[petsc-users] snes_type aspin without DA example
Karin&NiKo niko.karin at gmail.com
Fri Jun 23 05:12:50 CDT 2023
In order to transfer from Python to C a list of int, real or bool as an
input, there are the functions iarray_i, iarray_r and iarray_b.
In order to transfer from C to Python a list of int, real, bool or pointers
as an output, there are the functions oarray_i, oarray_r, oarray_b and
oarray_p.
Nevertheless I do not find the function iarray_p which (I think) is
required to transfer a list of Scatter when calling SNESNASMSetSubdomains.
Am I right ?
Le ven. 23 juin 2023 à 09:40, Karin&NiKo <niko.karin at gmail.com> a écrit :
> Dear Barry,
> I have started looking at the code but I miss an example using
> SNESNASMSetSubdomains. In fact I do not even find a single use of the
> function in PETSc.
> Could someone provide me with an example ?
> Thanks,
> Nicolas
> Le ven. 23 juin 2023 à 02:17, Barry Smith <bsmith at petsc.dev> a écrit :
>>   A test would be great.
>> On Jun 22, 2023, at 3:20 PM, Karin&NiKo <niko.karin at gmail.com> wrote:
>> Thank you Barry. I will try this.
>> Should I provide a test in src/binding/petsc4py/test/test_snes.py ?
>> Le jeu. 22 juin 2023 à 20:41, Barry Smith <bsmith at petsc.dev> a écrit :
>>>   You are not missing anything. The petsc4py stub for
>>> SNESNASMSetSubdomains() has not been written. You could add it by adding to
>>> src/petsc4py/PETSc/SNES.pyx and src/petsc4py/PETSc/petscsnes.pxi and
>>> then make a merge request
>>> https://petsc.org/release/developers/contributing/ to get it into PETSc.
>>> On Jun 22, 2023, at 1:54 PM, Karin&NiKo <niko.karin at gmail.com> wrote:
>>> Dear PETSc team,
>>> I would like to play with aspin-type nonlinear solvers. I have found
>>> several tests like snes/tutorials/ex19.c but they all use DA, which I don't
>>> want to use since I need to stick at the algebraic level.
>>> Then, I started looking at petsc4py/demo/ode/heat.py and tried to set up
>>> things.
>>> Unfortunately, I get the error "DM has no default decomposition
>>> defined.  Set subsolves manually with SNESNASMSetSubdomains()" which, I
>>> think, I do understand.
>>> But I do not find any implementation of the SNESNASMSetSubdomains in
>>> petsc4py.
>>> Am I missing something ?
>>> Thanks,
>>> Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230623/d6cae5d5/attachment.html>
