[petsc-users] Matrix assembly problem of overlapped DMPlex
袁煕 yuanxi at advancesoft.jp
Sun Jul 23 10:53:46 CDT 2023
袁煕 <yuanxi at advancesoft.jp>
0:50 (0 分前)
To PETSc
I used PETSc to assemble a FEM stiff matrix of an overlapped (overlap=2)
DMPlex and used the MUMPS solver to solve it. But I got a
different solution by using 1 CPU and MPI parallel computation. I am
wondering if I missed some necessary step or setting during my
implementation.
    My calling process like follows
1. Generate matrix pkij from DMPlex dm_mesh
      PetscCallA( DMCreateMatrix(dm_mesh, pkij, ierr) )
      PetscCallA( MatSetBlockSize(pkij, 1, ierr))
      if( overlap>0 ) call
MatSetOption(pkij,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE,ierr)
      PetscCallA( MatSetFromOptions(pkij, ierr))
      PetscCallA(MatGetLocalSize(pkij, m, n, ierr));
      PetscCallA(MatGetSize(pkij, gm, gn, ierr));
      PetscCallA(MatGetBlockSize(pkij, bs, ierr));
2. Do Matrix preallocation
      PetscCallA(MatCreate(PETSC_COMM_WORLD, preallocator, ierr));
      PetscCallA(MatSetType(preallocator, MATPREALLOCATOR, ierr));
      PetscCallA(MatSetSizes(preallocator, m, n, gm, gn, ierr));
      PetscCallA(MatSetBlockSize(preallocator, bs, ierr));
      PetscCallA(MatSetUp(preallocator, ierr));
      PetscCallA( MatPreallocatorPreallocate(preallocator, PETSC_TRUE,
pkij, ierr) )
      PetscCallA( MatDestroy(preallocator,ierr) )
3. Assemble matrix pkij by calling MatSetValue of all overlapped elements.
In my above implementation, I used
MatSetOption(pkij,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE,ierr). Is
that correct? Or even other options are needed?
Thanks for your help.
X. Yuan, Ph.D. of solid mechanics
Advancesoft, Japan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230724/f497c79f/attachment.html>
