[petsc-users] Inquiry about the definitely lost memory
neil liu liufield at gmail.com
Fri Jun 9 15:33:29 CDT 2023
Thanks a lot,  Matt and Barry.
Indeed, I found the original leak that will lead to something related to
DMGetWorkArray.
==15547== 50,000 bytes in 1 blocks are definitely lost in loss record 2,786
of 2,791
==15547==    at 0x4C37135: malloc (vg_replace_malloc.c:381)
==15547==    by 0x9BE4E43: MPL_malloc (mpl_trmem.h:373)
==15547==    by 0x9BE6B3B: PMIU_cmd_add_int (pmi_wire.c:538)
==15547==    by 0x9BEB7C6: PMIU_msg_set_query_abort (pmi_msg.c:322)
==15547==    by 0x9BE16F0: PMI_Abort (pmi_v1.c:327)
==15547==    by 0x9A8E3E7: MPIR_pmi_abort (mpir_pmi.c:243)
==15547==    by 0x9B20BC7: MPID_Abort (mpid_abort.c:67)
==15547==    by 0x9A22823: MPIR_Abort_impl (init_impl.c:270)
==15547==    by 0x97FFF02: internal_Abort (abort.c:65)
==15547==    by 0x98000C3: PMPI_Abort (abort.c:112)
==15547==    by 0x58FE116: PetscError (err.c:403)
==15547==    by 0x410CA3: main (ex1.c:764) //Call DMDestroy();
On Fri, Jun 9, 2023 at 12:38 PM Barry Smith <bsmith at petsc.dev> wrote:
>   This are MPI objects PETSc creates in  PetscInitialize(), for successful
> runs they should all be removed in PETSc finalize, hence they should not
> appear as valgrind links.
>   Are you sure PetscFinalize() is called and completes?
>   We'll need the exact PETSc version you are using to know exactly which
> MPI object is not being destroyed.
>   Barry
> > On Jun 9, 2023, at 12:01 PM, neil liu <liufield at gmail.com> wrote:
> > Dear Petsc developers,
> > I am using valgrind to check the memory leak. It shows,
> > <image.png>
> > Finally, I found that DMPlexrestoretrasitiveclosure can resolve this
> memory leak.
> > My question is from the above screen shot, it seems the leak is related
> to MPI. How can I relate that reminder to DMPlexrestoretrasitiveclosure ?
> > Thanks,
> > Xiaodong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230609/67efb588/attachment.html>
