[petsc-users] DMPlex "Could not find orientation for quadrilateral"
onur.notonur onur.notonur at proton.me
Wed Dec 13 02:12:51 CST 2023
This page explains polyMesh in the section 4.1.2: https://www.openfoam.com/documentation/user-guide/4-mesh-generation-and-conversion/4.1-mesh-description
(Also I added my polyMesh files as attachment.)
After my first email I generated valid mesh by finding 2 of the 6 faces which have no common vertex, then arranging them to look like this: 1-2-3-4 is my first face, 5-6-7-8 is my second face. But this approach isn't a general solution (but currently it works because my mesh consists of only hexahedral elements), If I could learn the true solution I'd be happy! Thank you again
1 2
| 4+--+---+3
5+---+--+8 |
`. | `.|  6+------+7
Sent with [Proton Mail](https://proton.me/) secure email.
On Wednesday, December 13th, 2023 at 2:16 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 12, 2023 at 12:22 PM onur.notonur via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I hope this email finds you well. I am currently working on importing an OpenFOAM PolyMesh into DMPlex, and I've encountered an issue. The PolyMesh format includes face owner cells/neighbor cells and face-to-vertex connectivity. I was using the "DMPlexCreateFromCellListPetsc()" function, which required cell-to-vertex connectivity. However, when attempting to create the cell connectivity using an edge loop [p_0, p_1, ..., p_7] (p_n and p_(n+1) are valid edges in my mesh), I encountered an error stating, "Could not find orientation for quadrilateral."
>> (Actually at first, I generated the connectivity list by simply creating a cell-to-face list and then using that to create a cell-to-vertex list. (just map over the list and remove duplicates) This created a DMPlex successfully, however, resulted in a mesh that was incorrect when looking with ParaView. I think that was because of I stated wrong edge loop to create cells)
>> I understand that I may need to follow a different format for connectivity, but I'm not sure what that format is. My current mesh is hexahedral, consisting of 8 corner elements(if important). I would appreciate any guidance on a general approach to address this issue.
> Can you start by giving the PolyMesh format, or some URL with it documented?
> Thanks,
> Matt
>> Thank you for your time and assistance.
>> Best,
>> Onur
>> Sent with Proton Mail secure email.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> [https://www.cse.buffalo.edu/~knepley/](http://www.cse.buffalo.edu/~knepley/)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231213/aaef6c7e/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231213/aaef6c7e/attachment-0001.zip>
