[petsc-users] Question about residue norm in PETSc
Sun Jul 2 05:50:43 CDT 2023
On Sun, Jul 2, 2023 at 2:24 AM 王赫萌 <wanghemeng at 163.com> wrote:
> Dear PETSc Team,
> Sorry to bother! My name is Hemeng Wang, and I am currently learning the
> use of PETSc software package. I am confused while calculating the norm of
> residue.
> I calculated residue norm by myself with:
>   PetscCall(VecNorm(b, NORM_2, &norm_b)); // (main.c, line 74)
>   PetscCall(VecDuplicate(b, &u)); // (main.c, line 105)
>   PetscCall(MatMult(A, x, u));
>   PetscCall(VecAXPY(b, -1.0, u));
>   PetscCall(VecNorm(b, NORM_2, &norm_delta));
> and check the (norm_delta) / (norm_b). It seems not the `atol` which set
> by `KSPSetTolerances()`.
> (I set atol as 1e-12, but got 5e-7 finally)
> (options:  -ksp_type cg -pc_type gamg -ksp_converged_reason -ksp_norm_type
> unpreconditioned -ksp_monitor_true_residual)
If you are using the default convergence test, there is an absolute
tolerance (atol) _and_ a relative tolerance (rtol). It seems likely you hit
the relative tolerance. You can check this using
You could make rtol really small if you want to just see the atol
  -ksp_rtol 1e-20
     Matt
> I also check the soure code of `KSPSolve_CG` in
> `petsc/src/ksp/ksp/impls/cg/cg.c`. And could not figure out where is the
> difference.
> I will really really appreciated if someone can explain the calculation of
> `resid norm` in petsc. And where is my mistake.
> To provide you with more context, here are the source code about my
> implementation. And the output of my test.
> main.c
> Main code of my program
> mmio.h  mmloader.h
> Headers for matrix read
> Makefile
> For compiling, same as sample provided
> task.sh
> A script for running program in `slurm`
> slurm-4803840.out
> Output of my test
> Thank you very much for your time and attention. I greatly appreciate your
> support and look forward to hearing from you soon.
> Best regards,
> Hemeng Wang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230702/9f4dfbfa/attachment.html>
