[petsc-users] parallel computing error
­권승리 / 학생 / 항공우주공학과 ksl7912 at snu.ac.kr
Wed May 3 21:29:04 CDT 2023
Dear developers
Thank you for your explanation.
But I should use the MatCreateSeqDense because I want to use the
MatMatSolve that B matrix must be a SeqDense matrix.
Using MatMatSolve is an inevitable part of my code.
Could you give me a comment to avoid this error?
Best,
Seung Lee Kwon
2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, May 3, 2023 at 6:05 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> wrote:
>> Dear developers
>> I'm trying to use parallel computing and I ran the command 'mpirun -np 4
>> ./app'
>> In this case, there are two problems.
>> *First,* I encountered error message
>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Invalid argument
>> [1]PETSC ERROR: Comm must be of size 1
>> The code on the error position is
>> MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
> 1) "Seq" means sequential, that is "not parallel".
> 2) This line should still be fine since PETSC_COMM_SELF is a serial
> communicator
> 3) You should be checking the error code for each call, maybe using the
> CHKERRQ() macro
> 4) Please always send the entire error message, not a snippet
>   THanks
>      Matt
>> Could "MatCreateSeqDense" not be used in parallel computing?
>> *Second*, the same error message is repeated as many times as the number
>> of cores.
>> if I use command -np 4, then the error message is repeated 4 times.
>> Could you recommend some advice related to this?
>> Best,
>> Seung Lee Kwon
>> Seung Lee Kwon, Ph.D.Candidate
>> Aerospace Structures and Materials Laboratory
>> Department of Mechanical and Aerospace Engineering
>> Seoul National University
>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>> E-mail : ksl7912 at snu.ac.kr
>> Office : +82-2-880-7389
>> C. P : +82-10-4695-1062
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230504/9303ca0c/attachment-0001.html>
