[petsc-users] sources of floating point randomness in JFNK in serial
Mark Lohry mlohry at gmail.com
Wed May 3 20:07:49 CDT 2023
This is on a single MPI rank. I haven't checked the coloring, was just
guessing there. But the solutions/residuals are slightly different from run
to run.
Fair to say that for serial JFNK/asm ilu0/gmres we should expect bitwise
identical results?
On Wed, May 3, 2023, 8:50 PM Barry Smith <bsmith at petsc.dev> wrote:
>   No, the coloring should be identical every time. Do you see differences
> with 1 MPI rank? (Or much smaller ones?).
> > On May 3, 2023, at 8:42 PM, Mark Lohry <mlohry at gmail.com> wrote:
> > I'm running multiple iterations of newtonls with an MFFD/JFNK nonlinear
> solver where I give it the sparsity. PC asm, KSP gmres, with
> SNESSetLagJacobian -2 (compute once and then frozen jacobian).
> > I'm seeing slight (<1%) but nonzero differences in residuals from run to
> run. I'm wondering where randomness might enter here -- does the jacobian
> coloring use a random seed?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230503/450f7b74/attachment.html>
