[petsc-users] TS docs wrong URLs in Examples
Barry Smith bsmith at petsc.dev
Thu Dec 21 16:32:43 CST 2023
https://gitlab.com/petsc/petsc/-/merge_requests/7135
Regex processing is not ideal for this task; I've modified the code to remove most false positive finds.
Thanks for reporting the problem,
Barry
> On Dec 21, 2023, at 8:35 AM, Niclas Götting <ngoetting at itp.uni-bremen.de> wrote:
> Hi all,
> I noticed that all links to the examples under https://petsc.org/release/manualpages/TS/TS/ point to the wrong URL. Instead of src/ts/**/*, they point to src/sys/**/*, which does not seem to be right. This definitely is a minor issue, but I couldn't see an obvious fix via "Edit this page", so here is the e-mail.
> Best regards
> Niclas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231221/401ef04f/attachment.html>
