[petsc-users] How to efficiently fill in, in parallel, a PETSc matrix from a COO sparse matrix?
Wed Jun 21 08:49:49 CDT 2023
On Wed, Jun 21, 2023 at 9:22 AM Diego Magela Lemos <diegomagela at usp.br>
wrote:
> Please, could you provide a minimal working example (or link) of how to do
> this?
You can see here
  https://petsc.org/main/src/ksp/ksp/tutorials/ex2.c.html
that each process only sets values for the rows it owns.
     Matt
> Thank you.
> Em ter., 20 de jun. de 2023 às 15:08, Matthew Knepley <knepley at gmail.com>
> escreveu:
>> On Tue, Jun 20, 2023 at 2:02 PM Diego Magela Lemos <diegomagela at usp.br>
>> wrote:
>>> So... what do I need to do, please?
>>> Why am I getting wrong results when solving the linear system if the
>>> matrix is filled in with MatSetPreallocationCOO and MatSetValuesCOO?
>> It appears that you have _all_ processes submit _all_ triples (i, j, v).
>> Each triple can only be submitted by a single process. You can fix this in
>> many ways. For example, an easy but suboptimal way is just to have process
>> 0 submit them all, and all other processes submit nothing.
>>   Thanks,
>>   Matt
>>> Em ter., 20 de jun. de 2023 às 14:56, Jed Brown <jed at jedbrown.org>
>>> escreveu:
>>>> Matthew Knepley <knepley at gmail.com> writes:
>>>> >> The matrix entries are multiplied by 2, that is, the number of
>>>> processes
>>>> >> used to execute the code.
>>>> > No. This was mostly intended for GPUs, where there is 1 process. If
>>>> you
>>>> > want to use multiple MPI processes, then each process can only
>>>> introduce
>>>> > some disjoint subset of the values. This is also how MatSetValues()
>>>> works,
>>>> > but it might not be as obvious.
>>>> They need not be disjoint, just sum to the expected values. This
>>>> interface is very convenient for FE and FV methods. MatSetValues with
>>>> ADD_VALUES has similar semantics without the intermediate storage, but it
>>>> forces you to submit one element matrix at a time. Classic parallelism
>>>> granularity versus memory use tradeoff with MatSetValuesCOO being a clear
>>>> win on GPUs and more nuanced for CPUs.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230621/3582b14b/attachment.html>
