[petsc-users] Failed to configure on Windows with latest Intel OneAPI
Hawk Shaw arsennnic at gmail.com
Thu Jun 1 09:01:24 CDT 2023
I failed to configue PETSc on Windows with latest Intel OneAPI toolkit:
./configure --with-cc="win32fe cl" --with-cxx="win32fe cl" --with-fc=0 \
        --with-debugging=0 --with-shared-libraries=0 --with-x=0
--with-quad-precision=0 \
        --with-threadcomm=1 --with-openmp=1 \
        --with-blaslapack-include="$MKLROOT/include" \
        --with-blaslapack-lib="-L$MKLROOT/lib/intel64 mkl_core.lib
mkl_intel_thread.lib mkl_intel_lp64.lib libiomp5md.lib" \
        --with-mpi-include="$I_MPI_ROOT/include" \
        --with-mpi-lib="-L$I_MPI_ROOT/lib/release impi.lib" \
        --with-mpiexec="$I_MPI_ROOT/bin/mpiexec" \
        --ignore-cygwin-link
However, the configuration was successful with Intel OneAPI 2022.1.0.93 or
previous version.
Error message:
                         Configuring PETSc to compile on your system
                                     ***** WARNING *****
  Using default optimization C flags "-O". You might consider manually
setting optimal
  optimization flags for your system with COPTFLAGS="optimization flags" see
  config/examples/arch-*-opt.py for examples
                                     ***** WARNING *****
  Using default Cxx optimization flags "-O". You might consider manually
setting optimal
  optimization flags for your system with CXXOPTFLAGS="optimization flags"
see
TESTING: checkCxxLibraries from
config.compilers(config/BuildSystem/config/compilers.py:450)
           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
  Cxx libraries cannot directly be used with C as linker.
  If you don't need the C++ compiler to build external packages or for you
application you
  can run
  ./configure with --with-cxx=0. Otherwise you need a different combination
of C and C++
  compilers
makefile:24:
/cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscrules: No
such file or directory
make[1]: *** No rule to make target
'/cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscrules'.
Stop.
gmakefile:67: arch-mswin-c-opt/lib/petsc/conf/files: No such file or
directory
make: *** [GNUmakefile:17:
/cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/include/petscconf.h] Error 2
makefile:24:
Stop.
/cygdrive/e/petsc-v3.19.2/lib/petsc/conf/variables:140:
/cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscvariables:
No such file or directory
/cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscvariables]
Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230601/e87510e8/attachment-0001.html>
