[petsc-users] Scalable Solver for Incompressible Flow
Jed Brown jed at jedbrown.org
Fri Jul 28 21:04:30 CDT 2023
See src/snes/tutorials/ex70.c for the code that I think was used for that paper.
Alexander Lindsay <alexlindsay239 at gmail.com> writes:
> Sorry for the spam. Looks like these authors have published multiple papers on the subject
> Combining the Augmented Lagrangian Preconditioner with the Simple Schur Complement Approximation | SIAM Journal on
> Scientific Computingdoi.org
>  On Jul 28, 2023, at 12:59 PM, Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  Do you know of anyone who has applied the augmented Lagrange methodology to a finite volume discretization?
>  On Jul 6, 2023, at 6:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
>  On Thu, Jul 6, 2023 at 8:30 PM Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  This is an interesting article that compares a multi-level ILU algorithm to approximate commutator and augmented
>  Lagrange methods: https://doi.org/10.1002/fld.5039
>  That is for incompressible NS. The results are not better than https://arxiv.org/abs/1810.03315, and that PC is considerably
>  simpler and already implemented in PETSc. There is an update in to this
>  https://epubs.siam.org/doi/abs/10.1137/21M1430698?casa_token=Fp_XhuZStZ0AAAAA:YDhnkW9XvAom_b8KocWz-hBEI7FAt46aw3ICa0FvCrOVCtYr9bwvtqJ4aBOTkDSvANKh6YTQEw
>  which removes the need for complicated elements.
>  You might need stuff like ILU for compressible flow, but I think incompressible is solved.
>    Thanks,
>       Matt
>  On Wed, Jun 28, 2023 at 11:37 AM Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  I do believe that based off the results in https://doi.org/10.1137/040608817 we should be able to make LSC, with
>  proper scaling, compare very favorably with PCD
>  On Tue, Jun 27, 2023 at 10:41 AM Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  I've opened https://gitlab.com/petsc/petsc/-/merge_requests/6642 which adds a couple more scaling
>  applications of the inverse of the diagonal of A
>  On Mon, Jun 26, 2023 at 6:06 PM Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  I guess that similar to the discussions about selfp, the approximation of the velocity mass matrix by the
>  diagonal of the velocity sub-matrix will improve when running a transient as opposed to a steady
>  calculation, especially if the time derivative is lumped.... Just thinking while typing
>  On Mon, Jun 26, 2023 at 6:03 PM Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  Returning to Sebastian's question about the correctness of the current LSC implementation: in the
>  taxonomy paper that Jed linked to (which talks about SIMPLE, PCD, and LSC), equation 21 shows four
>  applications of the inverse of the velocity mass matrix. In the PETSc implementation there are at
>  most two applications of the reciprocal of the diagonal of A (an approximation to the velocity mass
>  matrix without more plumbing, as already pointed out). It seems like for code implementations in
>  which there are possible scaling differences between the velocity and pressure equations, that this
>  difference in the number of inverse applications could be significant? I know Jed said that these
>  scalings wouldn't really matter if you have a uniform grid, but I'm not 100% convinced yet.
>  I might try fiddling around with adding two more reciprocal applications.
>  On Fri, Jun 23, 2023 at 1:09 PM Pierre Jolivet <pierre.jolivet at lip6.fr> wrote:
>  On 23 Jun 2023, at 10:06 PM, Pierre Jolivet <pierre.jolivet at lip6.fr> wrote:
>  On 23 Jun 2023, at 9:39 PM, Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>  Ah, I see that if I use Pierre's new 'full' option for -mat_schur_complement_ainv_type
>  That was not initially done by me
>  Oops, sorry for the noise, looks like it was done by me indeed in
>  9399e4fd88c6621aad8fe9558ce84df37bd6fada…
>  Thanks,
>  Pierre
>  (though I recently tweaked MatSchurComplementComputeExplicitOperator() a bit to use
>  KSPMatSolve(), so that if you have a small Schur complement — which is not really the case
>  for NS — this could be a viable option, it was previously painfully slow).
>  Thanks,
>  Pierre
>  that I get a single iteration for the Schur complement solve with LU. That's a nice testing
>  option
>  On Fri, Jun 23, 2023 at 12:02 PM Alexander Lindsay <alexlindsay239 at gmail.com>
>  wrote:
>  I guess it is because the inverse of the diagonal form of A00 becomes a poor
>  representation of the inverse of A00? I guess naively I would have thought that the
>  blockdiag form of A00 is A00
>  On Fri, Jun 23, 2023 at 10:18 AM Alexander Lindsay <alexlindsay239 at gmail.com>
>  wrote:
>  Hi Jed, I will come back with answers to all of your questions at some point. I
>  mostly just deal with MOOSE users who come to me and tell me their solve is
>  converging slowly, asking me how to fix it. So I generally assume they have
>  built an appropriate mesh and problem size for the problem they want to solve
>  and added appropriate turbulence modeling (although my general assumption
>  is often violated).
>  > And to confirm, are you doing a nonlinearly implicit velocity-pressure solve?
>  Yes, this is our default.
>  A general question: it seems that it is well known that the quality of selfp
>  degrades with increasing advection. Why is that?
>  > This has been a great discussion to follow. Regarding
>  >> when time stepping, you have enough mass matrix that cheaper
>  preconditioners are good enough
>  > I'm curious what some algebraic recommendations might be for high Re
>  in
>  > transients.
>  What mesh aspect ratio and streamline CFL number? Assuming your model
>  is turbulent, can you say anything about momentum thickness Reynolds
>  number Re_θ? What is your wall normal spacing in plus units? (Wall
>  resolved or wall modeled?)
>  solve?
>  > I've found one-level DD to be ineffective when applied monolithically or
>  to the momentum block of a split, as it scales with the mesh size.
>  I wouldn't put too much weight on "scaling with mesh size" per se. You
>  want an efficient solver for the coarsest mesh that delivers sufficient
>  accuracy in your flow regime. Constants matter.
>  Refining the mesh while holding time steps constant changes the advective
>  CFL number as well as cell Peclet/cell Reynolds numbers. A meaningful
>  scaling study is to increase Reynolds number (e.g., by growing the domain)
>  while keeping mesh size matched in terms of plus units in the viscous
>  sublayer and Kolmogorov length in the outer boundary layer. That turns
>  out to not be a very automatic study to do, but it's what matters and you
>  can spend a lot of time chasing ghosts with naive scaling studies.
>  What most experimenters take for granted before they begin their experiments is infinitely more interesting than any
>  results to which their experiments lead.
>  -- Norbert Wiener
>  https://www.cse.buffalo.edu/~knepley/
