[petsc-users] difference in Face Sets in latest petsc release
Tue Dec 12 17:51:46 CST 2023
On Tue, Dec 12, 2023 at 5:50 PM Sharan Roongta <s.roongta at mpie.de> wrote:
> Hello,
> I see discrepancy in the size/value of the 'Face Sets' printed in the
> current release v3.20.2 , and v3.18.6
> Attached is the .msh file
> -dm_view with v3.18.6
> DM Object: Generated Mesh 1 MPI process
>   type: plex
> Generated Mesh in 3 dimensions:
>   Number of 0-cells per rank: 14
>   Number of 1-cells per rank: 49
>   Number of 2-cells per rank: 60
>   Number of 3-cells per rank: 24
> Labels:
>   celltype: 4 strata with value/size (0 (14), 6 (24), 3 (60), 1 (49))
>   depth: 4 strata with value/size (0 (14), 1 (49), 2 (60), 3 (24))
>   Cell Sets: 1 strata with value/size (1 (24))
>   Face Sets: 5 strata with value/size (1 (4), 2 (4), 3 (4), 4 (4), 5 (4))
> -dm_view with the current release (commit 4b9a870af96)
>   type: plex
> Labels:
>   Face Sets: 12 strata with value/size (1 (5), 2 (5), 3 (5), 4 (5), 5 (5),
> 6 (1), 7 (1), 8 (1), 9 (1), 10 (1), 11 (1), 12 (1))
> I believe the older version printed the correct thing? Has something
> changed in the interpretation of Face Sets?
Yes. In the older version, I was only labeling cells, faces, and vertices.
There were complaints, so I put in the edge labels. If you check, all the
additional labels are on edges, and checking your .msh file, those edges
clearly have those labels.
     Matt
> Thanks,
> Sharan
> *Group - Theory & Simulation*
> *Department of Microstructure Physics & Alloy Design*
> Stay up to date and follow us on LinkedIn, Twitter and YouTube.
> Max-Planck-Institut für Eisenforschung GmbH
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Handelsregister B 2533
> Amtsgericht Düsseldorf
> Geschäftsführung
> Prof. Dr. Gerhard Dehm
> Prof. Dr. Jörg Neugebauer
> Prof. Dr. Dierk Raabe
> Dr. Kai de Weldige
> Ust.-Id.-Nr.: DE 11 93 58 514
> Steuernummer: 105 5891 1000
> Please consider that invitations and e-mails of our institute are
> only valid if they end with …@mpie.de.
> If you are not sure of the validity please contact rco at mpie.de
> Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
> aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
> In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231212/c7c45592/attachment-0001.html>
