[petsc-users] Inquiry about the PetscScalar in Petsc.
neil liu liufield at gmail.com
Tue Jul 11 10:48:28 CDT 2023
Thanks for your reply.
I am using DMPLEX to read GMSH. And it seems I have to use
DMGetCoordinatesLocal();
VecGetArray(veccords, &coords);//it seems coords has to be defined by
complex either.
2) Store the coordinates in coords with imaginary part equal to zero.
I got the coordinates from above function *VecGetArray*, therefore will
this reduce the memory?
3) is a good way to work around that.
On Tue, Jul 11, 2023 at 11:40 AM Barry Smith <bsmith at petsc.dev> wrote:
>   Not really. PetscScalar (and entries of vectors etc) are either real or
> complex, they cannot be mixed.
>   What parts of PETSc are you using, DM?
>   You can
> 1) store the coordinates in arrays and not use Vec for them. (of if you
> are not using DM)
> 2) sore them in Vec but with imaginary part 0
> 3) rewrite your complex systems as real systems (with twice as many
> unknowns, but only real ones)
>   Barry
> > On Jul 11, 2023, at 11:34 AM, neil liu <liufield at gmail.com> wrote:
> > Dear Petsc developers,
> > My computation involves both real and complex numbers.
> > For example, my coordinate is real, but my matrix is complex.
> > I use VecGetArray to get the coordinates. But it seems coordinates have
> to be defined in a complex manner to be consistent with complex matrix.
> > Is there some ways to work around this if I understood correctly ?
> > Thanks,
> > Xiaodong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230711/02948faf/attachment.html>
