[petsc-users] DMSTAG Gathering Vector on single process
Colton Bryant coltonbryant2021 at u.northwestern.edu
Wed Dec 13 11:02:21 CST 2023
Ok! Thanks for the reply. I'll take a look when I get a chance.
-Colton
On Wed, Dec 13, 2023 at 10:48 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 13, 2023 at 11:22 AM Colton Bryant <
> coltonbryant2021 at u.northwestern.edu> wrote:
>> Hi,
>> Thanks for the help last week. The suggestions made the implementation I
>> had much cleaner. I had one follow up question. Is there a way to sort of
>> undo this operation? I know the vec scatter can be done backwards to
>> distribute the arrays but I didn't see an easy way to migrate the DMDA
>> vectors back into the DMStag object.
> It is not there. However, writing it would be straightforward. I would
>   1) Expose DMStagMigrateVecDMDA(), which is not currently public
>   2) Add a ScatterMode argument
>   3) Put in code that calls DMStagSetValuesStencil(), rather than
> GetValuesStencil()
> We would be happy to take on MR on this, and could help in the review.
>   Thanks,
>      MAtt
>> Thanks for any advice.
>> -Colton
>> On Wed, Dec 6, 2023 at 8:18 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> On Dec 6, 2023, at 8:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Dec 6, 2023 at 8:10 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   Depending on the serial library you may not need to split the vector
>>>> into DMDA vectors with DMStagVecSplitToDMDA() for each component. Just
>>>> global to natural and scatter to zero on the full vector, now the full
>>>> vector is on the first rank and you can access what you need in that one
>>>> vector if possible.
>>> Does DMStag have a GlobalToNatural?
>>>    Good point, it does not appear to have such a thing, though it could.
>>> Also, the serial code would have to have identical interleaving.
>>>   Thanks,
>>>      Matt
>>>> On Dec 6, 2023, at 6:37 PM, Colton Bryant <
>>>> Ah excellent! I was not aware of the ability to preallocate the objects
>>>> and migrate them each time.
>>>> Thanks!
>>>> -Colton
>>>> On Wed, Dec 6, 2023 at 5:18 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Dec 6, 2023 at 5:54 PM Colton Bryant <
>>>>>> Hello,
>>>>>> I am working on a code in which a DMSTAG object is used to solve a
>>>>>> fluid flow problem and I need to gather this flow data on a single process
>>>>>> to interact with an existing (serial) library at each timestep of my
>>>>>> simulation. After looking around the solution I've tried is:
>>>>>> -use DMStagVecSplitToDMDA to extract vectors of each component of the
>>>>>> flow
>>>>>> -use DMDACreateNaturalVector and DMDAGlobalToNatural to get the
>>>>>> components naturally ordered
>>>>>> -use VecScatterCreateToZero to set up and then do the scatter to
>>>>>> gather on the single process
>>>>>> Unless I'm misunderstanding something this method results in a lot of
>>>>>> memory allocation/freeing happening at each step of the evolution and I was
>>>>>> wondering if there is a way to directly perform such a scatter from the
>>>>>> DMSTAG object without splitting as I'm doing here.
>>>>> 1) You can see here:
>>>>> https://petsc.org/main/src/dm/impls/stag/stagda.c.html#DMStagVecSplitToDMDA
>>>>> that this function is small. You can do the DMDA creation manually,
>>>>> and then just call DMStagMigrateVecDMDA() each time, which will not
>>>>> create anything.
>>>>> 2) You can create the natural vector upfront, and just scatter each
>>>>> time.
>>>>> 3) You can create the serial vector upfront, and just scatter each
>>>>> time.
>>>>> This is some data movement. You can compress the g2n and 2zero
>>>>> scatters using
>>>>>   https://petsc.org/main/manualpages/PetscSF/PetscSFCompose/
>>>>> as an optimization.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Any advice would be much appreciated!
>>>>>> Best,
>>>>>> Colton Bryant
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231213/05c9d9c5/attachment-0001.html>
