[petsc-users] Scalable Solver for Incompressible Flow
Thu Jul 6 20:24:59 CDT 2023
On Thu, Jul 6, 2023 at 8:30 PM Alexander Lindsay <alexlindsay239 at gmail.com>
wrote:
> This is an interesting article that compares a multi-level ILU algorithm
> to approximate commutator and augmented Lagrange methods:
> https://doi.org/10.1002/fld.5039
That is for incompressible NS. The results are not better than
https://arxiv.org/abs/1810.03315, and that PC is considerably simpler and
already implemented in PETSc. There is an update in to this
https://epubs.siam.org/doi/abs/10.1137/21M1430698?casa_token=Fp_XhuZStZ0AAAAA:YDhnkW9XvAom_b8KocWz-hBEI7FAt46aw3ICa0FvCrOVCtYr9bwvtqJ4aBOTkDSvANKh6YTQEw
which removes the need for complicated elements.
You might need stuff like ILU for compressible flow, but I think
incompressible is solved.
     Matt
> On Wed, Jun 28, 2023 at 11:37 AM Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> I do believe that based off the results in
>> https://doi.org/10.1137/040608817 we should be able to make LSC, with
>> proper scaling, compare very favorably with PCD
>> On Tue, Jun 27, 2023 at 10:41 AM Alexander Lindsay <
>>> I've opened https://gitlab.com/petsc/petsc/-/merge_requests/6642 which
>>> adds a couple more scaling applications of the inverse of the diagonal of A
>>> On Mon, Jun 26, 2023 at 6:06 PM Alexander Lindsay <
>>>> I guess that similar to the discussions about selfp, the approximation
>>>> of the velocity mass matrix by the diagonal of the velocity sub-matrix will
>>>> improve when running a transient as opposed to a steady calculation,
>>>> especially if the time derivative is lumped.... Just thinking while typing
>>>> On Mon, Jun 26, 2023 at 6:03 PM Alexander Lindsay <
>>>>> Returning to Sebastian's question about the correctness of the current
>>>>> LSC implementation: in the taxonomy paper that Jed linked to (which talks
>>>>> about SIMPLE, PCD, and LSC), equation 21 shows four applications of the
>>>>> inverse of the velocity mass matrix. In the PETSc implementation there are
>>>>> at most two applications of the reciprocal of the diagonal of A (an
>>>>> approximation to the velocity mass matrix without more plumbing, as already
>>>>> pointed out). It seems like for code implementations in which there are
>>>>> possible scaling differences between the velocity and pressure equations,
>>>>> that this difference in the number of inverse applications could be
>>>>> significant? I know Jed said that these scalings wouldn't really matter if
>>>>> you have a uniform grid, but I'm not 100% convinced yet.
>>>>> I might try fiddling around with adding two more reciprocal
>>>>> applications.
>>>>> On Fri, Jun 23, 2023 at 1:09 PM Pierre Jolivet <pierre.jolivet at lip6.fr>
>>>>> wrote:
>>>>>> On 23 Jun 2023, at 10:06 PM, Pierre Jolivet <pierre.jolivet at lip6.fr>
>>>>>> wrote:
>>>>>> On 23 Jun 2023, at 9:39 PM, Alexander Lindsay <
>>>>>> Ah, I see that if I use Pierre's new 'full' option for
>>>>>> -mat_schur_complement_ainv_type
>>>>>> That was not initially done by me
>>>>>> Oops, sorry for the noise, looks like it was done by me indeed
>>>>>> in 9399e4fd88c6621aad8fe9558ce84df37bd6fada…
>>>>>> Thanks,
>>>>>> Pierre
>>>>>> (though I recently
>>>>>> tweaked MatSchurComplementComputeExplicitOperator() a bit to use
>>>>>> KSPMatSolve(), so that if you have a small Schur complement — which is not
>>>>>> really the case for NS — this could be a viable option, it was previously
>>>>>> painfully slow).
>>>>>> Thanks,
>>>>>> Pierre
>>>>>> that I get a single iteration for the Schur complement solve with LU.
>>>>>> That's a nice testing option
>>>>>> On Fri, Jun 23, 2023 at 12:02 PM Alexander Lindsay <
>>>>>>> I guess it is because the inverse of the diagonal form of A00
>>>>>>> becomes a poor representation of the inverse of A00? I guess naively I
>>>>>>> would have thought that the blockdiag form of A00 is A00
>>>>>>> On Fri, Jun 23, 2023 at 10:18 AM Alexander Lindsay <
>>>>>>>> Hi Jed, I will come back with answers to all of your questions at
>>>>>>>> some point. I mostly just deal with MOOSE users who come to me and tell me
>>>>>>>> their solve is converging slowly, asking me how to fix it. So I generally
>>>>>>>> assume they have built an appropriate mesh and problem size for the problem
>>>>>>>> they want to solve and added appropriate turbulence modeling (although my
>>>>>>>> general assumption is often violated).
>>>>>>>> > And to confirm, are you doing a nonlinearly implicit
>>>>>>>> velocity-pressure solve?
>>>>>>>> Yes, this is our default.
>>>>>>>> A general question: it seems that it is well known that the quality
>>>>>>>> of selfp degrades with increasing advection. Why is that?
>>>>>>>> On Wed, Jun 7, 2023 at 8:01 PM Jed Brown <jed at jedbrown.org> wrote:
>>>>>>>>> Alexander Lindsay <alexlindsay239 at gmail.com> writes:
>>>>>>>>> > This has been a great discussion to follow. Regarding
>>>>>>>>> >> when time stepping, you have enough mass matrix that cheaper
>>>>>>>>> preconditioners are good enough
>>>>>>>>> > I'm curious what some algebraic recommendations might be for
>>>>>>>>> high Re in
>>>>>>>>> > transients.
>>>>>>>>> What mesh aspect ratio and streamline CFL number? Assuming your
>>>>>>>>> model is turbulent, can you say anything about momentum thickness Reynolds
>>>>>>>>> number Re_θ? What is your wall normal spacing in plus units? (Wall resolved
>>>>>>>>> or wall modeled?)
>>>>>>>>> > I've found one-level DD to be ineffective when applied
>>>>>>>>> monolithically or to the momentum block of a split, as it scales with the
>>>>>>>>> mesh size.
>>>>>>>>> I wouldn't put too much weight on "scaling with mesh size" per se.
>>>>>>>>> You want an efficient solver for the coarsest mesh that delivers sufficient
>>>>>>>>> accuracy in your flow regime. Constants matter.
>>>>>>>>> Refining the mesh while holding time steps constant changes the
>>>>>>>>> advective CFL number as well as cell Peclet/cell Reynolds numbers. A
>>>>>>>>> meaningful scaling study is to increase Reynolds number (e.g., by growing
>>>>>>>>> the domain) while keeping mesh size matched in terms of plus units in the
>>>>>>>>> viscous sublayer and Kolmogorov length in the outer boundary layer. That
>>>>>>>>> turns out to not be a very automatic study to do, but it's what matters and
>>>>>>>>> you can spend a lot of time chasing ghosts with naive scaling studies.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230706/f0f8370c/attachment.html>
