[petsc-users] Inquiry about the PetscScalar in Petsc.
Barry Smith bsmith at petsc.dev
Tue Jul 11 11:41:45 CDT 2023
> On Jul 11, 2023, at 12:16 PM, neil liu <liufield at gmail.com> wrote:
> I think I understood that.
> 1) In order to save memory, use a larger real system
   This will save a little memory, but requires a slight change to your model/code for your problem
> 2) vec will store the real part with imaginary part equal to zero in the context of --scalar =complex. But this will not save memory.
    This will waste a little memory.
    Usually, coordinates do not take much of the total memory, that is solution vectors, matrices, intermediate work vectors for the solver take most of the memory
so I suggest just using complex and not worrying about the few percent memory lost.
> Right?
> Thanks,
> Xiaodong
> On Tue, Jul 11, 2023 at 12:03 PM neil liu <liufield at gmail.com <mailto:liufield at gmail.com>> wrote:
>> Do you mean that,
>> even if I configure with --scalar=complex, when I use vecGetarray to get the coords, the coords array is still stored in a real manner?
>> Thanks,
>> Xiaodong
>> On Tue, Jul 11, 2023 at 11:54 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Tue, Jul 11, 2023 at 11:48 AM neil liu <liufield at gmail.com <mailto:liufield at gmail.com>> wrote:
>>>> Thanks for your reply.
>>>> I am using DMPLEX to read GMSH. And it seems I have to use
>>>> DMGetCoordinatesLocal();
>>>> VecGetArray(veccords, &coords);//it seems coords has to be defined by complex either.
>>>> 2) Store the coordinates in coords with imaginary part equal to zero.
>>>> I got the coordinates from above function VecGetArray, therefore will this reduce the memory?
>>>> 3) is a good way to work around that.
>>> We just store them with real part 0.
>>>   Thanks,
>>>     Matt
>>>> On Tue, Jul 11, 2023 at 11:40 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>   Not really. PetscScalar (and entries of vectors etc) are either real or complex, they cannot be mixed.
>>>>>   What parts of PETSc are you using, DM?
>>>>>   You can
>>>>> 1) store the coordinates in arrays and not use Vec for them. (of if you are not using DM)
>>>>> 2) sore them in Vec but with imaginary part 0
>>>>> 3) rewrite your complex systems as real systems (with twice as many unknowns, but only real ones)
>>>>>   Barry
>>>>> > On Jul 11, 2023, at 11:34 AM, neil liu <liufield at gmail.com <mailto:liufield at gmail.com>> wrote:
>>>>> > Dear Petsc developers,
>>>>> > My computation involves both real and complex numbers.
>>>>> > For example, my coordinate is real, but my matrix is complex.
>>>>> > I use VecGetArray to get the coordinates. But it seems coordinates have to be defined in a complex manner to be consistent with complex matrix.
>>>>> > Is there some ways to work around this if I understood correctly ?
>>>>> > Thanks,
>>>>> > Xiaodong
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230711/2c01959c/attachment-0001.html>
