[petsc-users] 3D Poisson solver failed in KSPSolve when number of cores is larger than one
Mon Jul 24 20:49:37 CDT 2023
On Mon, Jul 24, 2023 at 8:16 PM Thuc Bui <bui at calcreek.com> wrote:
> Dear PETSc Users/Developers.
> I have been successfully using PETsc on Windows without MPI for a while
> now. I have now attempted to implement PETSc with MPI on Windows 10. I have
> built a release version of PETSc 3.18.6 with MS MPI 10.1.2, Intel MKL 3.279
> (2020) and Visual Studio 2019 as a static library. I am testing a finite
> difference 3D Poisson solver (cylindrical coordinates) with this MPI PETSc.
> On a Windows 10 laptop with 4 cores (8 logical processors), the solver
> works fine with one core. However, it gives errors with 2 cores. The errors
> are listed below followed by a complete code. The errors are generated in
> KSPSolve. I perhaps miss some settings to cause this error “No method
> muldiagonalblock for Mat of type seqaij”. I don’t know why for a 2-core MPI
> program that a seqaij matrix is used in KSPSolve.
> I would be very grateful if someone can provide me with some direction to
> fix these issues.
That is a bug with PCEISENSTAT. It is not frequently used. Since your
matrix does not use inodes, a default implementation of
MatMultDIagonalBlock is not found. We just need to add this for MATSEQAIJ.
It should work with a different PC. We will fix this as soon as we can.
     Matt
> Many thanks for your help,
> Thuc Bui
> Senior R&D Engineer
> Calabazas Creek Research, Inc
> (650) 948-5361
> ///////////////errors/////////////////////////
> rank=0 iStart=0 iEnd=2375
> rank=1 iStart=2375 iEnd=4750
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> --------------------- Error Message
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> No support for this operation for this object type
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> No method multdiagonalblock for Mat of type seqaij
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> See https://petsc.org/release/faq/ for trouble shooting.
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> Petsc Release Version 3.18.6, Mar 30, 2023
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> Poisson3D.exe on a v140-x64SReleaseSP named HERMES by bui Mon Jul 24
> 15:16:55 2023
> [1]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc=0
> --with-cxx="win32fe cl" --with-debugging=0 --with-openmp
> --with-mpi-include=/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/MSMPI/latest/include:/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/MSMPI/latest/include/x64
> --with-mpi-lib="[/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/MSMPI/latest/Lib/x64/msmpi.lib,/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/MSMPI/latest/Lib/x64/msmpifec.lib]"
> --with-blaslapack-lib="[/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/IntelMKL/latest/x64/lib/mkl_intel_lp64.lib,/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/IntelMKL/latest/x64/lib/mkl_core.lib,/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/IntelMKL/latest/x64/lib/mkl_intel_thread.lib,/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/IntelMKL/latest/x64/lib/libiomp5md.lib]"
> --with-mpiexec=/cygdrive/c/Users/bui/Documents/Petsc/externalpackages/MSMPI/latest/bin/x64/mpiexec
> --with-shared-libraries=0
> 15:16:55 2023
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #1 MatMultDiagonalBlock() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\mat\INTERF~1\matrix.c:2538
> Configure options --with-cc="win32fe cl" --with-fc=0 --with-cxx="win32fe
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #2 MatMultDiagonalBlock_MPIAIJ() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\mat\impls\aij\mpi\mpiaij.c:978
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #3 MatMultDiagonalBlock() at
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #4 PCApply_Eisenstat() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\ksp\pc\impls\eisens\eisen.c:51
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #5 PCApply() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\ksp\pc\INTERF~1\precon.c:441
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #6 KSP_PCApply() at
> C:\Users\bui\DOCUME~1\Petsc\latest\include\petsc/private/kspimpl.h:380
> #5 PCApply() at
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #7 KSPInitialResidual() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\ksp\ksp\INTERF~1\itres.c:64
> #6 KSP_PCApply() at
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #8 KSPSolve_GMRES() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\ksp\ksp\impls\gmres\gmres.c:227
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #9 KSPSolve_Private() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\ksp\ksp\INTERF~1\itfunc.c:899
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #10 KSPSolve() at
> C:\Users\bui\DOCUME~1\Petsc\latest\src\ksp\ksp\INTERF~1\itfunc.c:1071
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> #11 main() at C:\Users\bui\Documents\Nemesis\Poisson3D\Main.cpp:253
> #10 KSPSolve() at
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> No PETSc Option Table entries
> [1]PETSC ERROR:
> [0]PETSC ERROR:
> ----------------End of Error Message -------send entire error message to
> petsc-maint at mcs.anl.gov----------
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> //complete codes///////////////////////////////////////////////
> #include "petscsys.h"
> #include "petscksp.h"
> #ifndef PETSC_SUCCESS
> #define PETSC_SUCCESS 0
> #endif
> //rectangular matrix mxn
> int** allocateIMatrixR(int m, int n)
>          int** v = (int**)malloc(m * sizeof(int*));
>          for (int i = 0; i < m; ++i) {
>                  v[i] = (int*)malloc(n * sizeof(int));
>                  for (int j = 0; j < n; ++n) {
>                           v[i][j] = -1;
>          return v;
> int mapIndex(int k, int i, int j, int Nz, int Nr)
>          //k for z, i for r, j for theta
>          //base 0
>          //3D table:      theta    r                z
>          //                        0                0                 0
>          //                        0                0                 1
>          //                        0                0                 2
>          //                        0                1                 0
>          //                        0                1                 1
>          //                        0                1                 2
>          int n = k + i * Nz + j * Nz * Nr;
>          return n;
> PetscErrorCode MPIAssembler(Mat* A, Vec* b, int Kz, int Ir, int Jt)
>          PetscFunctionBeginUser;
>          int M;
>          PetscCall(VecGetSize(*b, &M));
> //contruct an array of Mx3, row index is the equation number, each row is (i,j,k),
>          //i is r-index, j theta-index, k z-index
>          const int dim = 3;
>          int** Nijk = allocateIMatrixR(M, dim);
>          for (int k = 0; k < Kz; ++k) {
>                  int k1 = k + 1;
>                  for (int i = 0; i < Ir; ++i) {
>                           for (int j = 0; j < Jt; ++j) {
>                                    //for each equation row m
>                                    int m = mapIndex(k, i, j, Kz, Ir);
>                                    Nijk[m][0] = i;
>                                    Nijk[m][1] = j;
>                                    Nijk[m][2] = k;
>          //Cylinder dimensions
>          double R = 11.0; //cm, cylinder radius
>          double L = 11.0; //cm, cylinder length in z
>          double Dr = R / (Ir + 1);
>          double Dz = L / (Kz + 1);
>          double Dr2 = Dr * Dr;
>          double Dr_2 = 0.5 * Dr;
>          double Dr_22 = Dr_2 * Dr_2;
>          double Dz_2 = 1.0 / (Dz * Dz);
>          double DT = 2.0 * M_PI / Jt;
>          double DT2 = DT * DT;
>          double Vr = 0.0; //Dirichlet on R
>          double chargeDens = -4.0;
>          int rank;
>          PetscCallMPI(MPI_Comm_rank(PETSC_COMM_WORLD, &rank));
>          //get the range of matrix rows owned by this processor
>          int startingNumber, endingNumber;
> PetscCall(MatGetOwnershipRange(*A, &startingNumber, &endingNumber));
>          fprintf(stderr, "rank=%i iStart=%i iEnd=%i\n"
> , rank, startingNumber, endingNumber);
>          int Ir_1 = Ir - 1;
>          int Jt_1 = Jt - 1;
>          for (int m = startingNumber; m < endingNumber; ++m) {
>                  int i = Nijk[m][0];
>                  int j = Nijk[m][1];
>                  int k = Nijk[m][2];
>                  double ri = Dr * (i + 1);
>                  double ri_2 = ri - Dr_2;
>                  double ri2 = ri + Dr_2;
>                  double sqri = ri * ri;
>                  double Ai = (ri_2 / ri) / Dr2;
>                  double Bi = (ri2 / ri) / Dr2;
>                  double Ci = 1.0 / (sqri * DT2);
>                  double
>  Ei = (ri2 + ri_2) / (ri * Dr2) + 2.0 / (sqri * DT2) + 2.0 * Dz_2;
>                  //contribution of charge density to RHS
>                  PetscCall(VecSetValue(*b, m, -chargeDens, ADD_VALUES));
>                  //contribution to RHS by Drichlet on R
>                  if (i == Ir_1) {
> PetscCall(VecSetValue(*b, i, -Bi * Vr, ADD_VALUES));
>                  if (!i) {        //from the axis
>                           //contributing to RHS
> PetscCall(VecSetValue(*b, m, -chargeDens * Ai * Dr_22, ADD_VALUES));
>                           //contributing to LHS
>                           double xTheta = (Ai / Jt);
>                           for (int jt = 0; jt < Jt; ++jt) {
>                                    int nj = mapIndex(k, i, jt, Kz, Ir);
> PetscCall(MatSetValues(*A, 1, &m, 1, &nj, &xTheta, ADD_VALUES));
>                  else {
>                           //0 < i < Ir: contribution of Ai to LHS
>                           int i_jk = mapIndex(k, i - 1, j, Kz, Ir);
> PetscCall(MatSetValues(*A, 1, &m, 1, &i_jk, &Ai, ADD_VALUES));
>                  if (i != Ir_1) {
>                           //0 <= i < It-1: contribution of Bi to LHS
>                           int ki1j = mapIndex(k, i + 1, j, Kz, Ir);
> PetscCall(MatSetValues(*A, 1, &m, 1, &ki1j, &Bi, ADD_VALUES));
>                  //apply periodic BC in theta////////////////////////////
>                  int kij_;
>                  if (!j) {
>                           kij_ = mapIndex(k, i, Jt_1, Kz, Ir);
>                  else {
>                           kij_ = mapIndex(k, i, j - 1, Kz, Ir);
>                  //1st contribution of Ci to LHS
> PetscCall(MatSetValues(*A, 1, &m, 1, &kij_, &Ci, ADD_VALUES));
>                  int kij1;
>                  if (j == Jt_1) {
>                           kij1 = mapIndex(k, i, 0, Kz, Ir);
>                  else {
>                           kij1 = mapIndex(k, i, j + 1, Kz, Ir);
>                  //2nd contribution of Ci to LHS
> PetscCall(MatSetValues(*A, 1, &m, 1, &kij1, &Ci, ADD_VALUES));
>                  //apply z Neumann BC ///////////////////////////////////
>                  int k_ij;
>                  if (!k) {        //z=0
>                           k_ij = mapIndex(k, i, j, Kz, Ir);
>                  else {           //0 < z < L
>                           k_ij = mapIndex(k - 1, i, j, Kz, Ir);
> PetscCall(MatSetValues(*A, 1, &m, 1, &k_ij, &Dz_2, ADD_VALUES));
>                  //contribution of Ei to LHS
>                  int kij = mapIndex(k, i, j, Kz, Ir);
> PetscCall(MatSetValues(*A, 1, &m, 1, &kij, &Ei, ADD_VALUES));
>          if (Nijk) {
>                  for (int i = 0; i < M; ++i) {
>                           free(Nijk[i]);
>                  free(Nijk);
>          PetscCall(VecAssemblyBegin(*b));
>          PetscCall(VecAssemblyEnd(*b));
>          PetscCall(MatAssemblyBegin(*A, MAT_FINAL_ASSEMBLY));
>          PetscCall(MatAssemblyEnd(*A, MAT_FINAL_ASSEMBLY));
>          PetscFunctionReturn(PETSC_SUCCESS);
> int main(int argc, char** argv)
>          const char help[] = "Poisson3D solver using PETSc.";
>          PetscCall(PetscInitialize(&argc, &argv, PETSC_NULL, help));
>          Mat mat_;
>          Vec B_;
>          Vec X_;
>          int Nz = 26;     //number of z-segments
>          int Nr = 20;     //number of r-segments
>          int Nt = 10;     //number of theta-segments
>          PetscCall(PetscOptionsGetInt(NULL, NULL, "-z", &Nz, NULL));
>          PetscCall(PetscOptionsGetInt(NULL, NULL, "-r", &Nr, NULL));
>          PetscCall(PetscOptionsGetInt(NULL, NULL, "-t", &Nt, NULL));
>          //Neumann at z=0 and z=L
>          //Dirichlet at R, the cylinder radius
>          //On axis, compute field
>          //number of unknowns of cylinder interior nodes minus axis
>          int Kz = Nz - 1;
>          int Ir = Nr - 1;
>          int M = Kz * Ir * Nt;
>          int bw = 15;     //for 7-point stencil
>          PetscCall(MatCreate(PETSC_COMM_WORLD, &mat_));
>          PetscCall(MatSetSizes(mat_, PETSC_DECIDE, PETSC_DECIDE, M, M));
>          PetscCall(MatSetFromOptions(mat_));
>          PetscCall(MatMPIAIJSetPreallocation(mat_, bw, 0, bw, 0));
>          PetscCall(MatSeqAIJSetPreallocation(mat_, bw, 0));
>          //source
>          PetscCall(VecCreate(PETSC_COMM_WORLD, &B_));
>          PetscCall(VecSetSizes(B_, PETSC_DECIDE, M));
>          PetscCall(VecSetFromOptions(B_));
>          //sol
>          PetscCall(VecDuplicate(B_, &X_));
>          MPIAssembler(&mat_, &B_, Kz, Ir, Nt);
>          PCType pcType = PCEISENSTAT;
>          KSPType solverType = KSPGMRES;
>          int maxIters = 100;
>          double relTol = 1.0e-6;
>          KSP ksp;
>          PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
>          PetscCall(KSPSetOperators(ksp, mat_, mat_));
>          PetscCall(KSPSetType(ksp, solverType));
>          //preconditioner
>          PC pc;
>          PetscCall(KSPGetPC(ksp, &pc));
>          PetscCall(PCSetType(pc, pcType));
> PetscCall(KSPSetTolerances(ksp, relTol, PETSC_DEFAULT, PETSC_DEFAULT, maxIters));
>          PetscCall(KSPSetFromOptions(ksp));
>          //solving
>          PetscCall(KSPSolve(ksp, B_, X_));
>          double xMin, xMax;
>          int mnIndx, mxIndx;
>          PetscCall(VecMin(X_, &mnIndx, &xMin));
>          PetscCall(VecMax(X_, &mxIndx, &xMax));
>          fprintf(stderr, "mnIndx=%i mxIndx=%i xMin=%g xMax=%g\n"
> , mnIndx, mxIndx, xMin, xMax);
>          PetscCall(PetscFinalize());
>          return 0;
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230724/4b3c04ff/attachment-0001.html>
