[petsc-users] parallel computing error
­권승리 / 학생 / 항공우주공학과 ksl7912 at snu.ac.kr
Thu May 4 02:20:24 CDT 2023
Dear Barry Smith
Thank you for your reply.
I've already installed MUMPS.
And I checked the example you said (ex125.c), I don't understand why the
RHS matrix becomes the SeqDense matrix.
Could you explain in more detail?
Best regards
Seung Lee Kwon
2023년 5월 4일 (목) 오후 12:08, Barry Smith <bsmith at petsc.dev>님이 작성:
>   You can configure with MUMPS ./configure --download-mumps
> --download-scalapack --download-ptscotch --download-metis
> --download-parmetis
>   And then use MatMatSolve() as in src/mat/tests/ex125.c with parallel
> MatMatSolve() using MUMPS as the solver.
>   Barry
> On May 3, 2023, at 10:29 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> wrote:
> Dear developers
> Thank you for your explanation.
> But I should use the MatCreateSeqDense because I want to use the
> MatMatSolve that B matrix must be a SeqDense matrix.
> Using MatMatSolve is an inevitable part of my code.
> Could you give me a comment to avoid this error?
> Best,
> Seung Lee Kwon
> 2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Wed, May 3, 2023 at 6:05 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>> wrote:
>>> Dear developers
>>> I'm trying to use parallel computing and I ran the command 'mpirun -np 4
>>> ./app'
>>> In this case, there are two problems.
>>> *First,* I encountered error message
>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: Invalid argument
>>> [1]PETSC ERROR: Comm must be of size 1
>>> The code on the error position is
>>> MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
>> 1) "Seq" means sequential, that is "not parallel".
>> 2) This line should still be fine since PETSC_COMM_SELF is a serial
>> communicator
>> 3) You should be checking the error code for each call, maybe using the
>> CHKERRQ() macro
>> 4) Please always send the entire error message, not a snippet
>>   THanks
>>      Matt
>>> Could "MatCreateSeqDense" not be used in parallel computing?
>>> *Second*, the same error message is repeated as many times as the
>>> number of cores.
>>> if I use command -np 4, then the error message is repeated 4 times.
>>> Could you recommend some advice related to this?
>>> Best,
>>> Seung Lee Kwon
>>> Seung Lee Kwon, Ph.D.Candidate
>>> Aerospace Structures and Materials Laboratory
>>> Department of Mechanical and Aerospace Engineering
>>> Seoul National University
>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>>> E-mail : ksl7912 at snu.ac.kr
>>> Office : +82-2-880-7389
>>> C. P : +82-10-4695-1062
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/467de5f5/attachment-0001.html>
