[petsc-users] Vec Ownership ranges with Global Section Offsets
    Matthew Knepley
    knepley at gmail.com
    Fri Jan  6 09:23:25 CST 2023
On Fri, Jan 6, 2023 at 10:10 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Matt
> I apologize for any lack of clarity in the initial email.
> looking at the initial output on rank 1
> write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
> cell           0 offset        2475 oStart        2640        -165
>  cell           1 offset        2530 oStart        2640        -110
>  cell           2 offset        2585 oStart        2640         -55
>  cell           3 offset        2640 oStart        2640           0
> cell          15 offset        -771 oStart        2640       -3411
> cell 15 provides a negative offset because it is the overlap cell (that is
> unowned)
> The remained of cells are all owned. However, the first 3 cells (0,1,2)
> return an offset that is less than the starting ownership range. I would
> expect cell 0 to start at offset 2640 at minimum.
Send the output for this section
  call PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD);
     Matt
> Sincerely
> Nicholas
> On Fri, Jan 6, 2023 at 10:05 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
>>> Apologies. If it helps, there is one cell of overlap in this small test
>>> case for a 2D mesh that is 1 cell in height and a number of cells in
>>> length. .
>>> process 0
>>>  Petsc VecGetLocalSize        2750
>>>  size(stateVecV)        2750
>>> process 1
>>>  Petsc VecGetLocalSize        2640
>>>  size(stateVecV)        2640
>> The offsets shown below are well-within these sizes. I do not understand
>> the problem.
>>   Thanks,
>>      Matt
>>> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>>>> Hi Matt
>>>>> I made a typo on the line statVecV(offset) = <set to something> in my
>>>>> example, I agree. (I wrote that offhand since the actual assignment is much
>>>>> larger) I should be statVecV(offset+1) = <assignment> so I'm confident it's
>>>>> not a 1 0 indexing thing.
>>>>> My question is more related to what is happening in the offsets. c0
>>>>> and c1 are pulled using DMplexgetheight stratum, so they are zero-indexed
>>>>> (which is why I loop from c0 to (c1-1)).
>>>>> For the size inquiries. on processor 0
>>>>>  Petsc VecGetSize(stateVec)        5390
>>>> I need to see VecGetLocalSize()
>>>>   Matt
>>>>> on processor 1
>>>>> Petsc VecGetSize 5390
>>>>> It's quite weird to me that processor one can have a positive offset
>>>>> that is less than its starting ownership index (in the initial email
>>>>> output).
>>>>> Thanks for the assistance
>>>>> Nicholas
>>>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>>>> Hi Petsc Users,
>>>>>>> I'm working with a dmplex system with a subsampled mesh distributed
>>>>>>> with an overlap of 1.
>>>>>>> I'm encountering unusual situations when using VecGetOwnershipRange
>>>>>>> to adjust the offset received from a global section. The logic of the
>>>>>>> following code is first to get the offset needed to index a global vector
>>>>>>> while still being able to check if it is an overlapped cell and skip if
>>>>>>> needed while counting the owned cells.
>>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>>>> do i = c0, (c1-1)
>>>>>>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>>> oStart
>>>>>>>     if(offset<0) then
>>>>>>>         cycle
>>>>>>>     endif
>>>>>>> offset=offset-oStart
>>>>>>> plexcells=plexcells+1
>>>>>>> stateVecV(offset)= <set to something> enddo
>>>>>>> I'm noticing some very weird results that I've appended below. The
>>>>>>> GetOffset documentation notes that a negative offset indicates an unowned
>>>>>>> point (which I use to cycle). However, the offset subtraction with oStart
>>>>>>> will yield an illegal index for the Vector access. I see that on the
>>>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>>>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>>>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>>>> definition have synchronized section information) I was wondering if there
>>>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>>>> of subtracting the offset of cell 0 perhaps?
>>>>>> Can you show your vector sizes? Are you sure it is not the fact that
>>>>>> F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> on rank 0
>>>>>>>  cell           0 offset           0 oStart           0           0
>>>>>>>  cell           1 offset          55 oStart           0          55
>>>>>>>  cell           2 offset         110 oStart           0         110
>>>>>>>  cell           3 offset         165 oStart           0         165
>>>>>>>  cell           4 offset         220 oStart           0         220
>>>>>>>  cell           5 offset         275 oStart           0         275
>>>>>>>  cell           6 offset         330 oStart           0         330
>>>>>>>  cell           7 offset         385 oStart           0         385
>>>>>>>  cell           8 offset         440 oStart           0         440
>>>>>>>  cell           9 offset         495 oStart           0         495
>>>>>>>  cell          10 offset         550 oStart           0         550
>>>>>>>  cell          11 offset         605 oStart           0         605
>>>>>>>  cell          12 offset         660 oStart           0         660
>>>>>>>  cell          13 offset         715 oStart           0         715
>>>>>>> and on rank one
>>>>>>>  cell           4 offset        2695 oStart        2640          55
>>>>>>>  cell           5 offset        2750 oStart        2640         110
>>>>>>>  cell           6 offset        2805 oStart        2640         165
>>>>>>>  cell           7 offset        2860 oStart        2640         220
>>>>>>>  cell           8 offset        2915 oStart        2640         275
>>>>>>>  cell           9 offset        2970 oStart        2640         330
>>>>>>>  cell          10 offset        3025 oStart        2640         385
>>>>>>>  cell          11 offset        3080 oStart        2640         440
>>>>>>>  cell          12 offset        3135 oStart        2640         495
>>>>>>>  cell          13 offset        3190 oStart        2640         550
>>>>>>>  cell          14 offset        3245 oStart        2640         605
>>>>>>> Sincerely
>>>>>>> Nicholas
>>>>>>> Ph.D. Candidate
>>>>>>> Computational Aeroscience Lab
>>>>>>> University of Michigan
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> Ph.D. Candidate
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Ph.D. Candidate
>> experiments lead.
>> -- Norbert Wiener
> Ph.D. Candidate
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/e583cd25/attachment-0001.html>
