[petsc-users] Question about using MatCreateAIJ
Karsten Lettmann karsten.lettmann at uni-oldenburg.de
Sun Jun 18 03:26:32 CDT 2023
Dear Matthew,
thanks for you help.
1) I tested your suggestion to pass NULL as the arguments for the
MatXAIJSetPreallocation.
So the old version was:
CALL
MatCreateMPIAIJ(MPI_GROUP,N_local,N_local,N_global,N_global,0,DNNZ,0,ONNZ,A,IERR)
And after you suggestion it is now:
   CALL MatCreate(MPI_GROUP,A,IERR)
   CALL MatSetType(A,MATAIJ,IERR)
   CALL MatSetSizes(A,N_local,N_local,N_global,N_global,IERR)
   CALL
MatXAIJSetPreallocation(A,1,DNNZ,ONNZ,PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,IERR)
   Setting block-size = 1.
2) Concerning the error with MatResetPreallocation:
We have an iterative loop, in which the matrix A is filled very often
with different non-zero structure.
Further, I read in the manual pages that due to performance issues, one
should preallocate enough space, as operations as matsetvalues might be
time consuming due to additional
on-demand allocations.
So I did the following coding in principle:
     Set matrix A the first time with preallocation
     iteration-loop start
         MatResetPreallocation(A,...)
         MatZeroEntries (A)
         Fill Matrix A
         MatAssemblyXX(A_WAVE,MAT_FINAL_ASSEMBLY,IERR)
     iteration-loop end
With these settings, the code run with 2 CPU.
But with 1 CPU I got an error, which was in MatResetPreallocation.
I could not understand, why the above code works with 2 CPU but not with
1 CPU.
At the moment, I believe the reason for this error seems to be a
pre-check, that is done in SeqAIJ but not in MPIAIJ fo a valid and
present matrix A.
(Now, an image is included showing the codings of   :
https://petsc.org/release/src/mat/impls/aij/seq/aij.c.html#MatResetPreallocation_SeqAIJ
https://petsc.org/release/src/mat/impls/aij/mpi/mpiaij.c.html#MatResetPreallocation_MPIAIJ
So, it seems for me at the moment, that the first MatResetPreallocation
(when the iteration loop is entered the first time) is done on an
not-assembled matrix A.
So for one CPU I got an error, while 2 CPUs seem to have been more tolerant.
(I'm not sure, if this interpretation is correct.)
So, I changed the coding in that way, that I check the assembly status
before the preallocation.
Using the coding:
     CALL MatAssembled(A,A_assembled,ierr)
     IF (A_assembled .eqv. PETSC_TRUE) then
         CALL MatResetPreallocation(A,ierr)
     ENDIF
then worked for 1 and 2 CPU.
3) There was another finding, which hopefully is correct.
Actually, I did this MatResetPreallocation to have a better performance
when filling the matrix A later, as was suggested on the manual pages.
However, I found (if I did nothing wrong) that this
MatResetPreallocation was much more time consuming than the additional
(and unwanted) allocations done during filling the matrix.
So, in the end, my code seems to be faster, when *not* doing this in the
iteration loop:
     ENDIF
As I told you, I'm a beginner to PETSC and I do not know, if I have done
it correctly???
Best, Karsten
> The arguments are a combination of the AIJ and SBAIJ arguments. You
> can just pass NULL for the SBAIJ args.
>     Then I  ran into issues with Resetpreallocation, that I do not
>     understand.
> Can you send the error?
>   Thanks,
>     Matt
>     I want this, because we have an iterative procedure, where the
>     matrix A_wave and its non-zero structure are changing very often.
>     I try to find the reason for my problem.
>     I really thank you for your answer, that helped me to understand
>     things a bit.
>     I wish you all the best, Karsten
>     Am 15.06.23 um 16:51 schrieb Matthew Knepley:
>>     ACHTUNG!Diese E-Mail kommt von Extern! WARNING! This email
>>     originated off-campus.
>>     On Thu, Jun 15, 2023 at 8:32 AM Karsten Lettmann
>>     <karsten.lettmann at uni-oldenburg.de
>>     <mailto:karsten.lettmann at uni-oldenburg.de>> wrote:
>>         Dear all,
>>         I'm quite new to PETSC. So I hope the following questions are
>>         not too
>>         stupid.
>>         1) We have a (Fortran) code, that we want to update from an
>>         older PETSC
>>         version (petsc.2.3.3-p16) to a newer version.
>>         Inside the old code, for creating matrices A, there are
>>         function calls
>>         of the from:
>>         MatCreateMPIAIJ
>>         In the reference page for this old version it says:
>>         When calling this routine with a single process communicator,
>>         a matrix
>>         of type SEQAIJ is returned.
>>         So I assume the following behavior of this old routine:
>>         - for N_proc == 1:
>>             a matrix of type SEQAIJ is returned.
>>         - for N_proc > 1:
>>             a matrix of type MPIAIJ is returned
>>         2a) So, in the new code, we want to have a similar behavior.
>>         I found that this function is not present any more in the
>>         newer PETSC
>>         versions.
>>         Instead, one might use: MatCreateAIJ(….)
>>         ( https://petsc.org/release/manualpages/Mat/MatCreateAIJ/ )
>>         If I understand the reference page of the function correctly,
>>         then,
>>         actually, a similar behavior should be expected:
>>         - for N_proc == 1:
>>         - for N_proc > 1:
>>         2b) However, on the reference page, there is the note:
>>         It is recommended that one use the MatCreate(), MatSetType()
>>         and/or
>>         MatSetFromOptions(), MatXXXXSetPreallocation() paradigm
>>         instead of this
>>         routine directly.
>>         So, if I want the behavior above, it is recommended to code
>>         it like
>>         this, isn't it:
>>         If (N_Proc == 1)
>>              MatCreate(.. ,A ,...)
>>              MatSetType(…,A, MATSEQAIJ,..)
>>              MatSetSizes(…,A, ..)
>>              MatSeqAIJSetPreallocation(,...A,...)
>>         else
>>              MatSetType(…,A, MATMPIAIJ,..)
>>              MatMPIAIJSetPreallocation(,...A,...)
>>     You can use
>>       MatCreate(comm, &A);
>>       MatSetType(A, MATAIJ);
>>       MatSetSizes(A, ...);
>>       MatXAIJSetPreallocation(A, ...);
>>     We recommend this because we would like to get rid of the
>>     convenience functions that
>>     wrap up exactly this code.
>>       Thanks,
>>          Matt
>>         end
>>         3) So my questions are:
>>         - Is my present understanding correct?
>>         If  yes:
>>         - Why might using MatCreateAIJ(….) for my case not be helpful?
>>         - So, why is it recommended to use the way 2b) instead of this
>>         MatCreateAIJ(….) ?
>>         Best, Karsten
>>         ICBM
>>         Section: Physical Oceanography
>>         Universitaet Oldenburg
>>         Postfach 5634
>>         D-26046 Oldenburg
>>         Germany
>>         Tel:    +49 (0)441 798 4061
>>         email: karsten.lettmann at uni-oldenburg.de
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
>>     https://www.cse.buffalo.edu/~knepley/
>>     <http://www.cse.buffalo.edu/~knepley/>
>     ICBM
>     Postfach 5634
>     D-26046 Oldenburg
>     Germany
>     email:karsten.lettmann at uni-oldenburg.de  <mailto:karsten.lettmann at uni-oldenburg.de>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
ICBM
Postfach 5634
D-26046 Oldenburg
Germany
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230618/dc7f1147/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230618/dc7f1147/attachment-0001.png>
