[petsc-users] sources of floating point randomness in JFNK in serial
Mark Lohry mlohry at gmail.com
Thu May 4 07:31:45 CDT 2023
>  Please send the output of -snes_view.
pasted below. anything stand out?
SNES Object: 1 MPI process
  type: newtonls
  maximum iterations=1, maximum function evaluations=-1
  tolerances: relative=0.1, absolute=1e-15, solution=1e-15
  total number of linear solver iterations=20
  total number of function evaluations=22
  norm schedule ALWAYS
  Jacobian is never rebuilt
  Jacobian is applied matrix-free with differencing
  Preconditioning Jacobian is built using finite differences with coloring
  SNESLineSearch Object: 1 MPI process
    type: basic
    maxstep=1.000000e+08, minlambda=1.000000e-12
    tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
    maximum iterations=40
  KSP Object: 1 MPI process
    type: gmres
      restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
      happy breakdown tolerance 1e-30
    maximum iterations=20, initial guess is zero
    tolerances:  relative=0.1, absolute=1e-15, divergence=10.
    left preconditioning
    using PRECONDITIONED norm type for convergence test
  PC Object: 1 MPI process
    type: asm
      total subdomain blocks = 1, amount of overlap = 0
      restriction/interpolation type - RESTRICT
      Local solver information for first block is in the following KSP and
PC objects on rank 0:
      Use -ksp_view ::ascii_info_detail to display information for all
blocks
    KSP Object: (sub_) 1 MPI process
      type: preonly
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      using NONE norm type for convergence test
    PC Object: (sub_) 1 MPI process
      type: ilu
        out-of-place factorization
        0 levels of fill
        tolerance for zero pivot 2.22045e-14
        matrix ordering: natural
        factor fill ratio given 1., needed 1.
          Factored matrix follows:
            Mat Object: (sub_) 1 MPI process
              type: seqbaij
              rows=16384, cols=16384, bs=16
              package used to perform factorization: petsc
              total: nonzeros=1277952, allocated nonzeros=1277952
                  block size is 16
      linear system matrix = precond matrix:
        type: seqbaij
        total number of mallocs used during MatSetValues calls=0
            block size is 16
    linear system matrix followed by preconditioner matrix:
    Mat Object: 1 MPI process
      type: mffd
        Matrix-free approximation:
          err=1.49012e-08 (relative error in function evaluation)
          Using wp compute h routine
              Does not compute normU
      type: seqbaij
          block size is 16
On Thu, May 4, 2023 at 8:30 AM Mark Adams <mfadams at lbl.gov> wrote:
> If you are using MG what is the coarse grid solver?
> -snes_view might give you that.
> On Thu, May 4, 2023 at 8:25 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, May 4, 2023 at 8:21 AM Mark Lohry <mlohry at gmail.com> wrote:
>>> Do they start very similarly and then slowly drift further apart?
>>> Yes, this. I take it this sounds familiar?
>>> See these two examples with 20 fixed iterations pasted at the end. The
>>> difference for one solve is slight (final SNES norm is identical to 5
>>> digits), but in the context I'm using it in (repeated applications to solve
>>> a steady state multigrid problem, though here just one level) the
>>> differences add up such that I might reach global convergence in 35
>>> iterations or 38. It's not the end of the world, but I was expecting that
>>> with -np 1 these would be identical and I'm not sure where the root cause
>>> would be.
>> The initial KSP residual is different, so its the PC. Please send the
>> output of -snes_view. If your ASM is using direct factorization, then it
>> could be randomness in whatever LU you are using.
>>   Thanks,
>>     Matt
>>>   0 SNES Function norm 2.801842107848e+04
>>>     0 KSP Residual norm 4.045639499595e+01
>>>     1 KSP Residual norm 1.917999809040e+01
>>>     2 KSP Residual norm 1.616048521958e+01
>>>    19 KSP Residual norm 8.788043518111e-01
>>>    20 KSP Residual norm 6.570851270214e-01
>>>   Linear solve converged due to CONVERGED_ITS iterations 20
>>>   1 SNES Function norm 1.801309983345e+03
>>> Nonlinear solve converged due to CONVERGED_ITS iterations 1
>>> Same system, identical initial 0 SNES norm, 0 KSP is slightly different
>>>     0 KSP Residual norm 4.045639473002e+01
>>>     1 KSP Residual norm 1.917999883034e+01
>>>     2 KSP Residual norm 1.616048572016e+01
>>>    19 KSP Residual norm 8.788046348957e-01
>>>    20 KSP Residual norm 6.570859588610e-01
>>>   1 SNES Function norm 1.801311320322e+03
>>>> That is the first couple of KSP iterations they are almost identical but
>>>> then for each iteration get a bit further. Similar for the SNES iterations,
>>>> starting close and then for more iterations and more solves they start
>>>> moving apart. Or do they suddenly jump to be very different? You can run
>>>> with -snes_monitor -ksp_monitor
>>>> On May 3, 2023, at 9:07 PM, Mark Lohry <mlohry at gmail.com> wrote:
>>>> This is on a single MPI rank. I haven't checked the coloring, was just
>>>> guessing there. But the solutions/residuals are slightly different from run
>>>> to run.
>>>> Fair to say that for serial JFNK/asm ilu0/gmres we should expect
>>>> bitwise identical results?
>>>> On Wed, May 3, 2023, 8:50 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>   No, the coloring should be identical every time. Do you see
>>>>> differences with 1 MPI rank? (Or much smaller ones?).
>>>>> > On May 3, 2023, at 8:42 PM, Mark Lohry <mlohry at gmail.com> wrote:
>>>>> > I'm running multiple iterations of newtonls with an MFFD/JFNK
>>>>> nonlinear solver where I give it the sparsity. PC asm, KSP gmres, with
>>>>> SNESSetLagJacobian -2 (compute once and then frozen jacobian).
>>>>> > I'm seeing slight (<1%) but nonzero differences in residuals from
>>>>> run to run. I'm wondering where randomness might enter here -- does the
>>>>> jacobian coloring use a random seed?
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/a88f25ba/attachment.html>
