[petsc-users] Inquiry about the PetscScalar in Petsc.
neil liu liufield at gmail.com
Tue Jul 11 11:03:37 CDT 2023
Do you mean that,
even if I configure with --scalar=complex, when I use vecGetarray to get
the coords, the coords array is still stored in a real manner?
Xiaodong
On Tue, Jul 11, 2023 at 11:54 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 11, 2023 at 11:48 AM neil liu <liufield at gmail.com> wrote:
>> Thanks for your reply.
>> I am using DMPLEX to read GMSH. And it seems I have to use
>> DMGetCoordinatesLocal();
>> VecGetArray(veccords, &coords);//it seems coords has to be defined by
>> complex either.
>> 2) Store the coordinates in coords with imaginary part equal to zero.
>> I got the coordinates from above function *VecGetArray*, therefore will
>> this reduce the memory?
>> 3) is a good way to work around that.
> We just store them with real part 0.
>   Thanks,
>     Matt
>> On Tue, Jul 11, 2023 at 11:40 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>   Not really. PetscScalar (and entries of vectors etc) are either real
>>> or complex, they cannot be mixed.
>>>   What parts of PETSc are you using, DM?
>>>   You can
>>> 1) store the coordinates in arrays and not use Vec for them. (of if you
>>> are not using DM)
>>> 2) sore them in Vec but with imaginary part 0
>>> 3) rewrite your complex systems as real systems (with twice as many
>>> unknowns, but only real ones)
>>>   Barry
>>> > On Jul 11, 2023, at 11:34 AM, neil liu <liufield at gmail.com> wrote:
>>> > Dear Petsc developers,
>>> > My computation involves both real and complex numbers.
>>> > For example, my coordinate is real, but my matrix is complex.
>>> > I use VecGetArray to get the coordinates. But it seems coordinates
>>> have to be defined in a complex manner to be consistent with complex
>>> matrix.
>>> > Is there some ways to work around this if I understood correctly ?
>>> > Thanks,
>>> > Xiaodong
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230711/d9d9034f/attachment.html>
