[petsc-users] Near null space for a fieldsplit in petsc4py
Karin&NiKo niko.karin at gmail.com
Thu Jul 13 11:22:54 CDT 2023
Thank you very much for the information Matt.
Unfortunately, I do not use DM....  :-(
Le jeu. 13 juil. 2023 à 13:44, Matthew Knepley <knepley at gmail.com> a écrit :
> On Thu, Jul 13, 2023 at 5:33 AM Pierre Jolivet <pierre.jolivet at lip6.fr>
> wrote:
>> Dear Nicolas,
>> On 13 Jul 2023, at 10:17 AM, TARDIEU Nicolas <nicolas.tardieu at edf.fr>
>> wrote:
>> Dear Pierre,
>> You are absolutely right. I was using a --with-debugging=0 (aka release)
>> install and this is definitely an error.
>> Once I used my debug install, I found the way to fix my problem. The
>> solution is in the attached script: I first need to extract the correct
>> block from the PC operator's MatNest and then append the null space to it.
>> Anyway this is a bit tricky...
>> Yep, it’s the same with all “nested” solvers, fieldsplit, ASM, MG, you
>> name it.
>> You first need the initial PCSetUp() so that the bare minimum is put in
>> place, then you have to fetch things yourself and adapt it to your needs.
>> We had a similar discussion with the MEF++ people last week, there is
>> currently no way around this, AFAIK.
> Actually, I hated this as well, so I built a way around it _if_ you are
> using a DM to define the problem. Then
> you can set a "nullspace constructor" to make it if the field you are
> talking about is ever extracted. You use DMSetNullSpaceConstructor(). I do
> this in SNES ex62 and ex69, and other examples.
>   Thanks,
>      Matt
>> Thanks,
>> Pierre
>> Regards,
>> Nicolas
>> *De :* pierre.jolivet at lip6.fr <pierre.jolivet at lip6.fr>
>> *Envoyé :* mercredi 12 juillet 2023 19:52
>> *À :* TARDIEU Nicolas <nicolas.tardieu at edf.fr>
>> *Cc :* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>> *Objet :* Re: [petsc-users] Near null space for a fieldsplit in petsc4py
>> > On 12 Jul 2023, at 6:04 PM, TARDIEU Nicolas via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> > Dear PETSc team,
>> > In the attached example, I set up a block pc for a saddle-point problem
>> in petsc4py. The IS define the unknowns, namely some physical quantity
>> (phys) and a Lagrange multiplier (lags).
>> > I would like to attach a near null space to the physical block, in
>> order to get the best performance from an AMG pc.
>> > I have been trying hard, attaching it to the initial block, to the IS
>> but no matter what I am doing, when it comes to "ksp_view", no near null
>> space is attached to the matrix.
>> > Could you please help me figure out what I am doing wrong ?
>> Are you using a double-precision 32-bit integers real build of PETSc?
>> Is it --with-debugging=0?
>> Because with my debug build, I get the following error (thus explaining
>> why it’s not attached to the KSP).
>> Traceback (most recent call last):
>>   File "/Volumes/Data/Downloads/test/test_NullSpace.py", line 35, in
>> <module>
>>     ns = NullSpace().create(True, [v], comm=comm)
>>   File "petsc4py/PETSc/Mat.pyx", line 5611, in
>> petsc4py.PETSc.NullSpace.create
>> petsc4py.PETSc.Error: error code 62
>> [0] MatNullSpaceCreate() at
>> /Volumes/Data/repositories/petsc/src/mat/interface/matnull.c:249
>> [0] Invalid argument
>> [0] Vector 0 must have 2-norm of 1.0, it is 22.3159
>> Furthermore, if you set yourself the constant vector in the near
>> null-space, then the first argument of create() must be False, otherwise,
>> you’ll have twice the same vector, and you’ll end up with another error
>> (the vectors in the near null-space must be orthonormal).
>> If things still don’t work after those couple of fixes, please feel free
>> to send an up-to-date reproducer.
>> Thanks,
>> Pierre
>> > Thanks,
>> > Nicolas
>> > Ce message et toutes les pièces jointes (ci-après le 'Message') sont
>> établis à l'intention exclusive des destinataires et les informations qui y
>> figurent sont strictement confidentielles. Toute utilisation de ce Message
>> non conforme à sa destination, toute diffusion ou toute publication totale
>> ou partielle, est interdite sauf autorisation expresse.
>> > Si vous n'êtes pas le destinataire de ce Message, il vous est interdit
>> de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou
>> partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de
>> votre système, ainsi que toutes ses copies, et de n'en garder aucune trace
>> sur quelque support que ce soit. Nous vous remercions également d'en
>> avertir immédiatement l'expéditeur par retour du message.
>> > Il est impossible de garantir que les communications par messagerie
>> électronique arrivent en temps utile, sont sécurisées ou dénuées de toute
>> erreur ou virus.
>> > ____________________________________________________
>> > This message and any attachments (the 'Message') are intended solely
>> for the addressees. The information contained in this Message is
>> confidential. Any use of information contained in this Message not in
>> accord with its purpose, any dissemination or disclosure, either whole or
>> partial, is prohibited except formal approval.
>> > If you are not the addressee, you may not copy, forward, disclose or
>> use any part of it. If you have received this message in error, please
>> delete it and all copies from your system and notify the sender immediately
>> by return message.
>> > E-mail communication cannot be guaranteed to be timely secure, error or
>> virus-free.
>> > <test.tgz>
>> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de
>> erreur ou virus.
>> This message and any attachments (the 'Message') are intended solely for
>> the addressees. The information contained in this Message is confidential.
>> Any use of information contained in this Message not in accord with its
>> purpose, any dissemination or disclosure, either whole or partial, is
>> If you are not the addressee, you may not copy, forward, disclose or use
>> any part of it. If you have received this message in error, please delete
>> it and all copies from your system and notify the sender immediately by
>> return message.
>> virus-free.
>> <test_NullSpace.py.gz>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230713/8c0fd605/attachment.html>
