[petsc-users] petscconf.h missing building cpp file with dolfinx?
Mon Jul 17 13:39:09 CDT 2023
PETSc supports both --prefix and inplace install.
Suggest using inplace install - in your $HOME:
For ex:
balay at p1 /home/balay
$ tar -xzf petsc-3.19.
petsc-3.19.2.tar.gz  petsc-3.19.3.tar.gz
$ tar -xzf petsc-3.19.3.tar.gz
$ cd petsc-3.19.3
balay at p1 /home/balay/petsc-3.19.3
$ export PETSC_DIR=$PWD
$ export PETSC_ARCH=arch-buildfordolfin
$ ./configure && make
[with the required configure options to get a successful build of PETSc]
Now - with PETSC_DIR and PETSC_ARCH (env variables) - set to the above values - try installing dolfin
Satish
On Mon, 17 Jul 2023, Barry Smith wrote:
>   When configuring and making PETSc, PETSC_DIR can be empty or point to the directory with the PETSc source
>   If you used --prefix to configure and install PETSc then
>       When using PETSc to compile other source code and using a makefile that utilizes PETSC_DIR, then PETSC_DIR needs to point to the --prefix location
>       PETSC_ARCH should be empty since it is not used for --prefix installs
> > On Jul 17, 2023, at 2:06 PM, philliprusso via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > So I have this to go by:
> > export PETSC_DIR=/absolute/path/to/petsc
> > export PETSC_ARCH=linux-gnu-c-debug
> > PETSC_DIR Is that the installation/destination path or the path where the source code is? I feel confused....
> > So there is a destination folder that dolfinx project wnats for petsc. I have an idea it might want /usr/local/include not sure of everything quite yet...
> > Sent with Proton Mail secure email.
> > ------- Original Message -------
> > On Monday, July 17th, 2023 at 8:08 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> We do not recommend installing PETSc in /usr/include [aka --prefix=/usr]. Now you have some petsc includes here that will potentially conflict with any other install of PETSc you might attempt.
> >> You might have to manually check - and delete PETSc installed files from here.
> >> For most uses - one can install PETSc in $HOME
> >> If you need a common install - suggest --prefix=/usr/local/petsc-version
> >> Satish
> >> On Sun, 16 Jul 2023, philliprusso via petsc-users wrote:
> >>> I cloned petsc source for use with dolfinx project. So after .configure mak sudo make install I found there was some type of difficulty with the destination directory so I copied the files manually into usr/includes of Ubuntu 22.04 jammy. So some petsc header files are now found for compiling cpp dolfinx source code but petscconf.h still not found by dolfinxs source tree of header files. Anyone know how to remedy this so dolfinx cpps can find petsscconf.h that g++ is claiming as missing? Thank you!
