[petsc-users] about repeat of expensive functions using VecScatterCreateToAll
    Venugopal, Vysakh (venugovh)
    venugovh at mail.uc.edu
    Tue Jan 17 14:12:53 CST 2023
I am doing the following thing.
Step 1. Create DM object and get global vector 'V' using DMGetGlobalVector.
Step 2. Doing some parallel operations on V.
Step 3. I am using VecScatterCreateToAll on V to create a sequential vector 'V_SEQ' using VecScatterBegin/End with SCATTER_FORWARD.
Step 4. I am performing an expensive operation on V_SEQ and outputting the updated V_SEQ.
Step 5. I am using VecScatterBegin/End with SCATTER_REVERSE (global and sequential flipped) to get V that is updated with new values from V_SEQ.
Step 6. I continue using this new V on the rest of the parallelized program.
Question: Suppose I have n MPI processes, is the expensive operation in Step 4 repeated n times? If yes, is there a workaround such that the operation in Step 4 is performed only once? I would like to follow the same structure as steps 1 to 6 with step 4 only performed once.
Vysakh Venugopal
Vysakh Venugopal
Ph.D. Candidate
Department of Mechanical Engineering
University of Cincinnati, Cincinnati, OH 45221-0072
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230117/04e3d822/attachment.html>
