[petsc-users] sources of floating point randomness in JFNK in serial
Mark Lohry mlohry at gmail.com
Thu May 4 15:43:51 CDT 2023
> Is your code valgrind clean?
Yes, I also initialize all allocations with NaNs to be sure I'm not using
anything uninitialized.
> We can try and test this. Replace your MatMFFD with an actual matrix and
> run. Do you see any variability?
I think I did what you're asking. I have -snes_mf_operator set, and then
SNESSetJacobian(snes, diag_ones, diag_ones, NULL, NULL) where diag_ones is
a matrix with ones on the diagonal. Two runs below, still with differences
but sometimes identical.
  0 SNES Function norm 3.424003312857e+04
    0 KSP Residual norm 3.424003312857e+04
    1 KSP Residual norm 2.871734444536e+04
    2 KSP Residual norm 2.490276930242e+04
    3 KSP Residual norm 2.131675872968e+04
    4 KSP Residual norm 1.973129814235e+04
    5 KSP Residual norm 1.832377856317e+04
    6 KSP Residual norm 1.716783617436e+04
    7 KSP Residual norm 1.583963149542e+04
    8 KSP Residual norm 1.482272170304e+04
    9 KSP Residual norm 1.380312106742e+04
   10 KSP Residual norm 1.297793480658e+04
   11 KSP Residual norm 1.208599123244e+04
   12 KSP Residual norm 1.137345655227e+04
   13 KSP Residual norm 1.059676909366e+04
   14 KSP Residual norm 1.003823862398e+04
   15 KSP Residual norm 9.425879221354e+03
   16 KSP Residual norm 8.954805890038e+03
   17 KSP Residual norm 8.592372470456e+03
   18 KSP Residual norm 8.060707175821e+03
   19 KSP Residual norm 7.782057728723e+03
   20 KSP Residual norm 7.449686095424e+03
  Linear solve converged due to CONVERGED_ITS iterations 20
KSP Object: 1 MPI process
  type: gmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=20, initial guess is zero
  tolerances:  relative=0.1, absolute=1e-15, divergence=10.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI process
  type: none
  linear system matrix followed by preconditioner matrix:
  Mat Object: 1 MPI process
    type: mffd
    rows=16384, cols=16384
      Matrix-free approximation:
        err=1.49012e-08 (relative error in function evaluation)
        Using wp compute h routine
            Does not compute normU
    type: seqaij
    total: nonzeros=16384, allocated nonzeros=16384
    total number of mallocs used during MatSetValues calls=0
      not using I-node routines
  1 SNES Function norm 1.085015646971e+04
Nonlinear solve converged due to CONVERGED_ITS iterations 1
SNES Object: 1 MPI process
  type: newtonls
  maximum iterations=1, maximum function evaluations=-1
  tolerances: relative=0.1, absolute=1e-15, solution=1e-15
  total number of linear solver iterations=20
  total number of function evaluations=23
  norm schedule ALWAYS
  Jacobian is never rebuilt
  Jacobian is applied matrix-free with differencing
  Preconditioning Jacobian is built using finite differences with coloring
  SNESLineSearch Object: 1 MPI process
    type: basic
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
    type: gmres
Orthogonalization with no iterative refinement
    type: none
      type: mffd
      type: seqaij
    2 KSP Residual norm 2.490276931041e+04
    3 KSP Residual norm 2.131675873776e+04
    4 KSP Residual norm 1.973129814908e+04
    5 KSP Residual norm 1.832377852186e+04
    6 KSP Residual norm 1.716783608174e+04
    7 KSP Residual norm 1.583963128956e+04
    8 KSP Residual norm 1.482272160069e+04
    9 KSP Residual norm 1.380312087005e+04
   10 KSP Residual norm 1.297793458796e+04
   11 KSP Residual norm 1.208599115602e+04
   12 KSP Residual norm 1.137345657533e+04
   13 KSP Residual norm 1.059676906197e+04
   14 KSP Residual norm 1.003823857515e+04
   15 KSP Residual norm 9.425879177747e+03
   16 KSP Residual norm 8.954805850825e+03
   17 KSP Residual norm 8.592372413320e+03
   18 KSP Residual norm 8.060706994110e+03
   19 KSP Residual norm 7.782057560782e+03
   20 KSP Residual norm 7.449686034356e+03
  type: gmres
  type: none
    type: mffd
    type: seqaij
  1 SNES Function norm 1.085015821006e+04
  type: newtonls
    type: basic
lambda=1.000000e-08
    type: gmres
    type: none
      type: mffd
      type: seqaij
On Thu, May 4, 2023 at 10:10 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 4, 2023 at 8:54 AM Mark Lohry <mlohry at gmail.com> wrote:
>> Try -pc_type none.
>> With -pc_type none the 0 KSP residual looks identical. But *sometimes*
>> it's producing exactly the same history and others it's gradually
>> changing.  I'm reasonably confident my residual evaluation has no
>> randomness, see info after the petsc output.
> If not, then it could be your routine, or it could be MatMFFD. So run a
> few with -snes_view, and we can see if the
> "w" parameter changes.
>   Thanks,
>      Matt
>> solve history 1:
>> solve history 2, identical to 1:
>> solve history 3, identical KSP at 0 and 1, slight change at 2, growing
>> difference to the end:
>> Ths is using a standard explicit 3-stage Runge-Kutta smoother for 10
>> iterations, so 30 calls of the same residual evaluation, identical
>> residuals every time
>> run 1:
>> # iteration            rho                 rhou                rhov
>>          rhoE                abs_res             rel_res             umin
>>              vmax                vmin                elapsed_time
>>           1.00000e+00  1.086860616292e+00  2.782316758416e+02
>>  4.482867643761e+00  2.993435920340e+02         2.04353e+02
>> 1.00000e+00        -8.23945e-15        -6.15326e-15        -1.35563e-14
>>     6.34834e-01
>>           2.00000e+00  2.310547487017e+00  1.079059352425e+02
>>  3.958323921837e+00  5.058927165686e+02         2.58647e+02
>> 1.26568e+00        -1.02539e-14        -9.35368e-15        -1.69925e-14
>>     6.40063e-01
>>           3.00000e+00  2.361005867444e+00  5.706213331683e+01
>>  6.130016323357e+00  4.688968362579e+02         2.36201e+02
>> 1.15585e+00        -1.19370e-14        -1.15216e-14        -1.59733e-14
>>     6.45166e-01
>>           4.00000e+00  2.167518999963e+00  3.757541401594e+01
>>  6.313917437428e+00  4.054310291628e+02         2.03612e+02
>> 9.96372e-01        -1.81831e-14        -1.28312e-14        -1.46238e-14
>>     6.50494e-01
>>           5.00000e+00  1.941443738676e+00  2.884190334049e+01
>>  6.237106158479e+00  3.539201037156e+02         1.77577e+02
>> 8.68970e-01         3.56633e-14        -8.74089e-15        -1.06666e-14
>>     6.55656e-01
>>           6.00000e+00  1.736947124693e+00  2.429485695670e+01
>>  5.996962200407e+00  3.148280178142e+02         1.57913e+02
>> 7.72745e-01        -8.98634e-14        -2.41152e-14        -1.39713e-14
>>     6.60872e-01
>>           7.00000e+00  1.564153212635e+00  2.149609219810e+01
>>  5.786910705204e+00  2.848717011033e+02         1.42872e+02
>> 6.99144e-01        -2.95352e-13        -2.48158e-14        -2.39351e-14
>>     6.66041e-01
>>           8.00000e+00  1.419280815384e+00  1.950619804089e+01
>>  5.627281158306e+00  2.606623371229e+02         1.30728e+02
>> 6.39715e-01         8.98941e-13         1.09674e-13         3.78905e-14
>>     6.71316e-01
>>           9.00000e+00  1.296115915975e+00  1.794843530745e+01
>>  5.514933264437e+00  2.401524522393e+02         1.20444e+02
>> 5.89394e-01         1.70717e-12         1.38762e-14         1.09825e-13
>>     6.76447e-01
>>           1.00000e+01  1.189639693918e+00  1.665381754953e+01
>>  5.433183087037e+00  2.222572900473e+02         1.11475e+02
>> 5.45501e-01        -4.22462e-12        -7.15206e-13        -2.28736e-13
>>     6.81716e-01
>> run N:
>>     6.23316e-01
>>     6.28510e-01
>>     6.33558e-01
>>     6.38773e-01
>>     6.43887e-01
>>     6.49073e-01
>>     6.54167e-01
>>     6.59394e-01
>>     6.64516e-01
>>     6.69677e-01
>> On Thu, May 4, 2023 at 8:41 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> ASM is just the sub PC with one proc but gets weaker with more procs
>>> unless you use jacobi. (maybe I am missing something).
>>> On Thu, May 4, 2023 at 8:31 AM Mark Lohry <mlohry at gmail.com> wrote:
>>>>  Please send the output of -snes_view.
>>>> pasted below. anything stand out?
>>>>   type: newtonls
>>>>   total number of function evaluations=22
>>>> coloring
>>>>     type: basic
>>>> lambda=1.000000e-08
>>>>     type: gmres
>>>>     type: asm
>>>>       total subdomain blocks = 1, amount of overlap = 0
>>>>       restriction/interpolation type - RESTRICT
>>>>       Local solver information for first block is in the following KSP
>>>> and PC objects on rank 0:
>>>>       Use -ksp_view ::ascii_info_detail to display information for all
>>>> blocks
>>>>     KSP Object: (sub_) 1 MPI process
>>>>       type: preonly
>>>>       maximum iterations=10000, initial guess is zero
>>>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>>>       using NONE norm type for convergence test
>>>>     PC Object: (sub_) 1 MPI process
>>>>       type: ilu
>>>>         out-of-place factorization
>>>>         0 levels of fill
>>>>         tolerance for zero pivot 2.22045e-14
>>>>         matrix ordering: natural
>>>>         factor fill ratio given 1., needed 1.
>>>>           Factored matrix follows:
>>>>             Mat Object: (sub_) 1 MPI process
>>>>               type: seqbaij
>>>>               rows=16384, cols=16384, bs=16
>>>>               package used to perform factorization: petsc
>>>>               total: nonzeros=1277952, allocated nonzeros=1277952
>>>>                   block size is 16
>>>>       linear system matrix = precond matrix:
>>>>         type: seqbaij
>>>>             block size is 16
>>>>       type: mffd
>>>>       type: seqbaij
>>>>           block size is 16
>>>> On Thu, May 4, 2023 at 8:30 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> If you are using MG what is the coarse grid solver?
>>>>> -snes_view might give you that.
>>>>> On Thu, May 4, 2023 at 8:25 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, May 4, 2023 at 8:21 AM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>> Do they start very similarly and then slowly drift further apart?
>>>>>>> Yes, this. I take it this sounds familiar?
>>>>>>> See these two examples with 20 fixed iterations pasted at the end.
>>>>>>> The difference for one solve is slight (final SNES norm is identical to 5
>>>>>>> digits), but in the context I'm using it in (repeated applications to solve
>>>>>>> a steady state multigrid problem, though here just one level) the
>>>>>>> differences add up such that I might reach global convergence in 35
>>>>>>> iterations or 38. It's not the end of the world, but I was expecting that
>>>>>>> with -np 1 these would be identical and I'm not sure where the root cause
>>>>>>> would be.
>>>>>> The initial KSP residual is different, so its the PC. Please send the
>>>>>> output of -snes_view. If your ASM is using direct factorization, then it
>>>>>> could be randomness in whatever LU you are using.
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>>   0 SNES Function norm 2.801842107848e+04
>>>>>>>     0 KSP Residual norm 4.045639499595e+01
>>>>>>>     1 KSP Residual norm 1.917999809040e+01
>>>>>>>     2 KSP Residual norm 1.616048521958e+01
>>>>>>>    19 KSP Residual norm 8.788043518111e-01
>>>>>>>    20 KSP Residual norm 6.570851270214e-01
>>>>>>>   1 SNES Function norm 1.801309983345e+03
>>>>>>> Same system, identical initial 0 SNES norm, 0 KSP is slightly
>>>>>>> different
>>>>>>>     0 KSP Residual norm 4.045639473002e+01
>>>>>>>     1 KSP Residual norm 1.917999883034e+01
>>>>>>>     2 KSP Residual norm 1.616048572016e+01
>>>>>>>    19 KSP Residual norm 8.788046348957e-01
>>>>>>>    20 KSP Residual norm 6.570859588610e-01
>>>>>>>   1 SNES Function norm 1.801311320322e+03
>>>>>>> On Wed, May 3, 2023 at 11:05 PM Barry Smith <bsmith at petsc.dev>
>>>>>>>> That is the first couple of KSP iterations they are almost identical but
>>>>>>>> then for each iteration get a bit further. Similar for the SNES iterations,
>>>>>>>> starting close and then for more iterations and more solves they start
>>>>>>>> moving apart. Or do they suddenly jump to be very different? You can run
>>>>>>>> with -snes_monitor -ksp_monitor
>>>>>>>> On May 3, 2023, at 9:07 PM, Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>> This is on a single MPI rank. I haven't checked the coloring, was
>>>>>>>> just guessing there. But the solutions/residuals are slightly different
>>>>>>>> from run to run.
>>>>>>>> Fair to say that for serial JFNK/asm ilu0/gmres we should expect
>>>>>>>> bitwise identical results?
>>>>>>>> On Wed, May 3, 2023, 8:50 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>>>   No, the coloring should be identical every time. Do you see
>>>>>>>>> differences with 1 MPI rank? (Or much smaller ones?).
>>>>>>>>> > On May 3, 2023, at 8:42 PM, Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>>> > I'm running multiple iterations of newtonls with an MFFD/JFNK
>>>>>>>>> nonlinear solver where I give it the sparsity. PC asm, KSP gmres, with
>>>>>>>>> SNESSetLagJacobian -2 (compute once and then frozen jacobian).
>>>>>>>>> > I'm seeing slight (<1%) but nonzero differences in residuals
>>>>>>>>> from run to run. I'm wondering where randomness might enter here -- does
>>>>>>>>> the jacobian coloring use a random seed?
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/3d79bb0b/attachment-0001.html>
