[petsc-users] [EXTERNAL] Re: Initializing kokkos before petsc causes a problem
Fackler, Philip facklerpw at ornl.gov
Tue Jun 27 09:30:40 CDT 2023
Good morning Junchao! I'm following up here to see if there is any update to petsc to resolve this issue, or if we need to come up with a work-around.
Thank you,
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
Sent: Wednesday, June 7, 2023 22:45
To: Fackler, Philip <facklerpw at ornl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Blondel, Sophie <sblondel at utk.edu>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>
Subject: [EXTERNAL] Re: [petsc-users] Initializing kokkos before petsc causes a problem
Hi, Philip,
  Thanks for reporting. I will have a look at the issue.
--Junchao Zhang
On Wed, Jun 7, 2023 at 9:30 AM Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I'm encountering a problem in xolotl. We initialize kokkos before initializing petsc. Therefore...
The pointer referenced here:
https://gitlab.com/petsc/petsc/-/blob/main/src/vec/is/sf/impls/basic/kokkos/sfkok.kokkos.cxx#L363<https://urldefense.us/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_blob_main_src_vec_is_sf_impls_basic_kokkos_sfkok.kokkos.cxx-23L363&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=mm5WnvW66V9aFezISyisTVEya_MgbI4YjpAuorp4BHdklRfAD8kTzaDBY3VlzI-4&s=i_BmubxwJ4005UQUtS2UbTyKmZwbDAq7aIfA-T4Gnsg&e=>
<https://urldefense.us/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_blob_main_include_petsc-5Fkokkos.hpp&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=mm5WnvW66V9aFezISyisTVEya_MgbI4YjpAuorp4BHdklRfAD8kTzaDBY3VlzI-4&s=DWQqfHRdrciXObsAIEgF4mGXbMH1xx2vIpcM07ncznU&e=>
from here:
https://gitlab.com/petsc/petsc/-/blob/main/include/petsc_kokkos.hpp<https://urldefense.us/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_blob_main_include_petsc-5Fkokkos.hpp&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=mm5WnvW66V9aFezISyisTVEya_MgbI4YjpAuorp4BHdklRfAD8kTzaDBY3VlzI-4&s=DWQqfHRdrciXObsAIEgF4mGXbMH1xx2vIpcM07ncznU&e=>
remains null because the code to initialize it is skipped here:
https://gitlab.com/petsc/petsc/-/blob/main/src/sys/objects/kokkos/kinit.kokkos.cxx#L28<https://urldefense.us/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_blob_main_src_sys_objects_kokkos_kinit.kokkos.cxx-23L28&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=mm5WnvW66V9aFezISyisTVEya_MgbI4YjpAuorp4BHdklRfAD8kTzaDBY3VlzI-4&s=qjM7d6j2BTI04hPQnjucl2H1osvGvortk9kn9e20Hww&e=>
See line 71.
Can this be modified to allow for kokkos to have been initialized by the application before initializing petsc?
Thank you for your help,
Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230627/388fc8f2/attachment-0001.html>
