[petsc-users] Questions on CPR preconditioner
Barry Smith bsmith at petsc.dev
Sun Jun 25 13:25:33 CDT 2023
It is pasted below
> On Jun 25, 2023, at 1:40 PM, Edoardo alinovi <edoardo.alinovi at gmail.com> wrote:
> Hi Barry,
> thanks for pointing me out to that discussion! Unfortunately I am getting issues with this link:  http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190302/b0c1ad29/attachment.mht , any chance it is a dead one?
> Cheers
Content-Type: text/plain
Content-Disposition: inline
  Ok, I have implemented the algorithm using PETSc PCCOMPOSITE and PCGALERKIN and get identical iterations as the code you sent. PCFIELDSPLIT is not intended for this type of solver composition. Here is the algorithm written in "two-step" form
  x_1/2   = P KSPSolve( R A P, using BoomerAMG) R b
  x          =  x_1/2 + PCApply( A, using Hypre PILUT preconditioner) ( b - A x_1/2)
PCCOMPOSITE with a type of multiplicative handles the two steps and PCGALERKIN handles the P KSPSolve(R A P) R business.
You will need to use the master version of PETSc because I had to add a feature to PCGALERKIN to allow the solver to be easily used for and A that changes values for later solvers.
Here is the output from -ksp_view
KSP Object: 1 MPI processes
 type: fgmres
   GMRES: restart=100, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
   GMRES: happy breakdown tolerance 1e-30
 maximum iterations=10000, initial guess is zero
 tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
 right preconditioning
 using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
 type: composite
 Composite PC type - MULTIPLICATIVE
 PCs on composite preconditioner follow
   PC Object: (sub_0_) 1 MPI processes
     type: galerkin
     Galerkin PC
     KSP on Galerkin follow
     KSP Object: (sub_0_galerkin_) 1 MPI processes
       type: richardson
         Richardson: damping factor=1.
       left preconditioning
       using PRECONDITIONED norm type for convergence test
     PC Object: (sub_0_galerkin_) 1 MPI processes
       type: hypre
         HYPRE BoomerAMG preconditioning
         HYPRE BoomerAMG: Cycle type V
         HYPRE BoomerAMG: Maximum number of levels 25
         HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
         HYPRE BoomerAMG: Convergence tolerance PER hypre call 0.
         HYPRE BoomerAMG: Threshold for strong coupling 0.25
         HYPRE BoomerAMG: Interpolation truncation factor 0.
         HYPRE BoomerAMG: Interpolation: max elements per row 0
         HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
         HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
         HYPRE BoomerAMG: Maximum row sums 0.9
         HYPRE BoomerAMG: Sweeps down         1
         HYPRE BoomerAMG: Sweeps up           1
         HYPRE BoomerAMG: Sweeps on coarse    1
         HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
         HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
         HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
         HYPRE BoomerAMG: Relax weight  (all)      1.
         HYPRE BoomerAMG: Outer relax weight (all) 1.
         HYPRE BoomerAMG: Using CF-relaxation
         HYPRE BoomerAMG: Not using more complex smoothers.
         HYPRE BoomerAMG: Measure type        local
         HYPRE BoomerAMG: Coarsen type        Falgout
         HYPRE BoomerAMG: Interpolation type  classical
       linear system matrix = precond matrix:
       Mat Object: 1 MPI processes
         type: seqaij
         rows=50, cols=50
         total: nonzeros=244, allocated nonzeros=244
         total number of mallocs used during MatSetValues calls =0
           not using I-node routines
       type: seqaij
       rows=100, cols=100, bs=2
       total: nonzeros=976, allocated nonzeros=100000
         using I-node routines: found 50 nodes, limit used is 5
   PC Object: (sub_1_) 1 MPI processes
     type: hypre
       HYPRE Pilut preconditioning
       HYPRE Pilut: maximum number of iterations 1
       HYPRE Pilut: drop tolerance 0.1
       HYPRE Pilut: default factor row size
       type: seqaij
Note that one can change the solvers on the two "stages" and all their options such as tolerances etc using the options database a proper prefixes which you can find in the output above. For example to use PETSc's ILU instead of hypre's just run with -sub_1_pc_type ilu or to use a direct solver instead of boomer -sub_0_galerkin_pc_type lu
I've attached a new version of testmain2.c that runs your solver and also my version.
Given the "unique" nature of your R = [ I I ... I] and P = [0 I 0 0 ... 0] I am not sure that it makes sense to include this preconditioner directly in PETSc as a new PC type; so if you are serious about using it you can take what I am sending back and modify it for your needs.  As a numerical analyst who works on linear solvers I am also not convinced that this is likely to be a particular good preconditioner
 Let me know if you have any questions,
  Barry
Content-Type: text/plain; name=testmain2.c
Content-Disposition: attachment; filename=testmain2.c
// make && mpirun -np 2 ./testmain2 -ksp_error_if_not_converged
#include "MCPR.h"
      Computes the submatrix associated with the Galerkin subproblem Ap = R A P
PetscErrorCode ComputeSubmatrix(PC pc,Mat A, Mat Ap, Mat *cAp,void *ctx)
 PetscErrorCode ierr;
 PetscInt       b,Am,An,start,end,first = 0, offset = 1;
 IS             is,js;
 Mat            Aij;
 PetscFunctionBegin;
 ierr = MatGetLocalSize(A,&Am,&An);CHKERRQ(ierr);
 ierr = MatGetBlockSize(A,&b);CHKERRQ(ierr);
 ierr = MatGetOwnershipRange(A, &start, &end);CHKERRQ(ierr);
 ierr = ISCreateStride(PetscObjectComm((PetscObject)A),Am/b,start+offset,b,&js);CHKERRQ(ierr);
 if (!Ap) {
   ierr  = ISCreateStride(PetscObjectComm((PetscObject)A),An/b,start+0,b,&is);CHKERRQ(ierr);
   ierr  = MatGetSubMatrix(A,is,js,MAT_INITIAL_MATRIX,&Ap);CHKERRQ(ierr);
   ierr  = ISDestroy(&is);CHKERRQ(ierr);
   *cAp  = Ap;
   first = 1;
 } else {
   ierr = MatZeroEntries(Ap);CHKERRQ(ierr);
 for(PetscInt k=first;k<b;++k) {
   ierr = ISCreateStride(PetscObjectComm((PetscObject)A),An/b,start+k,b,&is);CHKERRQ(ierr);
   ierr = MatGetSubMatrix(A,is,js,MAT_INITIAL_MATRIX,&Aij);CHKERRQ(ierr);
   ierr = MatAXPY(Ap,1.0,Aij,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
   ierr = MatDestroy(&Aij);CHKERRQ(ierr);
 ierr = ISDestroy(&js);CHKERRQ(ierr);
 PetscFunctionReturn(0);
   Apply the restriction operator for the Galkerin problem
PetscErrorCode ApplyR(Mat A, Vec x,Vec y)
 PetscInt       b;
 PetscFunctionBegin;
 ierr = VecGetBlockSize(x,&b);CHKERRQ(ierr);
 ierr = VecStrideGather(x,0,y,INSERT_VALUES);CHKERRQ(ierr);
 for (PetscInt k=1;k<b;++k) {ierr = VecStrideGather(x,k,y,ADD_VALUES);CHKERRQ(ierr);}
   Apply the interpolation operator for the Galerkin problem
PetscErrorCode ApplyP(Mat A, Vec x,Vec y)
 PetscInt       offset = 1;
 PetscFunctionBegin;
 ierr = VecStrideScatter(x,offset,y,INSERT_VALUES);CHKERRQ(ierr);
int main( int argc, char *argv[] )
 	PetscInitialize(&argc,&argv,PETSC_NULL,PETSC_NULL);
 	int rank, size;
	MPI_Comm_rank (MPI_COMM_WORLD, &rank);	/* get current process id */
	MPI_Comm_size (MPI_COMM_WORLD, &size);	/* get number of processes */
	MPI_Comm C = PETSC_COMM_WORLD;
	PetscRandom    rnd;
	PetscRandomCreate(C,&rnd);
	PetscRandomSetInterval(rnd,0.0,1.0);
	PetscRandomSetFromOptions(rnd);
	int M = 100;
	int N = size*M;
	Mat A = getSampleMatrix(M);
	Mat T1 = getT1(A,1);
	Mat T2 = getT2(A,0.1);
	Mat MCPR = getMCPR(A,T1,T2);
	Vec u,v,w,z;
	VecCreate(C,&u);
	VecSetBlockSize(u,2);
	VecSetSizes(u,M,N);
	VecSetFromOptions(u);
	VecDuplicate(u,&v);
	VecDuplicate(u,&w);
	VecDuplicate(u,&z);
	VecSetRandom(u,rnd);
	Mat mats[] = {T2,MCPR};
	const char *names[] = {"T2","MCPR"};
	for(int k=1;k<2;++k) {
		KSP solver;
		KSPCreate(C,&solver);
		KSPSetOperators(solver,A,A);
		KSPSetType(solver,KSPFGMRES);
		KSPGMRESSetRestart(solver,N);
		PC pc;
		KSPGetPC(solver,&pc);
		putMatrixInPC(pc,mats[k]);
       KSPSetFromOptions(solver);
       KSPSolve(solver,u,v);
		KSPConvergedReason reason;
		int its;
		KSPGetConvergedReason(solver,&reason);
		KSPGetIterationNumber(solver,&its);
		PetscPrintf(PETSC_COMM_WORLD,"testmain2: %s converged reason %d; iterations %d.\n",names[k],reason,its);
	    KSPView(solver,PETSC_VIEWER_STDOUT_WORLD);
		KSPDestroy(&solver);
                  The preconditioner is
                  where the first line is implemented using PCGALERKIN with BoomerAMG on the subproblem so can be written as
                                        x_1/2   = PCApply(A, using PCGALERKIN with KSPSolve( R A P, using BoomerAMG) as the inner solver
                  Which is implemented using the PETSc PCCOMPOSITE preconditioner of type multiplicative so can be written as
         x = PCApply(A, using PCCOMPOSITE using (PCGALERKIN with KSPSolve( R A P, using BoomerAMG) as the inner solver) as the first solver and PCApply( A, using Hypre PILUT preconditioner) as the second solver)
       KSP ksp;
       ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
       ierr = KSPSetType(ksp,KSPFGMRES);CHKERRQ(ierr);
       ierr = KSPGMRESSetRestart(ksp,100);CHKERRQ(ierr);
       ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
       PC pc;
       ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
       ierr = PCSetType(pc,PCCOMPOSITE);CHKERRQ(ierr);
       ierr = PCCompositeSetType(pc,PC_COMPOSITE_MULTIPLICATIVE);CHKERRQ(ierr);
       /* Create first sub problem solver Hypre boomerAMG on Ap */
       PC t1;
       ierr = PCCompositeAddPC(pc,PCGALERKIN);CHKERRQ(ierr);
       ierr = PCCompositeGetPC(pc,0,&t1);CHKERRQ(ierr);
       KSP Ap_ksp;
       ierr = PCGalerkinGetKSP(t1,&Ap_ksp);CHKERRQ(ierr);
       ierr = KSPSetType(Ap_ksp,KSPRICHARDSON);CHKERRQ(ierr);
       PC Ap_pc;
       ierr = KSPGetPC(Ap_ksp,&Ap_pc);CHKERRQ(ierr);
       ierr = PCSetType(Ap_pc,PCHYPRE);CHKERRQ(ierr);
       /* this tells the PC how to compute the reduced matrix */
       ierr = PCGalerkinSetComputeSubmatrix(t1,ComputeSubmatrix,NULL);CHKERRQ(ierr);
       PetscInt b,Am,An;
	int start,end;
       /* create the R operator */
       Mat R;
       ierr = MatCreateShell(PetscObjectComm((PetscObject)A),Am/b,An,PETSC_DETERMINE,PETSC_DETERMINE,NULL,&R);
       ierr = MatShellSetOperation(R,MATOP_MULT,(void (*)(void))ApplyR);CHKERRQ(ierr);
       ierr = PCGalerkinSetRestriction(t1,R);CHKERRQ(ierr);
       /* create the P operator */
       Mat P;
       ierr = MatCreateShell(PetscObjectComm((PetscObject)A),Am,An/b,PETSC_DETERMINE,PETSC_DETERMINE,NULL,&P);
       ierr = MatShellSetOperation(P,MATOP_MULT,(void (*)(void))ApplyP);CHKERRQ(ierr);
       ierr = PCGalerkinSetInterpolation(t1,P);CHKERRQ(ierr);
       /*  Create the second subproblem solver Block ILU */
       PC t2;
       ierr = PCCompositeAddPC(pc,PCHYPRE);CHKERRQ(ierr);
       ierr = PCCompositeGetPC(pc,1,&t2);CHKERRQ(ierr);
	ierr = PCSetType(t2,PCHYPRE);CHKERRQ(ierr);
	ierr = PetscOptionsSetValue(NULL,"-sub_1_pc_hypre_pilut_maxiter","1");
       char s[100];
	sprintf(s,"%e",.1);
	ierr = PetscOptionsSetValue(NULL,"-sub_1_pc_hypre_pilut_tol",s);CHKERRQ(ierr);
	ierr = PCHYPRESetType(t2,"pilut");CHKERRQ(ierr);
       ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
       ierr = VecZeroEntries(v);CHKERRQ(ierr);
       ierr = KSPSolve(ksp,u,v);CHKERRQ(ierr);
       ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
	return 0;
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: quoted-printable
> On Jan 23, 2017, at 8:25 AM, S=C3=A9bastien Loisel <sloisel at gmail.com <mailto:sloisel at gmail.com>> wr=
ote:
>=20
> Hi Barry,
>=20
> Thanks for your email. Thanks for pointing out my PetSC sillyness. I thin=
k what happened is I played with matrices as well as with preconditioners s=
o I initially implemented it as MATSHELL and at the end wrapped it in a PCS=
HELL. :)
>=20
> On Mon, Jan 23, 2017 at 2:26 AM, Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
> I've started to look at this; it is a little weird using MATSHELL within =
your PCSHELL, seems unnecessary. Not necessarily wrong, just strange. I'll =
continue to try to understand it.
>=20
>   Barry
>=20
>=20
>=20
> > On Jan 20, 2017, at 5:48 PM, S=C3=A9bastien Loisel <sloisel at gmail.com <mailto:sloisel at gmail.com>> =
wrote:
> > OK I'm attaching the prototype.
> > It won't be 100% plug-and-play for you because in principle T1 and T2 a=
re built on top of "sub-preconditioners" (AMG for T1 and BILU for T2) and j=
udging from the PetSC architecture elsewhere I must assume you're going to =
want to expose those in a rational way. At present, I've hard-coded some su=
b-preconditioners, and in particular for T2 I had to resort to PILUT becaus=
e I didn't have a BILU(0) handy.
> > Also, I broke the PetSC law and my functions don't return integers, so =
I also assume you're going to want to tweak that... Sorry!
> > On Fri, Jan 20, 2017 at 11:29 PM, Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrot=
e:
> >   Sure, email the PCSHELL version, best case scenario  I only need chan=
ge out the PCSHELL and it takes me 5 minutes :-)
> > > On Jan 20, 2017, at 5:07 PM, S=C3=A9bastien Loisel <sloisel at gmail.com <mailto:sloisel at gmail.com>=
> wrote:
> > > Hi all,
> > > Thanks for your emails. I'm willing to help in whatever way. We have =
a "PCSHELL" prototype we can provide on request, although PetSC experts can=
no doubt do a better job than I did.
> > > Thanks,
> > > On Fri, Jan 20, 2017 at 9:50 PM, Robert Annewandter <robert.annewandt=
er at opengosim.com <mailto:er at opengosim.com>> wrote:
> > > Indeed that would be very helpful! We're very happy to support to tes=
t things out, provide feedback etc
> > > Many thanks!
> > > Robert
> > > On 20/01/17 21:22, Hammond, Glenn E wrote:
> > >> That sounds great.  I do know that there is also much interest state=
-side in CPR preconditioning within PFLOTRAN.  I have a Sandia colleague in=
Carlsbad, NM who has been asking about it.  I am sure that Sebastien and/o=
r Robert will help out in any way possible.
> > >> Thanks,
> > >> Glenn
> > >>> -----Original Message-----
> > >>> From: Barry Smith [
> > >>> Sent: Friday, January 20, 2017 12:58 PM
> > >>> To: Hammond, Glenn E
> > >>> <gehammo at sandia.gov <mailto:gehammo at sandia.gov>>
> > >>> Cc: S=C3=A9bastien Loisel
> > >>> ; Robert Annewandter
> > >>> <robert.annewandter at opengosim.com <mailto:robert.annewandter at opengosim.com>>; Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>>
> > >>> Paolo Orsini
> > >>> <paolo.orsini at opengosim.com <mailto:paolo.orsini at opengosim.com>>
> > >>> ; Matthew Knepley
> > >>> <knepley at gmail.com <mailto:knepley at gmail.com>>
> > >>> Subject: Re: [EXTERNAL] CPR preconditioning
> > >>>   Glenn,
> > >>>     Sorry about the delay in processing this, too much going on ...
> > >>>     I think the best thing is for us (the PETSc developers) to impl=
ement a CPR
> > >>> preconditioner "directly" as its own PC and then have you guys try =
it out. I am
> > >>> planning to do this.
> > >>>    Barry
> > >>>> On Jan 20, 2017, at 2:50 PM, Hammond, Glenn E <gehammo at sandia.gov <mailto:gehammo at sandia.gov>>
> > >>> wrote:
> > >>>> Barry, Jed or Matt,
> > >>>> Do you have any suggestions for how to address the limitations of
> > >>> PetscFieldSplit() discussed below.  Will they need to manipulate th=
e matrices
> > >>> manually?
> > >>>> Thanks,
> > >>>> Glenn
> > >>>> From: S=C3=A9bastien Loisel [
> > >>>> Sent: Wednesday, January 11, 2017 3:33 AM
> > >>>> To: Barry Smith
> > >>>> ; Hammond, Glenn E
> > >>>> <gehammo at sandia.gov <mailto:gehammo at sandia.gov>>; Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>>
> > >>>> ; Paolo Orsini
> > >>>> Subject: [EXTERNAL] CPR preconditioning
> > >>>> Dear Friends,
> > >>>> Paolo has asked me to write this email to clarify issues surroundi=
ng
> > >>>> the CPR preconditioner that is widely used in multiphase flow. I k=
now
> > >>>> Barry from a long time ago but we only met once when I was a PhD
> > >>>> student so I would be shocked if he remembered me. :)
> > >>>> I'm a math assistant professor and one of my areas of specializati=
on is linear
> > >>> algebra and preconditioning.
> > >>>> The main issue that is useful to clarify is the following. There w=
as a proposal
> > >>> to use PetSC's PETSCFIELDSPLIT in conjunction with PCCOMPOSITE in o=
rder to
> > >>> implement CPR preconditioning. Although this is morally the right i=
dea, this
> > >>> seems to be currently impossible because PETSCFIELDSPLIT lacks the
> > >>> capabilities it would need to implement the T1 preconditioner. This=
is due to
> > >>> limitations in the API exposed by PETSCFIELDSPLIT (and no doubt lim=
itations
> > >>> in the underlying implementation).
> > >>>> In order to be as clear as possible, please allow me to describe
> > >>> unambiguously the first of the two parts of the CPR preconditioner =
using
> > >>> some MATLAB snippets. Let I denote the N by N identity, and Z the N=
by N
> > >>> zero matrix. Put WT =3D [I I I] and C =3D [Z;Z;I]. The pressure mat=
rix is Ap =3D
> > >>> WT*A*C, and the T1 preconditioner is C*inv(Ap)*WT, where inv(Ap) is=
to be
> > >>> implemented with AMG.
> > >>>> This T1 preconditioner is the one that would have to be implemente=
d by
> > >>> PETSCFIELDSPLIT. The following limitations in PETSCFIELDSPLIT preve=
nts one
> > >>> to implement T1:
> > >>>>    =E2=80=A2 One must select the "pressure" by specifying an IS ob=
ject to
> > >>> PCFieldSplitSetIS(). However, since WT =3D [I I I], the pressure is=
obtained by
> > >>> summing over the three fields. As far as I can tell, an IS object d=
oes not allow
> > >>> one to sum over several entries to obtain the pressure field.
> > >>>>    =E2=80=A2 The pressure matrix is Ap =3D WT*A*C; note that the m=
atrix WT on
> > >>> the left is different from the matrix C on the right. However, PCFI=
ELDSPLIT
> > >>> has no notion of a "left-IS" vs "right-IS"; morally, only diagonal =
blocks of A can
> > >>> be used by PCFIELDSPLIT.
> > >>>>    =E2=80=A2 PCFIELDSPLIT offers a range of hard-coded block struc=
tures for the
> > >>> final preconditioner, but the choice T1 =3D C*inv(Ap)*WT is not one=
of these
> > >>> choices. Indeed, this first stage CPR preconditioner T1 is *singula=
r*, but there
> > >>> is no obvious way for PCFIELDSPLIT to produce a singular preconditi=
oner.
> > >>>> Note that the documentation for PETSCFIELDSPLIT says that "The
> > >>> Constrained Pressure Preconditioner (CPR) does not appear to be cur=
rently
> > >>> implementable directly with PCFIELDSPLIT". Unless there are very si=
gnificant
> > >>> capabilities that are not documented, I don't see how CPR can be
> > >>> implemented with PETSCFIELDSPLIT.
> > >>>> Elsewhere, someone proposed putting the two preconditioners T1 and=
T2
> > >>>> on each side of A, e.g. T1*A*T2. That is a very bad idea because T=
1 is
> > >>>> singular and hence T1*A*T2 is also singular. The correct CPR
> > >>>> preconditioner is nonsingular despite the fact that T1 is singular,
> > >>>> and MCPR is given by the formula MCPR =3D T2*(I-A*T1)+T1, where T2=
=3D
> > >>>> BILU(0) of A. (There is a proof, due to Felix Kwok, that BILU(0) w=
orks
> > >>>> even though ILU(0) craps out on vanishing diagonal entries.)
> > >>>> I'm also attaching a sample MATLAB code that runs the CPR precondi=
tioner
> > >>> on some fabricated random matrix A. I emphasize that this is not a =
realistic
> > >>> matrix, but it still illustrates that the algorithm works, and that=
MCPR is better
> > >>> than T2 alone. Note that T1 cannot be used alone since it is singul=
ar. Further
> > >>> gains are expected when the Robert's realistic code with correct ph=
ysics will
> > >>> come online.
> > >>>> <image003.jpg>
> > >>>> I hope this clarifies some things.
> > >>>> Assistant Professor
> > >>>> Department of Mathematics, Heriot-Watt University Riccarton, EH14 =
4AS,
> > >>>> United Kingdom
> > >>>> web:
> > >>>> http://www.ma.hw.ac.uk/~loisel/
> > >>>> email: S.Loisel at
> > >>>> hw.ac.uk <http://hw.ac.uk/>
> > >>>> phone:
> > >>>> +44 131 451 3234
> > >>>> fax:
> > >>>> +44 131 451 3249
> > > Assistant Professor
> > > Riccarton, EH14 4AS, United Kingdom
> > > web: http://www.ma.hw.ac.uk/~loisel/
> > > email: S.Loisel at hw.ac.uk <http://hw.ac.uk/>
> > > phone: +44 131 451 3234
> > > fax: +44 131 451 3249
> > Assistant Professor
> > <petsc.zip>
>=20
>=20
>=20
>=20
> --=20
> Assistant Professor
>=20
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230625/7c386e61/attachment-0003.html>
