[petsc-users] Problem in some macro when using VS+intel cl
冯上玮 fengshw3 at mail2.sysu.edu.cn
Tue Jun 27 22:30:07 CDT 2023
This is EXACTLY the CRUX of the matter, with this precompile command, there is no more error! Thanks for your patience with my numerous and continuous questions.
Je vous remercie !!
------------------ Original ------------------
Date:  Wed, Jun 28, 2023 10:24 AM
To:  "冯上玮"<fengshw3 at mail2.sysu.edu.cn>;
Cc:  "Matthew Knepley"<knepley at gmail.com>; "petsc-users"<petsc-users at mcs.anl.gov>;
Subject:  Re: [petsc-users] Problem in some macro when using VS+intel cl
   The macros expand differently depending on the compiler being used. In this case
#if defined(PETSC_HAVE_BUILTIN_EXPECT)
  #define PetscUnlikely(cond) __builtin_expect(!!(cond), 0)
  #define PetscLikely(cond)   __builtin_expect(!!(cond), 1)
#else
  #define PetscUnlikely(cond) (cond)
  #define PetscLikely(cond)   (cond)
#endif
So with Microsoft Windows compilers, if they do not support built_inexpect the compiler will only see the #else for the macro thus the compiler would never see the __builtin_expect
You can check in $PETSC_DIR/$PETSC_ARCH/include/petscconf.h and see if PETSC_HAVE_BUILTIN_EXPECT is defined. ./configure determines if this (and many other) features are supported by the compiler. It is conceivable that somehow configure determined incorrectly that this is supported.
On Jun 27, 2023, at 10:09 PM, 冯上玮 <fengshw3 at mail2.sysu.edu.cn> wrote:
I've followed your advice and include the header's file and libraries in Visual Studio. Such "error" still shows but I can build the project! It's strange!
I expand the CHKERRQ macro and find the error actually locates at
<2F07716E at 673DAE5F.6C969B6400000000.bmp>
What I know from google is that the "__builtin_expect__" is defined in GCC, so is it unsolvable in Windows with visual studio C compiler or Inter C compiler?
Date:  Wed, Jun 28, 2023 01:59 AM
Cc:  "petsc-users"<petsc-users at mcs.anl.gov>;
On Tue, Jun 27, 2023 at 11:32 AM 冯上玮 <fengshw3 at mail2.sysu.edu.cn> wrote:
After failure with MS-MPI once and once again, I tried icl+oneAPI and succeeded in installing and testing PESTc in Cygwin!
However, (always however) when I copied the example code on Getting Started page on visual studio, there are tons of error like:
<CCB1C477 at 3FC4424F.6C969B6400000000.jpg>
I just wonder where the problem locates, I've googled this error message and it seems that it's induced by the difference of compilers, c.f. https://stackoverflow.com/questions/42136395/identifier-builtin-expect-is-undefined-during-ros-on-win-tutorial-talker-ex. But Intel says that they also provide such thing on icl, and I actually use this compiler instead of visual studio cl...
The IDE is not showing the actual error message. Are you sure that your IDE build has the right includes and libraries? You can
get these using
  cd $PETSC_DIR
  make getincludedirs
  make getlinklibs
     Matt
Anyway, the project could be built if I delete these error-checking macro.
Installing feedback (or as a test result):
When configure on windows, only icl + impi works, and in this case, both --with-cc and --with-cxx options need to point out the version like: --with-cc-std-c99 and --with-cxx-std-c++'ver'. Other combinations such as cl + impi, icl + msmpi, cl + msmpi never work. My tutor told me that older version of msmpi may work but I never try this.
FENG.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230628/12d20f1d/attachment-0001.html>
