[petsc-users] Start logging with -info after PetscInitialize()
Jeremy Theler (External) jeremy.theler-ext at ansys.com
Tue Jun 13 09:16:16 CDT 2023
Hello all.
I've asked this question to Satish personally last week at the conference, but I'm stuck so any help would be appreciated.
For some reason not worth explaining, I need to activate -info after PetscInitialize() has been already called.
I'm trying something like this:
PetscOptionsSetValue(NULL, "-info", NULL);
PetscInfoSetFromOptions(NULL);
The second call fails with
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: PetscInfoSetClasses() cannot be called after PetscInfoGetClass() or PetscInfoProcessClass()
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.19.2, Jun 01, 2023
[0]PETSC ERROR: reflexCLI on a double-int32-release named LIN54Z7SQ3 by jtheler Tue Jun 13 11:08:29 2023
[0]PETSC ERROR: Configure options --download-eigen --download-hdf5 --download-hypre --download-metis --download-mumps --download-parmetis --download-pragmatic --download-scalapack --download-slepc --with-64-bit-indices=no --with-debugging=no --with-precision=double --with-scalar-type=real COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 --download-egads --download-opencascade --download-tetgen
[0]PETSC ERROR: #1 PetscInfoSetClasses() at /home/jtheler/libs/petsc-3.19.2/src/sys/info/verboseinfo.c:182
[0]PETSC ERROR: #2 PetscInfoSetFromOptions() at /home/jtheler/libs/petsc-3.19.2/src/sys/info/verboseinfo.c:407
But if I ignore the non-zero return value and I allow my program to continue, the required logging is enabled.
I also tried using a local PetscOptions object but the result is the same.
Any ideas to avoid that wrong state error?
Thanks
jeremy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230613/0274fee5/attachment.html>
