[petsc-users] Using PETSc GPU backend
Ng, Cho-Kuen cho at slac.stanford.edu
Fri Jul 14 18:56:43 CDT 2023
I managed to pass the following options to PETSc using a GPU node on Perlmutter.
    -mat_type aijcusparse -vec_type cuda -log_view -options_left
Below is a summary of the test using 4 MPI tasks and 1 GPU per task.
o #PETSc Option Table entries:
   -log_view
   -options_left
   -vec_type cuda
   #End of PETSc Option Table entries
   WARNING! There are options you set that were not used!
   WARNING! could be spelling mistake, etc!
   There is one unused database option. It is:
   Option left: name:-mat_type value: aijcusparse
The -mat_type option has not been used. In the application code, we use
    ierr = MatCreateAIJ(PETSC_COMM_WORLD,mlocal,mlocal,m,n,
             d_nz,PETSC_NULL,o_nz,PETSC_NULL,&A);;CHKERRQ(ierr);
o The percent flops on the GPU for KSPSolve is 17%.
In comparison with a CPU run using 16 MPI tasks, the GPU run is an order of magnitude slower. How can I improve the GPU performance?
Cho
Sent: Friday, June 30, 2023 7:57 AM
To: Barry Smith <bsmith at petsc.dev>; Mark Adams <mfadams at lbl.gov>
Cc: Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Using PETSc GPU backend
Barry, Mark and Matt,
Thank you all for the suggestions. I will modify the code so we can pass runtime options.
Cho
Sent: Friday, June 30, 2023 7:01 AM
To: Mark Adams <mfadams at lbl.gov>
Cc: Matthew Knepley <knepley at gmail.com>; Ng, Cho-Kuen <cho at slac.stanford.edu>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
  Note that options like -mat_type aijcusparse  -vec_type cuda only work if the program is set up to allow runtime swapping of matrix and vector types. If you have a call to MatCreateMPIAIJ() or other specific types then then these options do nothing but because Mark had you use -options_left the program will tell you at the end that it did not use the option so you will know.
On Jun 30, 2023, at 9:30 AM, Mark Adams <mfadams at lbl.gov> wrote:
PetscCall(PetscInitialize(&argc, &argv, NULL, help)); gives us the args and you run:
a.out -mat_type aijcusparse -vec_type cuda -log_view -options_left
On Fri, Jun 30, 2023 at 6:16 AM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Jun 30, 2023 at 1:13 AM Ng, Cho-Kuen via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Mark,
The application code reads in parameters from an input file, where we can put the PETSc runtime options. Then we pass the options to PetscInitialize(...). Does that sounds right?
PETSc will read command line argument automatically in PetscInitialize() unless you shut it off.
    Matt
Cho
From: Ng, Cho-Kuen <cho at slac.stanford.edu<mailto:cho at slac.stanford.edu>>
Sent: Thursday, June 29, 2023 8:32 PM
To: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Mark,
Thanks for the information. How do I put the runtime options for the executable, say, a.out, which does not have the provision to append arguments? Do I need to change the C++ main to read in the options?
Cho
From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Sent: Thursday, June 29, 2023 5:55 PM
To: Ng, Cho-Kuen <cho at slac.stanford.edu<mailto:cho at slac.stanford.edu>>
Run with options: -mat_type aijcusparse -vec_type cuda -log_view -options_left
The last column of the performance data (from -log_view) will be the percent flops on the GPU. Check that that is > 0.
The end of the output will list the options that were used and options that were _not_ used (if any). Check that there are no options left.
On Thu, Jun 29, 2023 at 7:50 PM Ng, Cho-Kuen via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I installed PETSc on Perlmutter using "spack install petsc+cuda+zoltan" and used it by "spack load petsc/fwge6pf". Then I compiled the application code (purely CPU code) linking to the petsc package, hoping that I can get performance improvement using the petsc GPU backend. However, the timing was the same using the same number of MPI tasks with and without GPU accelerators. Have I missed something in the process, for example, setting up PETSc options at runtime to use the GPU backend?
Cho
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230714/ae52b2d1/attachment-0001.html>
