[petsc-users] Node numbering in parallel partitioned mesh
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Tue May 2 07:25:06 CDT 2023
Hello,
This is not exactly a PETSc question. I have a parallel partitioned finite element mesh. What are the steps involved in having a contiguous but unique set of node numbering from one partition to the next? There are nodes which are shared between different partitions. Moreover, this partition has to coincide parallel partition of PETSc Vec/Mat, which ensures data locality.
If you can post the algorithm or cite a reference, it will prove helpful.
Many thanks.
Kind regards,
Karthik.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230502/59ee0994/attachment.html>
