[petsc-users] sources of floating point randomness in JFNK in serial
Thu May 4 15:56:53 CDT 2023
On Thu, May 4, 2023 at 4:44 PM Mark Lohry <mlohry at gmail.com> wrote:
> Is your code valgrind clean?
> Yes, I also initialize all allocations with NaNs to be sure I'm not using
> anything uninitialized.
>> We can try and test this. Replace your MatMFFD with an actual matrix and
>> run. Do you see any variability?
> I think I did what you're asking. I have -snes_mf_operator set, and then
> SNESSetJacobian(snes, diag_ones, diag_ones, NULL, NULL) where diag_ones is
> a matrix with ones on the diagonal. Two runs below, still with differences
> but sometimes identical.
No, I mean without -snes_mf_* (as Barry says), so we are just running that
solver with a sparse matrix. This would give me confidence
that nothing in the solver is variable.
     Matt
>   0 SNES Function norm 3.424003312857e+04
>     0 KSP Residual norm 3.424003312857e+04
>     1 KSP Residual norm 2.871734444536e+04
>     2 KSP Residual norm 2.490276930242e+04
>     3 KSP Residual norm 2.131675872968e+04
>     4 KSP Residual norm 1.973129814235e+04
>     5 KSP Residual norm 1.832377856317e+04
>     6 KSP Residual norm 1.716783617436e+04
>     7 KSP Residual norm 1.583963149542e+04
>     8 KSP Residual norm 1.482272170304e+04
>     9 KSP Residual norm 1.380312106742e+04
>    10 KSP Residual norm 1.297793480658e+04
>    11 KSP Residual norm 1.208599123244e+04
>    12 KSP Residual norm 1.137345655227e+04
>    13 KSP Residual norm 1.059676909366e+04
>    14 KSP Residual norm 1.003823862398e+04
>    15 KSP Residual norm 9.425879221354e+03
>    16 KSP Residual norm 8.954805890038e+03
>    17 KSP Residual norm 8.592372470456e+03
>    18 KSP Residual norm 8.060707175821e+03
>    19 KSP Residual norm 7.782057728723e+03
>    20 KSP Residual norm 7.449686095424e+03
>   Linear solve converged due to CONVERGED_ITS iterations 20
> KSP Object: 1 MPI process
>   type: gmres
>     restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=20, initial guess is zero
>   tolerances:  relative=0.1, absolute=1e-15, divergence=10.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI process
>   type: none
>   linear system matrix followed by preconditioner matrix:
>   Mat Object: 1 MPI process
>     type: mffd
>     rows=16384, cols=16384
>       Matrix-free approximation:
>         err=1.49012e-08 (relative error in function evaluation)
>         Using wp compute h routine
>             Does not compute normU
>     type: seqaij
>     total: nonzeros=16384, allocated nonzeros=16384
>     total number of mallocs used during MatSetValues calls=0
>       not using I-node routines
>   1 SNES Function norm 1.085015646971e+04
> Nonlinear solve converged due to CONVERGED_ITS iterations 1
> SNES Object: 1 MPI process
>   type: newtonls
>   maximum iterations=1, maximum function evaluations=-1
>   tolerances: relative=0.1, absolute=1e-15, solution=1e-15
>   total number of linear solver iterations=20
>   total number of function evaluations=23
>   norm schedule ALWAYS
>   Jacobian is never rebuilt
>   Jacobian is applied matrix-free with differencing
>   Preconditioning Jacobian is built using finite differences with coloring
>   SNESLineSearch Object: 1 MPI process
>     type: basic
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
>     type: gmres
>     type: none
>       type: mffd
>       type: seqaij
>     2 KSP Residual norm 2.490276931041e+04
>     3 KSP Residual norm 2.131675873776e+04
>     4 KSP Residual norm 1.973129814908e+04
>     5 KSP Residual norm 1.832377852186e+04
>     6 KSP Residual norm 1.716783608174e+04
>     7 KSP Residual norm 1.583963128956e+04
>     8 KSP Residual norm 1.482272160069e+04
>     9 KSP Residual norm 1.380312087005e+04
>    10 KSP Residual norm 1.297793458796e+04
>    11 KSP Residual norm 1.208599115602e+04
>    12 KSP Residual norm 1.137345657533e+04
>    13 KSP Residual norm 1.059676906197e+04
>    14 KSP Residual norm 1.003823857515e+04
>    15 KSP Residual norm 9.425879177747e+03
>    16 KSP Residual norm 8.954805850825e+03
>    17 KSP Residual norm 8.592372413320e+03
>    18 KSP Residual norm 8.060706994110e+03
>    19 KSP Residual norm 7.782057560782e+03
>    20 KSP Residual norm 7.449686034356e+03
>   type: gmres
>   type: none
>     type: mffd
>     type: seqaij
>   1 SNES Function norm 1.085015821006e+04
>   type: newtonls
>     type: basic
> lambda=1.000000e-08
>     type: gmres
>     type: none
>       type: mffd
>       type: seqaij
> On Thu, May 4, 2023 at 10:10 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, May 4, 2023 at 8:54 AM Mark Lohry <mlohry at gmail.com> wrote:
>>> Try -pc_type none.
>>> With -pc_type none the 0 KSP residual looks identical. But *sometimes*
>>> it's producing exactly the same history and others it's gradually
>>> changing.  I'm reasonably confident my residual evaluation has no
>>> randomness, see info after the petsc output.
>> If not, then it could be your routine, or it could be MatMFFD. So run a
>> few with -snes_view, and we can see if the
>> "w" parameter changes.
>>   Thanks,
>>      Matt
>>> solve history 1:
>>> solve history 2, identical to 1:
>>> solve history 3, identical KSP at 0 and 1, slight change at 2, growing
>>> difference to the end:
>>> Ths is using a standard explicit 3-stage Runge-Kutta smoother for 10
>>> iterations, so 30 calls of the same residual evaluation, identical
>>> residuals every time
>>> run 1:
>>> # iteration            rho                 rhou                rhov
>>>            rhoE                abs_res             rel_res             umin
>>>                vmax                vmin                elapsed_time
>>>           1.00000e+00  1.086860616292e+00  2.782316758416e+02
>>>  4.482867643761e+00  2.993435920340e+02         2.04353e+02
>>> 1.00000e+00        -8.23945e-15        -6.15326e-15        -1.35563e-14
>>>     6.34834e-01
>>>           2.00000e+00  2.310547487017e+00  1.079059352425e+02
>>>  3.958323921837e+00  5.058927165686e+02         2.58647e+02
>>> 1.26568e+00        -1.02539e-14        -9.35368e-15        -1.69925e-14
>>>     6.40063e-01
>>>           3.00000e+00  2.361005867444e+00  5.706213331683e+01
>>>  6.130016323357e+00  4.688968362579e+02         2.36201e+02
>>> 1.15585e+00        -1.19370e-14        -1.15216e-14        -1.59733e-14
>>>     6.45166e-01
>>>           4.00000e+00  2.167518999963e+00  3.757541401594e+01
>>>  6.313917437428e+00  4.054310291628e+02         2.03612e+02
>>> 9.96372e-01        -1.81831e-14        -1.28312e-14        -1.46238e-14
>>>     6.50494e-01
>>>           5.00000e+00  1.941443738676e+00  2.884190334049e+01
>>>  6.237106158479e+00  3.539201037156e+02         1.77577e+02
>>> 8.68970e-01         3.56633e-14        -8.74089e-15        -1.06666e-14
>>>     6.55656e-01
>>>           6.00000e+00  1.736947124693e+00  2.429485695670e+01
>>>  5.996962200407e+00  3.148280178142e+02         1.57913e+02
>>> 7.72745e-01        -8.98634e-14        -2.41152e-14        -1.39713e-14
>>>     6.60872e-01
>>>           7.00000e+00  1.564153212635e+00  2.149609219810e+01
>>>  5.786910705204e+00  2.848717011033e+02         1.42872e+02
>>> 6.99144e-01        -2.95352e-13        -2.48158e-14        -2.39351e-14
>>>     6.66041e-01
>>>           8.00000e+00  1.419280815384e+00  1.950619804089e+01
>>>  5.627281158306e+00  2.606623371229e+02         1.30728e+02
>>> 6.39715e-01         8.98941e-13         1.09674e-13         3.78905e-14
>>>     6.71316e-01
>>>           9.00000e+00  1.296115915975e+00  1.794843530745e+01
>>>  5.514933264437e+00  2.401524522393e+02         1.20444e+02
>>> 5.89394e-01         1.70717e-12         1.38762e-14         1.09825e-13
>>>     6.76447e-01
>>>           1.00000e+01  1.189639693918e+00  1.665381754953e+01
>>>  5.433183087037e+00  2.222572900473e+02         1.11475e+02
>>> 5.45501e-01        -4.22462e-12        -7.15206e-13        -2.28736e-13
>>>     6.81716e-01
>>> run N:
>>>     6.23316e-01
>>>     6.28510e-01
>>>     6.33558e-01
>>>     6.38773e-01
>>>     6.43887e-01
>>>     6.49073e-01
>>>     6.54167e-01
>>>     6.59394e-01
>>>     6.64516e-01
>>>     6.69677e-01
>>> On Thu, May 4, 2023 at 8:41 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> ASM is just the sub PC with one proc but gets weaker with more procs
>>>> unless you use jacobi. (maybe I am missing something).
>>>> On Thu, May 4, 2023 at 8:31 AM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>  Please send the output of -snes_view.
>>>>> pasted below. anything stand out?
>>>>>   type: newtonls
>>>>>   total number of function evaluations=22
>>>>> coloring
>>>>>     type: basic
>>>>> lambda=1.000000e-08
>>>>>     type: gmres
>>>>>     type: asm
>>>>>       total subdomain blocks = 1, amount of overlap = 0
>>>>>       restriction/interpolation type - RESTRICT
>>>>>       Local solver information for first block is in the following KSP
>>>>> and PC objects on rank 0:
>>>>>       Use -ksp_view ::ascii_info_detail to display information for all
>>>>> blocks
>>>>>     KSP Object: (sub_) 1 MPI process
>>>>>       type: preonly
>>>>>       maximum iterations=10000, initial guess is zero
>>>>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>       using NONE norm type for convergence test
>>>>>     PC Object: (sub_) 1 MPI process
>>>>>       type: ilu
>>>>>         out-of-place factorization
>>>>>         0 levels of fill
>>>>>         tolerance for zero pivot 2.22045e-14
>>>>>         matrix ordering: natural
>>>>>         factor fill ratio given 1., needed 1.
>>>>>           Factored matrix follows:
>>>>>             Mat Object: (sub_) 1 MPI process
>>>>>               type: seqbaij
>>>>>               rows=16384, cols=16384, bs=16
>>>>>               package used to perform factorization: petsc
>>>>>               total: nonzeros=1277952, allocated nonzeros=1277952
>>>>>                   block size is 16
>>>>>       linear system matrix = precond matrix:
>>>>>         type: seqbaij
>>>>>             block size is 16
>>>>>       type: mffd
>>>>>       type: seqbaij
>>>>>           block size is 16
>>>>> On Thu, May 4, 2023 at 8:30 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> If you are using MG what is the coarse grid solver?
>>>>>> -snes_view might give you that.
>>>>>> On Thu, May 4, 2023 at 8:25 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Thu, May 4, 2023 at 8:21 AM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>> Do they start very similarly and then slowly drift further apart?
>>>>>>>> Yes, this. I take it this sounds familiar?
>>>>>>>> See these two examples with 20 fixed iterations pasted at the end.
>>>>>>>> The difference for one solve is slight (final SNES norm is identical to 5
>>>>>>>> digits), but in the context I'm using it in (repeated applications to solve
>>>>>>>> a steady state multigrid problem, though here just one level) the
>>>>>>>> differences add up such that I might reach global convergence in 35
>>>>>>>> iterations or 38. It's not the end of the world, but I was expecting that
>>>>>>>> with -np 1 these would be identical and I'm not sure where the root cause
>>>>>>>> would be.
>>>>>>> The initial KSP residual is different, so its the PC. Please send
>>>>>>> the output of -snes_view. If your ASM is using direct factorization, then it
>>>>>>> could be randomness in whatever LU you are using.
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>>   0 SNES Function norm 2.801842107848e+04
>>>>>>>>     0 KSP Residual norm 4.045639499595e+01
>>>>>>>>     1 KSP Residual norm 1.917999809040e+01
>>>>>>>>     2 KSP Residual norm 1.616048521958e+01
>>>>>>>>    19 KSP Residual norm 8.788043518111e-01
>>>>>>>>    20 KSP Residual norm 6.570851270214e-01
>>>>>>>>   1 SNES Function norm 1.801309983345e+03
>>>>>>>> Same system, identical initial 0 SNES norm, 0 KSP is slightly
>>>>>>>> different
>>>>>>>>     0 KSP Residual norm 4.045639473002e+01
>>>>>>>>     1 KSP Residual norm 1.917999883034e+01
>>>>>>>>     2 KSP Residual norm 1.616048572016e+01
>>>>>>>>    19 KSP Residual norm 8.788046348957e-01
>>>>>>>>    20 KSP Residual norm 6.570859588610e-01
>>>>>>>>   1 SNES Function norm 1.801311320322e+03
>>>>>>>> On Wed, May 3, 2023 at 11:05 PM Barry Smith <bsmith at petsc.dev>
>>>>>>>>> apart? That is the first couple of KSP iterations they are almost identical
>>>>>>>>> but then for each iteration get a bit further. Similar for the SNES
>>>>>>>>> iterations, starting close and then for more iterations and more solves
>>>>>>>>> they start moving apart. Or do they suddenly jump to be very different? You
>>>>>>>>> can run with -snes_monitor -ksp_monitor
>>>>>>>>> On May 3, 2023, at 9:07 PM, Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>>> This is on a single MPI rank. I haven't checked the coloring, was
>>>>>>>>> just guessing there. But the solutions/residuals are slightly different
>>>>>>>>> from run to run.
>>>>>>>>> Fair to say that for serial JFNK/asm ilu0/gmres we should expect
>>>>>>>>> bitwise identical results?
>>>>>>>>> On Wed, May 3, 2023, 8:50 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>>>>   No, the coloring should be identical every time. Do you see
>>>>>>>>>> differences with 1 MPI rank? (Or much smaller ones?).
>>>>>>>>>> > On May 3, 2023, at 8:42 PM, Mark Lohry <mlohry at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>> > I'm running multiple iterations of newtonls with an MFFD/JFNK
>>>>>>>>>> nonlinear solver where I give it the sparsity. PC asm, KSP gmres, with
>>>>>>>>>> SNESSetLagJacobian -2 (compute once and then frozen jacobian).
>>>>>>>>>> > I'm seeing slight (<1%) but nonzero differences in residuals
>>>>>>>>>> from run to run. I'm wondering where randomness might enter here -- does
>>>>>>>>>> the jacobian coloring use a random seed?
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/25f7389a/attachment-0001.html>
