[petsc-users] Confusion/failures about the tests involved in including Hypre
Daniel Stone daniel.stone at opengosim.com
Mon Jul 24 05:21:19 CDT 2023
On the hypre versioning - aha. For this project I locked the petsc version
a little while ago (3.19.1), but I've been using a fresh clone of hypre, so
clearly
it's too modern a version. Using the appropriate version of hypre (2.28.0,
according to hypre.py) might fix some things.
I may have other problems in the form of the confilicting compiler options
as Satish mentioned, which I'll have to figure out too.
Daniel
On Fri, Jul 21, 2023 at 9:32 PM Barry Smith <bsmith at petsc.dev> wrote:
> hypre_Error was changed from an integer to a struct in hypre. PETSc code
> was changed in main to work with that struct and not work if hypre_Error is
> an int. This means main cannot work with previous hypre versions (where
> hypre_Error is an int). Sure, instead of changing the minimum version one
> could potentially change PETSc's main version source code to work with both
> old and new hypre, but that would need to be done and has not been done.
> main is simply broken, it allows configure to succeed with an older version
> of hypre but PETSc main cannot compile with this, thus confusing developers
> and users. This does need to be fixed, one way or another.
> > On Jul 21, 2023, at 1:32 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > We don't have a good way to verify if the changes continue to work
> > with the minver of the pkg [and if minor fixes can get this working -
> > without increasing this requirement - sure without access to the new
> > features provided by the new version]
> > Having a single version dependency between pkgs makes the whole
> > ecosystem [where many pkgs with all their dependencies mixed in]
> > brittle..
> > Satish
> > On Thu, 20 Jul 2023, Barry Smith wrote:
> >>  Satish,
> >>   I think hypre.py in main needs minversion = 2.29 instead of 2.14
> >>> On Jul 20, 2023, at 11:05 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> Can check config/BuildSystem/config/packages/hypre.py
> >>> petsc-3.19 (or release branch) is compatible with hypre 2.28.0, petsc
> 'main' branch with 2.29.0
> >>> Satish
> >>> On Thu, 20 Jul 2023, Barry Smith via petsc-users wrote:
> >>>> You cannot use this version of PETSc, 3.19, with the version of hypre
> you installed. In hypre they recently changed hypre_Error from an integer
> to a struct which completely breaks compatibility with previous versions of
> hypre (and hence previous versions of PETSc). You must use the main git
> branch of PETSc with the version of hypre you installed.
> >>>> Barry
> >>>>> On Jul 20, 2023, at 5:10 AM, Daniel Stone <
> daniel.stone at opengosim.com> wrote:
> >>>>> Hi All,
> >>>>> Many thanks for the detailed explainations and ideas!
> >>>>> I tried skipping the test. When it came time to do the build itself
> (make $PETSC_DIR... all) I get some failures, unsurprisingly:
> >>>>>        FC arch-mswin-c-opt/obj/dm/f90-mod/petscdmplexmod.o
> >>>>>        CC
> arch-mswin-c-opt/obj/ksp/pc/impls/hypre/ftn-custom/zhypref.o
> >>>>>        CC arch-mswin-c-opt/obj/ksp/pc/impls/hypre/ftn-auto/hypref.o
> >>>>>        CC arch-mswin-c-opt/obj/ksp/pc/impls/hypre/hypre.o
> C:\cygwin64\home\DANIEL~1\PETSC_~1.1\src\ksp\pc\impls\hypre\hypre.c(444,29):
> error: assigning to 'hypre_Error' from incompatible type 'int'
> >>>>>       hypre__global_error = 0;
> >>>>> C:\cygwin64\home\DANIEL~1\PETSC_~1.1\include\petscerror.h(1752,7):
> note: expanded from macro 'PetscStackCallExternalVoid'
> >>>>>     __VA_ARGS__; \
> C:\cygwin64\home\DANIEL~1\PETSC_~1.1\src\ksp\pc\impls\hypre\hypre.c(634,29):
> >>>>>     __VA_ARGS__; \
> >>>>> 2 errors generated.
> >>>>> make[3]: *** [gmakefile:195:
> arch-mswin-c-opt/obj/ksp/pc/impls/hypre/hypre.o] Error 1
> >>>>> make[3]: *** Waiting for unfinished jobs....
> >>>>>        FC arch-mswin-c-opt/obj/ksp/f90-mod/petsckspdefmod.o
> >>>>>        CC arch-mswin-c-opt/obj/dm/impls/da/hypre/mhyp.o
> >>>>>        CC arch-mswin-c-opt/obj/mat/impls/hypre/mhypre.o
> >>>>> make[3]: Leaving directory '/home/DanielOGS/petsc_ogs_3.19.1'
> >>>>> make[2]: ***
> [/home/DanielOGS/petsc_ogs_3.19.1/lib/petsc/conf/rules.doc:28: libs] Error 2
> >>>>> make[2]: Leaving directory '/home/DanielOGS/petsc_ogs_3.19.1'
> >>>>> **************************ERROR*************************************
> >>>>> Error during compile, check arch-mswin-c-opt/lib/petsc/conf/make.log
> >>>>> Send it and arch-mswin-c-opt/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
> >>>>> Finishing make run at Wed, 19 Jul 2023 17:07:00 +0100
> >>>>> But wait - isn't this the compile stage, not the linking stage? This
> seems to imply that I've made a hash of providing include file such that a
> definition of "hypre_Error"
> >>>>> cannot be seen - unless I'm misinterpreting. Interesting note about
> Hypre and include files - if built using configure and make, all the
> include files are conviniently copied
> >>>>> into hypre/src/hypre/include. This is not done for a cmake build - I
> had to do the copying myself. Maybe I missed one.
> >>>>> On shared vs. static - if there a clear way of telling which I've
> ended up with? I've checked the cmakelists for hypre and this seems to
> imply that not-shared is the default,
> >>>>> which I didn't change:
> >>>>> # Configuration options
> >>>>> option(HYPRE_ENABLE_SHARED           "Build a shared library" OFF)
> >>>>> option(HYPRE_ENABLE_BIGINT           "Use long long int for
> HYPRE_Int" OFF)
> >>>>> option(HYPRE_ENABLE_MIXEDINT         "Use long long int for
> HYPRE_BigInt, int for HYPRE_INT" OFF)
> >>>>> checking again, I've noticed that the way that the stub-test fails
> is different depending on whether it's called from the config script or
> used in isolation - more details on that soon.
> >>>>> Thanks again,
> >>>>> Daniel
> >>>>> On Wed, Jul 19, 2023 at 4:58 PM Satish Balay via petsc-users <
> petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >>>>>> I think it should work with static libraries and 64bit compilers.
> >>>>>> That's how I think --download-f2cblaslapack [etc] work.
> >>>>>> Also it works with MS-MPI - even-though its a dll install, the
> library stub provides this symbol somehow..
> >>>>>> balay at ps5 /cygdrive/c/Program Files (x86)/Microsoft
> SDKs/MPI/Lib/x64
> >>>>>> $ nm -Ao msmpi.lib |grep " MPI_Init"
> >>>>>> msmpi.lib:msmpi.dll:0000000000000000 T MPI_Init
> >>>>>> msmpi.lib:msmpi.dll:0000000000000000 T MPI_Init_thread
> >>>>>> msmpi.lib:msmpi.dll:0000000000000000 T MPI_Initialized
> >>>>>> However - if the library symbol is somehow mangled - this configure
> mode of checking library functions will fail.
> >>>>>> Checking PETSc dll build:
> >>>>>> balay at ps5 ~/petsc/arch-ci-mswin-uni/lib
> >>>>>> $ nm -Ao libpetsc.lib |grep MatCreateSeqAIJWithArrays
> >>>>>> libpetsc.lib:libpetsc.dll:0000000000000000 I
> __imp_MatCreateSeqAIJWithArrays
> >>>>>> libpetsc.lib:libpetsc.dll:0000000000000000 T
> >>>>>> It also has the unmangled symbol - so I guess this mode can work
> generally with dlls.
> >>>>>> Satish
> >>>>>> On Wed, 19 Jul 2023, Barry Smith wrote:
> >>>>>>> Satish,
> >>>>>>>  So it will always fail on Windows with Windows compilers (both
> with static and shared libraries)? Is this true for all PETSc external
> packages? If so, why does the installation documentation say that some
> external packages can work with Windows compilers? (Presumably PETSc cannot
> since the configure tests will fail).
> >>>>>>> Barry
> >>>>>>>> On Jul 19, 2023, at 11:40 AM, Satish Balay <balay at mcs.anl.gov
> <mailto:balay at mcs.anl.gov>> wrote:
> >>>>>>>> BTW: Some explanation of configure:
> >>>>>>>> It attempts the following on linux:
> >>>>>>>> Source:
> >>>>>>>> #include "confdefs.h"
> >>>>>>>> #include "conffix.h"
> >>>>>>>> /* Override any gcc2 internal prototype to avoid an error. */
> >>>>>>>> char HYPRE_IJMatrixCreate();
> >>>>>>>> static void _check_HYPRE_IJMatrixCreate() {
> HYPRE_IJMatrixCreate(); }
> >>>>>>>> int main(void) {
> >>>>>>>> _check_HYPRE_IJMatrixCreate();
> >>>>>>>> return 0;
> >>>>>>>> Note - it does not include 'HYPRE.h' here - but redefines the
> prototype as 'char HYPRE_IJMatrixCreate();
> >>>>>>>> Compiling it manually:
> >>>>>>>> [balay at pj01 petsc]$ cat conftest.c
> >>>>>>>> int main(void) {
> >>>>>>>> return 0;
> >>>>>>>> [balay at pj01 petsc]$ gcc -c conftest.c
> >>>>>>>> [balay at pj01 petsc]$ nm -Ao conftest.o |grep HYPRE_IJMatrixCreate
> >>>>>>>> conftest.o:0000000000000000 t _check_HYPRE_IJMatrixCreate
> >>>>>>>> conftest.o:                 U HYPRE_IJMatrixCreate
> >>>>>>>> [balay at pj01 petsc]$ nm -Ao arch-linux-c-debug/lib/libHYPRE.so
> >>>>>>>> arch-linux-c-debug/lib/libHYPRE.so:000000000007f2c2 T
> >>>>>>>> Here the "U HYPRE_IJMatrixCreate" in conftest.o matches "T
> HYPRE_IJMatrixCreate" in libHYPRE.so - so the "link" test in configure
> succeeds!
> >>>>>>>> [balay at pj01 petsc]$ gcc -o conftest conftest.o
> >>>>>>>> [balay at pj01 petsc]$ echo $?
> >>>>>>>> 0
> >>>>>>>> On windows - [due to name mangling by cdecl/stdcall, (/MT vs /MD)
> etc..] - this might not match - resulting in link failures.
> >>>>>>>> Satish
> >>>>>>>> On Wed, 19 Jul 2023, Satish Balay via petsc-users wrote:
> >>>>>>>>> You could try skipping this test [and assume
> --with-hypre-include and --with-hypre-lib options are correct] - and see if
> this works.
> >>>>>>>>> diff --git a/config/BuildSystem/config/packages/hypre.py
> b/config/BuildSystem/config/packages/hypre.py
> >>>>>>>>> index 5bc88322aa2..2d6c7932e17 100644
> >>>>>>>>> --- a/config/BuildSystem/config/packages/hypre.py
> >>>>>>>>> +++ b/config/BuildSystem/config/packages/hypre.py
> >>>>>>>>> @@ -11,7 +11,7 @@ class Configure(config.package.GNUPackage):
> >>>>>>>>>   self.requiresversion = 1
> >>>>>>>>>   self.gitcommit       = 'v'+self.version
> >>>>>>>>>   self.download        = ['git://
> https://github.com/hypre-space/hypre','
> https://github.com/hypre-space/hypre/archive/'+self.gitcommit+'.tar.gz']
> >>>>>>>>> -    self.functions       = ['HYPRE_IJMatrixCreate']
> >>>>>>>>> +    self.functions       = []
> >>>>>>>>>   self.includes        = ['HYPRE.h']
> >>>>>>>>>   self.liblist         = [['libHYPRE.a']]
> >>>>>>>>>   self.buildLanguages  = ['C','Cxx']
> >>>>>>>>> Satish
> >>>>>>>>>> You don't indicate what type of libraries you built hypre with;
> static or shared. My guess is you ended up with shared
> >>>>>>>>>> I think the answer to your difficulty is hidden in __cdecl
> (Satish will know much better than me). When you are looking for symbols in
> Windows shared libraries you have to prepend something to the function
> prototype to have it successfully found. For example the PETSc include
> files have these things __declspec(dllimport) The configure test fails
> because it does not provide the needed prototype. Likely you built PTScotch
> with static libraries so no problem.
> >>>>>>>>>> The simplest fix would be to build static hypre libraries. I
> think it is a major project to get PETSc configure and macro system to work
> properly with external packages that are in Windows shared libraries since
> more use of __declspec would be needed.
> >>>>>>>>>> Barry
> >>>>>>>>>> The PETSc installation instructions should probably say
> something about external packages with Windows shared libraries.
> >>>>>>>>>>> On Jul 19, 2023, at 10:52 AM, Daniel Stone <
> daniel.stone at opengosim.com <mailto:daniel.stone at opengosim.com>> wrote:
> >>>>>>>>>>> Hello,
> >>>>>>>>>>> I'm working on getting a petsc build running on windows. One
> necessary package to include is Hypre. I've been able to build Hypre
> seperately using cmake, and confirmed that the library works
> >>>>>>>>>>> by setting up a VS project to run some of the example programs.
> >>>>>>>>>>> My attempted petsc build is being done through cygwin. I've
> been able to (with varying degrees of difficulty), build a fairly plain
> petsc, and one that downloads and builds ptscotch (after some modifications
> >>>>>>>>>>> to both ptscotch and the config script). I am now attempting
> to include Hypre (using the --hypre-iclude and --hypre-lib flags, etc).
> Note that the same compilers are being used for both Hypre and for petsc
> >>>>>>>>>>> through cygwin - the new intel oneapi compilers (icx and ifx,
> after again varying amounts of pain to work around their awkwardness with
> the config script).
> >>>>>>>>>>> I'm seeing a problem when the config script does some tests on
> the included hypre lib. The source code looks like:
> >>>>>>>>>>> #include "HYPRE.h"
> >>>>>>>>>>> int main() {
> >>>>>>>>>>> _check_HYPRE_IJMatrixCreate();;
> >>>>>>>>>>> return 0;
> >>>>>>>>>>> As I understand this is a fairly standard type of stub program
> used by the config script to check that it is able to link to certain
> symbols in given libraries. Tests like this have succeeded in my builds that
> >>>>>>>>>>> include PTScotch.
> >>>>>>>>>>> I keep getting a linker error with the above test, including
> if I seperate it out and try to build it seperately:
> >>>>>>>>>>> unresolved external symbol "char __cdel
> HYPRE_IJMatrixCreate(void)" ....
> >>>>>>>>>>> Ok, it looks like a problem with either the library or linker
> commands. But here's the interesting thing - If I transplant this code into
> VS, with the same project setting that allows it to build the much more
> >>>>>>>>>>> nontrivial Hypre example programs, I get the same error:
> >>>>>>>>>>> Error LNK2001 unresolved external symbol "char __cdecl
> HYPRE_IJMatrixCreate(void)" (?HYPRE_IJMatrixCreate@@YADXZ) hypretry1
> C:\Users\DanielOGS\source\repos\hypretry1\hypretry1\Source.obj 1
> >>>>>>>>>>> So it seems like there might be something about this type of
> stub program that is not working with my Hypre library. I don't fully
> understand this program - it's able to call the function with no arguments,
> but
> >>>>>>>>>>> it also needs to be linked against a library containing the
> function, apparently by wrapping it in a static void function? Not
> something I've seen before.
> >>>>>>>>>>> Does anyone have any insight into what might be going wrong -
> or really just any explaination of how the stub program works so I can
> figure out why it isn't in this case?
> >>>>>>>>>>> Many thanks,
> >>>>>>>>>>> Daniel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230724/5b987e73/attachment-0001.html>
