[petsc-users] IS natural numbering to global numbering
YuSh Lo ysjosh.lo at gmail.com
Sun Jun 18 00:18:25 CDT 2023
Hi Matthew,
After setting DMSetUseNatural to true and calling DMPlexGetGlobalToNatural,
I call PestcSFView right away, it gives segmentation fault.
I have also tried DMGetNaturalSF, it also gives segmentation fault when
calling PetscSFView.
I use PETSC_VIEWER_STDOUT_WORLD as PetscViewer
Josh
Matthew Knepley <knepley at gmail.com> 於 2023年6月9日 週五 下午1:04寫道:
> On Fri, Jun 9, 2023 at 1:46 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>> Hi Barry,
>> Is there any way to use the mapping generated by DMPlexDistribute along
>> with AO?
> For Plex, if you turn on
>   https://petsc.org/main/manualpages/DM/DMSetUseNatural/
> before DMPlexDistribute(), it will compute and store a GlobalToNatural
> map. This can be
> used to map vectors back and forth, but you can extract the SF
>   DMPlexGetGlobalToNaturalSF
> <https://petsc.org/main/manualpages/DMPlex/DMPlexGetGlobalToNaturalSF/>
> and use that to remap your IS, by extracting the indices.
>   THanks,
>      Matt
>> Thanks,
>> Josh
>> Barry Smith <bsmith at petsc.dev> 於 2023年6月9日 週五 上午10:42寫道:
>>>   You might be looking for
>>> https://petsc.org/release/manualpages/AO/AO/#ao
>>> On Jun 9, 2023, at 11:02 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> An IS is just an array of integers. We need your context.
>>> Is this question for sparse matrices? If so look at the documentation on
>>> the AIJ matrix construction and the global vertex numbering system.
>>> Mark
>>> On Thu, Jun 8, 2023 at 1:15 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>>>> Hi,
>>>> I have an IS that contains some vertex that is in natural numbering.
>>>> How do I map them to global numbering without being distributed?
>>>> Thanks,
>>>> Josh
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230618/b2b5b34d/attachment.html>
