[petsc-users] petscconf.h missing building cpp file with dolfinx?
philliprusso philliprusso at proton.me
Mon Jul 17 13:06:39 CDT 2023
So I have this to go by:
export PETSC_DIR=/absolute/path/to/petsc
export PETSC_ARCH=linux-gnu-c-debug
PETSC_DIR Is that the installation/destination path or the path where the source code is? I feel confused....
So there is a destination folder that dolfinx project wnats for petsc. I have an idea it might want /usr/local/include not sure of everything quite yet...
Sent with Proton Mail secure email.
------- Original Message -------
On Monday, July 17th, 2023 at 8:08 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> We do not recommend installing PETSc in /usr/include [aka --prefix=/usr]. Now you have some petsc includes here that will potentially conflict with any other install of PETSc you might attempt.
> You might have to manually check - and delete PETSc installed files from here.
> For most uses - one can install PETSc in $HOME
> If you need a common install - suggest --prefix=/usr/local/petsc-version
> Satish
> On Sun, 16 Jul 2023, philliprusso via petsc-users wrote:
> > I cloned petsc source for use with dolfinx project. So after .configure mak sudo make install I found there was some type of difficulty with the destination directory so I copied the files manually into usr/includes of Ubuntu 22.04 jammy. So some petsc header files are now found for compiling cpp dolfinx source code but petscconf.h still not found by dolfinxs source tree of header files. Anyone know how to remedy this so dolfinx cpps can find petsscconf.h that g++ is claiming as missing? Thank you!
