[petsc-users] parallel computing error
­권승리 / 학생 / 항공우주공학과 ksl7912 at snu.ac.kr
Wed May 3 05:04:35 CDT 2023
Dear developers
I'm trying to use parallel computing and I ran the command 'mpirun -np 4
./app'
In this case, there are two problems.
*First,* I encountered error message
[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Invalid argument
[1]PETSC ERROR: Comm must be of size 1
The code on the error position is
MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
Could "MatCreateSeqDense" not be used in parallel computing?
*Second*, the same error message is repeated as many times as the number of
cores.
if I use command -np 4, then the error message is repeated 4 times.
Could you recommend some advice related to this?
Best,
Seung Lee Kwon
Seung Lee Kwon, Ph.D.Candidate
Aerospace Structures and Materials Laboratory
Department of Mechanical and Aerospace Engineering
Seoul National University
Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
E-mail : ksl7912 at snu.ac.kr
Office : +82-2-880-7389
C. P : +82-10-4695-1062
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230503/2ca5ee40/attachment.html>
