[petsc-users] DMSWARM with DMDA and KSP
Matthew Young myoung.space.science at gmail.com
Tue May 2 10:26:51 CDT 2023
Yup -- I realized that I had '-pc_type mg' in the script I was using to
build and run as I developed. I guess that was causing the KSP to coarsen
its DM, which made me think I had to force the density DM to be consistent.
Still, refactoring my original grid DM into one for Vlasov components and
one for the potential was useful.
Thanks for the help!
--Matt
Matthew Young, PhD (he/him)
Research Scientist II
Space Science Center
University of New Hampshire
Matthew.Young at unh.edu
On Mon, May 1, 2023 at 10:51 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Mon 1. May 2023 at 18:57, Matthew Young <myoung.space.science at gmail.com>
> wrote:
>> Thanks for the suggestion to keep DMs separate, and for pointing me
>> toward that example. I now have a DM for the particle quantities (i.e.,
>> density and flux) and another for the potential. I'm hoping to use
>> KSPSetComputeOperators with PCGAMG, so I packed the density DM into the
>> application context and set the potential DM on the KSP, but I'm not sure
>> how to communicate changes in the KSP DM (e.g., coarsening) to the density
>> DM inside my operator function.
> I don’t think you need to.
> GAMG only requires the fine grid operator - this will be the matrix
> assembled from KSPSetComputeOperators. Hence density DM and potential DM
> fields only need to be managed by you on the finest level.
> However, if you wanted to use PCMG with rediscretized operators on every
> level, then you would need the density DM field defined on each level of
> your geometric multigrid hierarchy. This could be done (possibly less than
> ideally) by calling DMCreateInterpolation() and then using the Mat to
> interpolate the density from the  finest level to next coarsest level (and
> so on).
> Thanks,
> Dave
>> --Matt
>> On Sun, Apr 30, 2023 at 1:52 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, Apr 30, 2023 at 1:12 PM Matthew Young <
>>> myoung.space.science at gmail.com> wrote:
>>>> Hi all,
>>>> I am developing a particle-in-cell code that models ions as particles
>>>> and electrons as an inertialess fluid. I use a PIC DMSWARM for the ions,
>>>> which I gather into density and flux before solving a linear system for the
>>>> electrostatic potential (phi). I currently have one DMDA with 5 degrees of
>>>> freedom -- one each for density, 3 flux components, and phi.
>>>> When setting up the linear system to solve for phi, I've been following
>>>> examples like KSP ex34.c and ex42.c when writing the KSP operator and RHS
>>>> functions but I'm not sure I have the right approach, since 4 of the DOFs
>>>> are known and 1 is unknown.
>>>> I saw this thread
>>>> <https://lists.mcs.anl.gov/pipermail/petsc-users/2016-November/031031.html>
>>>> that recommended using DMDAGetReducedDMDA, which I gather has been
>>>> deprecated in favor of DMDACreateCompatibleDMDA. Is that a good approach
>>>> for managing a regular grid with known and unknown quantities on each node?
>>>> Could a composite DM be useful? Has anyone else worked on a problem like
>>>> this?
>>> I recommend making a different DM for each kind of solve you want.
>>> DMDACreateCompatibleDMDA() should be the implementation of DMClone(), but
>>> we have yet to harmonize all things for all DMs. I would create one DM for
>>> your Vlasov components and one for the Poisson.
>>> We follow this strategy in our Vlasov-Poisson test for Landau damping:
>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/swarm/tests/ex9.c
>>>   Thanks,
>>>      Matt
>>>> --Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230502/9d76f188/attachment.html>
