[petsc-users] Parallel matrix multiplication
Mon Jul 17 14:33:47 CDT 2023
On Mon, Jul 17, 2023 at 2:22 PM Barry Smith <bsmith at petsc.dev> wrote:
>    https://petsc.org/release/manualpages/Mat/MatPtAP/  also note that
> PETSc has a large infrastructure for efficient ways to compute various
> matrix-matrix operations with a variety of algorithms that can be all
> accessed by starting with
> https://petsc.org/release/manualpages/Mat/MatProductCreate/
> On Jul 17, 2023, at 1:13 PM, Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I would like to perform the following operation
> [P^T A P] x’ = P^T f
> If P is thin, you might want to consider making a MatLRC and passing that
to a Krylov method, probably with a small precondition matrix (like P^T
diag(A) P).
     Matt
> Where P is a rectangular matrix and A is a square matrix.  All the
> matrixes are constructed using MPIAIJ.
> Should I be concerned about the parallel partitioning of the matrix P and
> A?
> Or can I just go ahead and use MatMatMult to compute [P^T A P]?
> Is there any in-built functionality to perform this operation?
> Kind regards,
> Karthik.
> *Dr. Karthik Chockalingam*
> High-Performance Software Engineer
> Hartree Centre | Science and Technology Facilities Council
> karthikeyan.chockalingam at stfc.ac.uk
>  <image001.png>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230717/c2a9207c/attachment.html>
