e-01
>>>>>>>           9.00000e+00  1.296115915975e+00  1.794843530745e+01  5.514933264437e+00  2.401524522393e+02         1.20444e+02         5.89394e-01         1.70717e-12         1.38762e-14         1.09825e-13         6.64516e-01
>>>>>>>           1.00000e+01  1.189639693918e+00  1.665381754953e+01  5.433183087037e+00  2.222572900473e+02         1.11475e+02         5.45501e-01        -4.22462e-12        -7.15206e-13        -2.28736e-13         6.69677e-01
>>>>>>> On Thu, May 4, 2023 at 8:41 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>>>>>> ASM is just the sub PC with one proc but gets weaker with more procs unless you use jacobi. (maybe I am missing something).
>>>>>>>> On Thu, May 4, 2023 at 8:31 AM Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>>>>>>>>  Please send the output of -snes_view.
>>>>>>>>> pasted below. anything stand out?
>>>>>>>>>   type: newtonls
>>>>>>>>>   total number of function evaluations=22
>>>>>>>>>     type: basic
>>>>>>>>>     type: gmres
>>>>>>>>>     type: asm
>>>>>>>>>       total subdomain blocks = 1, amount of overlap = 0
>>>>>>>>>       restriction/interpolation type - RESTRICT
>>>>>>>>>       Local solver information for first block is in the following KSP and PC objects on rank 0:
>>>>>>>>>       Use -ksp_view ::ascii_info_detail to display information for all blocks
>>>>>>>>>     KSP Object: (sub_) 1 MPI process
>>>>>>>>>       type: preonly
>>>>>>>>>       maximum iterations=10000, initial guess is zero
>>>>>>>>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>>>>>       using NONE norm type for convergence test
>>>>>>>>>     PC Object: (sub_) 1 MPI process
>>>>>>>>>       type: ilu
>>>>>>>>>         out-of-place factorization
>>>>>>>>>         0 levels of fill
>>>>>>>>>         tolerance for zero pivot 2.22045e-14
>>>>>>>>>         matrix ordering: natural
>>>>>>>>>         factor fill ratio given 1., needed 1.
>>>>>>>>>           Factored matrix follows:
>>>>>>>>>             Mat Object: (sub_) 1 MPI process
>>>>>>>>>               type: seqbaij
>>>>>>>>>               package used to perform factorization: petsc
>>>>>>>>>                   block size is 16
>>>>>>>>>         type: seqbaij
>>>>>>>>>             block size is 16
>>>>>>>>>       type: mffd
>>>>>>>>>       type: seqbaij
>>>>>>>>>           block size is 16
>>>>>>>>> On Thu, May 4, 2023 at 8:30 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>>>>>>>> If you are using MG what is the coarse grid solver?
>>>>>>>>>> -snes_view might give you that.
>>>>>>>>>> On Thu, May 4, 2023 at 8:25 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>>>>>>>> On Thu, May 4, 2023 at 8:21 AM Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>>>>>>>>>>> Do they start very similarly and then slowly drift further apart?
>>>>>>>>>>>> Yes, this. I take it this sounds familiar?
>>>>>>>>>>>> See these two examples with 20 fixed iterations pasted at the end. The difference for one solve is slight (final SNES norm is identical to 5 digits), but in the context I'm using it in (repeated applications to solve a steady state multigrid problem, though here just one level) the differences add up such that I might reach global convergence in 35 iterations or 38. It's not the end of the world, but I was expecting that with -np 1 these would be identical and I'm not sure where the root cause would be.
>>>>>>>>>>> The initial KSP residual is different, so its the PC. Please send the output of -snes_view. If your ASM is using direct factorization, then it
>>>>>>>>>>> could be randomness in whatever LU you are using.
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>     Matt
>>>>>>>>>>>>   0 SNES Function norm 2.801842107848e+04
>>>>>>>>>>>>     0 KSP Residual norm 4.045639499595e+01
>>>>>>>>>>>>     1 KSP Residual norm 1.917999809040e+01
>>>>>>>>>>>>     2 KSP Residual norm 1.616048521958e+01
>>>>>>>>>>>>    19 KSP Residual norm 8.788043518111e-01
>>>>>>>>>>>>    20 KSP Residual norm 6.570851270214e-01
>>>>>>>>>>>>   1 SNES Function norm 1.801309983345e+03
>>>>>>>>>>>> Same system, identical initial 0 SNES norm, 0 KSP is slightly different
>>>>>>>>>>>>     0 KSP Residual norm 4.045639473002e+01
>>>>>>>>>>>>     1 KSP Residual norm 1.917999883034e+01
>>>>>>>>>>>>     2 KSP Residual norm 1.616048572016e+01
>>>>>>>>>>>>    19 KSP Residual norm 8.788046348957e-01
>>>>>>>>>>>>    20 KSP Residual norm 6.570859588610e-01
>>>>>>>>>>>>   1 SNES Function norm 1.801311320322e+03
>>>>>>>>>>>> On Wed, May 3, 2023 at 11:05 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>>>>>>>>>   Do they start very similarly and then slowly drift further apart? That is the first couple of KSP iterations they are almost identical but then for each iteration get a bit further. Similar for the SNES iterations, starting close and then for more iterations and more solves they start moving apart. Or do they suddenly jump to be very different? You can run with -snes_monitor -ksp_monitor
>>>>>>>>>>>>>> On May 3, 2023, at 9:07 PM, Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>>>>>>>>>>>> This is on a single MPI rank. I haven't checked the coloring, was just guessing there. But the solutions/residuals are slightly different from run to run.
>>>>>>>>>>>>>> Fair to say that for serial JFNK/asm ilu0/gmres we should expect bitwise identical results?
>>>>>>>>>>>>>> On Wed, May 3, 2023, 8:50 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>>>>>>>>>>>   No, the coloring should be identical every time. Do you see differences with 1 MPI rank? (Or much smaller ones?).
>>>>>>>>>>>>>>> > On May 3, 2023, at 8:42 PM, Mark Lohry <mlohry at gmail.com <mailto:mlohry at gmail.com>> wrote:
>>>>>>>>>>>>>>> > I'm running multiple iterations of newtonls with an MFFD/JFNK nonlinear solver where I give it the sparsity. PC asm, KSP gmres, with SNESSetLagJacobian -2 (compute once and then frozen jacobian).
>>>>>>>>>>>>>>> > I'm seeing slight (<1%) but nonzero differences in residuals from run to run. I'm wondering where randomness might enter here -- does the jacobian coloring use a random seed?
>>>>>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>>>>> -- Norbert Wiener
>>>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/d3391f88/attachment-0001.html>
